Old 06-23-2018, 07:19 AM   #15
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 19 WRX
Breaker bar to start regardless of lug nut torque spec (even the 89 ft*lb lug nuts on her Subie get broken by hand). Then I'll use the Milwaukee 18v on low speed to finish removing the nuts. I have a feeling that high speed nut removal/installation tends to either polish or wear additional clearance in the threads making them less resistant to initial loosening over many cycles.
On installation I'll start the nuts by hand a couple of turns and use the Mil on low speed (which is also low power) to run the nuts down to what ends up being "not quite snug". Ratchet and torque wrench from there (2 or 3 stages with the torque wrench). Recheck the last stage torque on the first couple of nuts in the pattern.
One tends to get a lot fussy about this after experiencing stud breakage in a 1+g corner, and chances are each of us removes and replaces each wheel more times in a single full season than most average-owners put their daily-drivers through before they're scrapped.
Norm
Old 06-24-2018, 11:28 PM   #16
Roostie
all it takes is cash
Roostie's Avatar
Drives: 2018 LS V6 1LE; 2000 BMW 540i 6MT
Thanks for all the responses, that's great info.
Roostie is offline   Reply With Quote
Old 06-27-2018, 04:15 PM   #17
Slate993tt
Slate993tt's Avatar
Drives: 2018 Silver ZL1 1LE
Norm, You and I have like minds. I do the same process as you.
Chad
Slate993tt is offline   Reply With Quote
