07-13-2018, 05:19 PM | #15 |
Drives: '18 SS 1LE M6 Join Date: Feb 2018
The fact that people are ok with using a canned tune from some dude across the country based on a mod list still boggles my mind..
'18 1SS 1LE M6 NGM|| 11.5:1 Diamond Pistons || Callie's H-beams || Vengeance III Cam Kit || Built Heads || TSP LTs 1 7/8"(C-Coated) || MSD IM || DSX E85 || Rotofab || BMR Springs || 576/472 @7000rpm
07-13-2018, 05:22 PM | #16 |
Drives: 2017 1ss 1le Join Date: Sep 2015
What dude are you referring to?
07-15-2018, 09:40 PM | #17 | |
Drives: 2017 Grand Sport Join Date: Oct 2013
A remote tune is every bit as good as a dyno tune provided the customer datalogs as requested by the tuner so the tuner can fine tune the car.
17' Grand Sport
PP ported MSD IM, NW 103mm TB, ARH 2" headers w/ 3" catted x-pipe, PP Flex Fuel tune, Halltech CAI, some radials and a CATCHCAN!!! |
07-15-2018, 09:43 PM | #18 |
07-16-2018, 01:58 PM | #19 | |
There's no substitute for being able to drive down the street to your tuner. Have him drive the car while he's logging with you in it until everything works the way you want it. I've never had any of my cars remote tuned and that won't change.
07-18-2018, 11:22 PM | #20 | |
Well thats your opinion and you are certainly entitled to it. But again. There is no difference in a tuner looking at a log in person, or one that is emailed to them.
17' Grand Sport
07-19-2018, 12:22 PM | #21 | |
Example: A remote tuner tries to adjust the afr on a car that's running too lean under heavy load, based on what he sees in a log. Owner flashes the new tune he receives. Car still runs lean and nukes during a WOT run. The tuner didn't know one of the car's pumps were bad thus why the afr was going lean. Had he been in the car tuning he might've heard the pump making a bit of noise, signaling it's near its death. There is much more to tuning than just reading a log. Telling people that a remote tune is every bit as good as in-person is VERY misleading.
07-28-2018, 08:49 AM | #22 | |
Train Driver
Drives: 2018 Summit White ZL1 1LE Join Date: Jun 2013
There are only several benefits to the in person tune and the fuel pump failing example above is not one of them. 1. If on a Dyno you can optimize power production as well as provide a safe and smooth tune. 2. You can hear knock during the run and abort if needed or if the car goes severely lean. However a good tuner would never be so off to cause severe knock or a severe lean condition. 3. The ability to street verify the tune to tune transient response. Once again, most tuners have these parameters dialed in on a base file. Note about item 2. The owner take some responsibility in knowing his car and having proper functionality of critical components. If you are remote data logging you should be able to hear knock. And if a wideband is used monitor the lambda of the car during data logging. Many years ago I was given a bad base tune on an Edelbrock Eforce on an LS3, that I was going to fine tune. It knocked severely. The timing was way too high. I could hear it and feel the car was flat. That was a bad base file. In my opinion the very best email tuner is JRE. He is amazing at email tuning. The key to his success is a great base file library, and applies value files based on the mods. He's good enough that with basic mods he can tune the MAF without need of a wideband. Very impressive.
2018 Camaro ZL1LE
/ / Katech TB // RotoFab Dry // Borla 60606 // ATI Super Damper / / |
