12-08-2019, 03:35 PM | #15 |
Drives: Fast if no one's looking Join Date: Aug 2019
That’s even worse. Proper troubleshooting should be a prerequisite by the manufacturers before they provide parts and pay for labor under warranty.
12-08-2019, 08:45 PM | #16 |
Drives: 2019 Chevrolet Camaro 2SS Join Date: Jul 2019
I had the same issue twice, I had Onstar send me an email of the issue and dealer replaced the sensor no questions asked, a few months later it happens again while on vacation, I just happen to purchase a new set of wheels and decided to replace all sensors, a few weeks later it happens again same location on car, I am thinking now it’s a communication glitch, long story short I was installing a PTB and unhooked the negative battery terminal over night per instructions and have not had the TPMS issue since could be a coincidence, but I’ll take it
03-08-2020, 09:08 AM | #17 |
Treasure Coast Camaro 5
Drives: 19 2SS vert, Mosaic Blk, A10 Join Date: Feb 2009
I'm going through these same issues currently on my 19 2SS... Random on my fronts... I've been narrowing it down and think I've solved the issue... It started after I had my amp /sub installed in the trunk, and occurs significantly more with the top up (convertible) and at highway speeds... Last time it faulted, I pulled over, unplugged the fuse of the class D amp I'm running, and BAM all good!!!! I'm thinking it's the high frequency switching in the Amp that's interfering with the front TPMS, happening more with the top up, because the top helps "buffer" the radiating signals emitting from the Amp... Gonna try relocating it and using some metal to shield the Amp, see if that does it for good
08-14-2020, 10:52 AM | #18 | |
Drives: 2018 Chevrolet Camaro ZL1 Join Date: Jun 2018
08-14-2020, 11:53 AM | #19 |
Drives: 2017 Camaro SS 1LE Join Date: Oct 2018
The manufacturer mandates the process, not the dealership.
07-25-2021, 11:21 AM | #20 | |
08-07-2021, 06:49 AM | #21 |
Drives: Camaro SS 2018 Convertible Join Date: Apr 2019
Have the same issue with LED Side Markers. Interesting is, that with cheaper markers from China the issue does not appear.
The vendor is running some tests and should provide me a new set of them when tested and the issue fixed. So there is hope. |
10-21-2021, 09:01 AM | #22 |
Drives: 2020 Rally Green Metallic 1SS 1LE Join Date: May 2021
Same happening here, contacted manufacturer and put stock side markers back on and issue resolved.
2021 Camaro 1SS 1LE A10 - RIP
2020 Camaro 2SS A10 - Sold 2016 Camaro 2SS M6 - Sold 2001 Camaro SS M6 - Sold 1996 Camaro V6 Auto - Sold 1986 Corvette 406ci M6 1967 Camaro SS350 |
11-08-2021, 08:41 PM | #23 | |
Drives: 2019 Camaro 2SS Join Date: Oct 2012
2019 2SS, GM Performance intake, Carbon Fiber skirting, hood vent. |
11-09-2021, 10:40 AM | #24 | |
Drives: Camaro 2019 2SS Join Date: Jan 2021
I have a DD side markers and have the tire sensor issue only when the head lights are on. I replaced them 3 times. Still happens. I just ignore it now. Since it only happens at night. |
11-09-2021, 10:43 AM | #25 |
ive had my front right tpms sensor go on also on the way to the track the last time times in the am and then go off once its sunny out...weird issue but wonder what it has to do with anything?
11-09-2021, 08:53 PM | #26 | |
Thinking about putting the stock ones back on to confirm my thoughts and then just smoke the lenses.. |
11-10-2021, 03:45 AM | #27 | |
No I don’t see that, just the tire sensor error. I would totally switch back to see if that problem goes away. Sent from my iPhone using Tapatalk |
11-14-2021, 10:58 PM | #28 |
Emailed Diode Dynamics with the suspicion and issues I was having and they confirmed the side marker LED’s were interfering with the TPMS. They are working on fixing the problem and are close to coming out with a new side marker for the car. They will also replace the side markers for the new version when they’re satisfied the problem is corrected. So in the mean time I will be putting my stock ones back on until the new ones come in.
