Old 06-28-2018, 02:39 PM   #15
oneredry
HYPER SS
oneredry's Avatar
Drives: 2016 Supercharged 2SS
Originally Posted by Sledgehammer70 View Post
I am going to do some pulls with the stock TB, a stock ported TB, the NW TB and I think I will buy a Katech and see what happens.
and which ever you don't like (pending on the gains or not) you can sell the other one to me!
Ordered: 1/15/2016
2000 status 02/01/16
3000 status 02/29/16
3400 status 03/07/16 TPW of 03/14/16
4200 status 03/17/16 in transit!
Delivered 03/23/16
2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points.
| AWE touring - resinated catback with link pipes.
oneredry is offline   Reply With Quote
Old 06-28-2018, 03:46 PM   #16
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
Sorry wasn't trying to come off as a dick in my response, not my intent. Just have been getting a lot of people putting words in my mouth. Not much info available. Both are very well made. I'd love to understand the differences. Maybe I can buy a Katech and do some testing. Not a cheap endeavor, but worth it for the info.
I'm classy. If I'm going to put anything in your mouth, I will at least buy you a drink first.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock
800 SAE rwhp. 9.4 @ 145 mph.
Old 06-28-2018, 03:53 PM   #17
Sledgehammer70
Lethal Camaro
Sledgehammer70's Avatar
Drives: 16 2SS, 71 Std, Suburban RTS
Now that sounds like a good way to do things.
Sledgehammer70 is offline   Reply With Quote
Old 06-30-2018, 09:45 AM   #18
TJay74
I am contemplating putting a 103mm on my car since I got the PC D1SC on it now. Trying to figure out how to do it without having to replace the LT1 intake manifold, but I dont think there is a way since the LT1 intake manifold is pretty limited on being able to be opened up on the entry behind the TB area.
Old 07-01-2018, 08:11 AM   #19
wnta1ss
Drives: 2017 Camaro 1SS
Conventional wisdom says that on a blow-through system like your D1SC (throttle body is after the blower), you won't gain power by changing the throttle body or intake manifold. The guys who have reported gains thus far with the 103mm tb on supercharged cars have been using PD blowers, where the tb is mounted on the suction side. I have not seen the blow-through tb size question actually tested out though. Only test I saw was an MSD manifold compared to the stock LT1 manifold on a centrifugal supercharger setup, and it did actually gain a little power with the MSD. Since those results do not follow the conventional opinion on blow-through intake systems, this question on whether a 103mm tb would have any effect on a blow-through system remains. To try it out though, would require an $1100 MSD manifold to accept the 103, then the 103 itself is I think about $700, so it would cost a good bit of money.
Old 07-04-2018, 07:11 AM   #20
Blwn2016ss
Drives: 2016 hyper blue 2ss
The Katech throttle body is made by Nick Williams. Same thing
Blwn2016ss is offline   Reply With Quote
Old 07-04-2018, 07:43 AM   #21
laynlo15
Drives: 2022 Lt1 A10
I run a 102 Nick Williams, kicks ass and looks great hooked to the snout of my 2300 Maggie. Made 713 on the dyno in 88 degree temps. My old 90 mm ported TB made 703 in 58 degree temps on the same dyno. It makes some extra hp for sure.
Old 07-04-2018, 07:45 AM   #22
aai
aai's Avatar
Drives: '17 SS/1LE/PDR
good to know, thanks
PRAY ported MSD/TB : ROTOFAB/dry : DSX flex fuel : HPA Stage 3 : ARH catted long system/oem NPP : RSR harness bar : RSD : FSO1 : MPS4S 305F/325R
aai is offline   Reply With Quote
Old 07-04-2018, 07:54 AM   #23
laynlo15
Sledge why did you switch from the procharger to the Whipple?
Old 07-04-2018, 09:11 AM   #24
danhr
BAMF SS
danhr's Avatar
What makes you say that?
Stock Longblock
Old 07-04-2018, 01:29 PM   #25
laynlo15
I'm pretty sure they do make the Katech. Could be wrong.
Old 07-04-2018, 03:57 PM   #26
TJay74
When I asked the shop that did my PC this was their exact words as well, I wont see any gains from a 103mm TB since I am on a blow thru system. They said unless I am going for over 1000hp or pure HP only goals that it is wasted money for the level of power I am looking for at this time.
Old 07-04-2018, 05:35 PM   #27
Turbo_RORO
Turbo_RORO's Avatar
Drives: Camaro 17 SS
Wink
Wnta1SS is completely correct. Trust us on this one...
Turbo_RORO is offline   Reply With Quote
