#15 |
![]() Drives: 2016 Camaro SS Join Date: Jul 2016
I believe that Centri superchargers have IAT sensors at pre-charger location.
#16 |
My friend having Magnuson and me having Whipple had rolling race yesterday. Maggi, 15psi , no meth vs Whipple 17psi, no meth. I won, but not far. From 60mi to 175mi. iATs are the same. From 130* to 183* . yesterday it was quite humid and hot. The both cars are around 700 hp.
#17 |
![]() Drives: Camaro 17 SS Join Date: Jan 2017
#18 | |
![]() ![]() Drives: 16' Camaro E-Force SS Join Date: Jul 2016
Abort abort abort!
Leo
2016 e-Force 2SS Instagram @cleoent |
#19 |
![]() ![]() Drives: 2017 50th Anniversary 2SS Join Date: Sep 2016
Exactly what I was thinking. How much timing is pulled at that temp? Im at 12 degrees advance at 6k rpm with IAT's in the 120's so that I don't get any KR @ 10lbs of boost.
#20 |
![]() Drives: 16' Camaro 2SS Join Date: Sep 2015
Just got some fresh new data: 4500 DA, 93 degrees ambient.
Non-iced starting: 101, ending IAT (1/4 mile) 124 Iced Starting: 65, ending IAT (1/4 mile) 93 Magnuson 15.5 psi, Cordes Expansion Tank, larger lines re-routed, upgraded water pump and Stage 2 Magnuson Bricks. Pro Meth injection post TB. Huge shoutout to Toohighonpsi for letting me purchase the new bricks and helping with the line re-routing.
@DeathWatchCamaro on Insta
993whp Magnuson 2.3R 9.5 @ 145, Magnuson 2300, Full Weight 2SS, 17’s (810whp) |
#21 | |
2016 loaded 2SS
Drives: Maverick X3 Turbo R Join Date: Feb 2015
#22 |
![]() ![]() ![]() Drives: 2017 Camaro 2SS Nightfall Gray vert Join Date: Jan 2018
Out at Camaro fest, it sounds like the Laynlo Maggie is sure running fine in high heat and high DA with no heat problems...with all stock internals. . .I know he beat a cammed whipple too. I think the heat info might be dated. Cant wait to see the full rundown from Camarofest.
More than likely, every setup will have a little worse performance in 100 degree temps.
Magnuson Heartbeat SC - Tuned by JRE Racing 776whp/745wtq (12psi) 2018 Corvette Z06 vert- Black To be tuned by JRE Racing TBD performance Last edited by Drsagacity; 07-14-2018 at 08:29 PM. |
#23 |
As far as I know there is an ambient air sensor that is located passenger side lower radiator in one of the shields. The actual IAT is in the MAF housing. That means on a centri it is post intercooler pre-throttle body.
#24 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '18 Zl1. '18 GT350. Join Date: Dec 2016
Shit, that's nothing. Mine goes up to 170 at idle. Of course, it's 100 degrees here so. haha. Under WOT, it drops to the high 90's.
There's only 2 people I trust. 1 of them is me, the other's not you. 2018 Zl1. 1199 RWHP/931 TQ.
#25 |
Drives: 2016 2SS Camaro Join Date: Sep 2016
