#15 |
![]() ![]() ![]() ![]() Drives: 1970 chevelle Join Date: Aug 2011
set the park brake put the car in neutral and try to turn it over by hand
On Order 2018 ZL1 1LE Garnet Red Tint Coat Metallic
MY Car 2015 Z06 Z07 Daytona Sunrise Orange Metallic Dads Car 2013 ZL1 vin 963 Crystal Red Tint Coat/Black Wheels Exposed Carbon Fiber Insert 6 Spd Manual |
#16 | |
![]() Drives: 2018 ZL1 Join Date: Sep 2016
#17 |
![]() ![]() Drives: ZL1/335i Join Date: Apr 2014
Sounds like either a severely discharged battery (alternator issue, etc.), or a mechanically seized engine. Being that you just had major work done (engine came out, right???), it could be anything.
I’d do what others mentioned, and try to crank it over by hand. If it’s a manual trans, make sure it’s in neutral. If it feels normal and free, then it’s probably an electrical thing. If not, something major failed or came loose inside the engine. With 100 miles since being torn down, that’s a likely scenario. |
#18 |
a multimeter and a load tester will rule out battery real fast. I hope for your sake it is something simple but i'm guessing motor but hard to tell from here.
#19 |
Thank you for all the info so, I'll keep you updated as I know things.
#20 |
Sarcasm loading --------
Do you have a wideband setup on it?
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD |
#21 |
