Old 06-20-2018, 05:48 PM   #15
hawk02
Coupe Newbie
hawk02's Avatar
Originally Posted by jbp8653 View Post
Just FYI..........Dealership where I service my ZL1 ( I happen to work there ) told me bulletin on using different oil was just on Corvettes. Are they behind times? Was there a different one that came out that they haven't seen that includes Camaro? Just asking. They are going to put the new stuff in anyway.
This should answer the question as to which engines are being upgraded to the new Mobil 1 ESP 0W-40.
See the section circled in red. It's from page 2 of the new oil's FAQ sheet.
Old 06-20-2018, 09:11 PM   #16
Trackman
Trackman's Avatar
Drives: 67RS Camaro ,Black 2013 ZL1
In the past Corvette, Camaro and Cadillac all had different oil specs for each vehicle even though they have the same engines. This change clears up all the confusion between cars. Now they align together with the same oil spec moving forward.
Trackman is offline   Reply With Quote
Old 06-20-2018, 09:18 PM   #17
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
nice post with accurate information! This is a great resource for folks overthinking the fluid recommendations!
Old 06-20-2018, 11:04 PM   #18
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
Appreciate it, means a lot coming from you.
Old 06-20-2018, 11:07 PM   #19
Can'tHave2MuchHP
Drives: Fast
I added this picture to the original post, think it will be helpful to have that info upfront.
Old 06-21-2018, 12:00 AM   #20
ZL14ME
Drives: 2018 ZL1 M6
No disrespect intended.
Lifting on aluminum components can and has damaged unibody. Also documented on these forums and in owners manual.
I would double check your door gaps and operation.
Oil change techs making up their own rules is precisely the reason that I will be the only one changing my oil. My dealer offers double (4) included initial maintenance visits.
+1...
Lifting from the wrong lift points is just that...wrong. While this is informative regarding oil changes and oil...owners need to know this is the wrong way to lift there investments per the manufacture. That way when they see something like this happening it can be corrected or prevented before damage occurs. I realize the OP just wants this to be an oil change thread but from my humble perspective it’s related. Too many forum users went in for an oil change, got a ZL1 lifted like this and came home with damage.
I come and go in peace.
ZL14ME is offline   Reply With Quote
Old 06-21-2018, 12:53 AM   #21
hawk02
Coupe Newbie
hawk02's Avatar
Good idea.
Old 06-21-2018, 03:28 AM   #22
hashtag
hashtag's Avatar
Drives: 2018 ZL1 A10/2018 GT350R #JR603
You have the cleanest exhaust I’ve ever seen for a 1500 mile car. Very appreciative of the post and will be switching over oil this week.
2018GT350R+2018 ZL1 "Red Hot" A10 w/ PDR, Nav, Carbon Fiber Hood insert, Carbon Fiber Dash Insert, Carbon Fiber Fuel Dior & Sun Roof. T/M T-Body, Roto Fab & Borla S Type.
hashtag is offline   Reply With Quote
Old 06-21-2018, 08:04 AM   #23
Koldunic
Drives: 2018 ZL1 1LE
Thank you for the info!
Koldunic is offline   Reply With Quote
Old 06-21-2018, 10:43 AM   #24
closs2sx
closs2sx's Avatar
Drives: 1970 chevelle
what about oil filters like
upf64r
upf48r
or the mobil 1 m1-113a
On Order 2018 ZL1 1LE Garnet Red Tint Coat Metallic
MY Car
2015 Z06 Z07
Daytona Sunrise Orange Metallic
Dads Car
2013 ZL1 vin 963
Crystal Red Tint Coat/Black Wheels
Exposed Carbon Fiber Insert
6 Spd Manual
closs2sx is offline   Reply With Quote
Old 06-21-2018, 10:59 AM   #25
greaser2
greaser2's Avatar
Drives: 2017 A10 ZL1 KG
I was there when they were lifting it up and brought the proper pinch weld adapters etc. but my tech said he'd rather lift by the areas he did than the pinch welds which can tend to get wobbly. I double checked with him and he was certain. He changes oil on Camaros 5-10 times a day. He knows what he's doing. It's also well documented that if you're lifting from all 4 points at once, it's safe to do what we did.
He was certainly wrong. Several have reported bent aluminum components doing what he did.
greaser2 is offline   Reply With Quote
Old 06-21-2018, 11:03 AM   #26
Can'tHave2MuchHP
Drives: Fast
upf64r
upf48r
There are many oil options, countless really. I only included OEM used oils. Obviously there are advantages and disadvantages of many different brands/weights etc. OEM 5w30, 15w50 for track requests, and the 0w40 ESP that replaces both for certain engines.
Old 06-21-2018, 11:05 AM   #27
Tim202
OK, coming from a guy who is a mechanical dumbarse......If I get this oil put into the car, and on a track day the engine goes 'poof', will it still be covered? I ask because a dealer/GM could say that I didn't put the recommended oil that the Owners Manual/HP Supplement said to put in, so they will not cover it.
Tim202 is offline   Reply With Quote
Old 06-22-2018, 01:27 PM   #28
Can'tHave2MuchHP
Drives: Fast
Guess I'll jump in, first off, the chances of GM voiding a warranty due to oil are slim. Secondly, this is an OEM Recommended Dealer Installed oil that SAYS it's for Street and Track use on LT1, LT4, and LTA engines (The LT5 requires a different oil when tracking). So really no way you can lose here IMO.
