Old 06-18-2018, 04:22 PM   #15
parbreak
Drives: 2017 50th Camaro SS
Parbreak, great info. Do you recall your rwhp for that run?
546 RWHP. 541 TQ
Dyno jet
Run at Capitol Raceway in MD
50th Anniversary Edition |Borla Atak and 60606 mid pipes| Kooks 1 7/8" | ProCharger Stage II |305/45/17 DRs | Circle D 3500 stall | LT4 fueling | Custom made Lowside Aux Pump | Alky Control Meth | DSX E85
parbreak is offline   Reply With Quote
Old 06-18-2018, 04:23 PM   #16
parbreak
Thinking slicks will get me deeeeeep 11s. Best 60 ft was 2.0
Old 06-18-2018, 04:31 PM   #17
Drsagacity
Drsagacity's Avatar
Actually, that’s a really good comparison. Laynlo running 540whp with just Maggie and tires was in 10’s, but he was also trapping at 129.8.
I had another thread trying to understand the difference between trap speed with different tires...basically got crickets.
776whp/745wtq (12psi)
2018 Corvette Z06 vert- Black
To be tuned by JRE Racing
TBD performance
Old 06-18-2018, 06:42 PM   #18
wnta1ss
Drives: 2017 Camaro 1SS
Wow, if you ran an 11.3 with a 2.0 short, then I think that you could have a chance at making the 10s with slicks on the car.
Old 06-18-2018, 09:04 PM   #19
DapperDan
DapperDan's Avatar
Drives: 2017 1SS A8 Nightfall Gray
546 RWHP. 541 TQ
Dyno jet
Right or Left lane?
DapperDan is offline   Reply With Quote
Old 06-18-2018, 09:29 PM   #20
parbreak
Originally Posted by DapperDan View Post
Right or Left lane?
11.3 pass was in right lane.
Old 06-20-2018, 08:13 AM   #21
Drsagacity
Drsagacity's Avatar
Originally Posted by toohighpsi View Post
Attachment 941431
This is what we ran with stock torque converter, stock engine, stock exhaust manifolds, and catalysts.
Video here:
https://youtu.be/bdJz6CJALtU
I don't think that this car would have gone any faster with a converter, the stock converter is pretty well suited to the 8 speed trans with a PD at this level. In the video you can hear the tires at their limit through first gear and in reality pulling a bit of timing at launch might have resulted in a slightly better pass.
We have gone as fast as 9.1@ 153 with the stock converter and 8 speed trans, but launching 1st gear at that level requires a well prepped track. I have just got home from Power Tour and none of the tracks could support a 1st gear launch with the really low first gear of the A8. (no real prep and lots of street tires running on the track)
With that in mind - the solution was to launch in second which resulted in:
Attachment 941432
Our 60' increased from a "prepped track" value of 1.39 to 1.52, but still a pretty respectable ET and MPH. Unfortunately after about 8-9 passes we began to notice some transmission problems, I think the transmission is still OK, but I believe that we have failed the lockup function in the stock converter. At least that is what the data looks like.
At this point I have no plans to continue to run the A8, we will be switching to a TH400 with a higher stall converter which I believe will ultimately be a faster solution in this car. Once the A8 is at this power level I don't think there is a good answer - it is near it's limit and shifts to much costing you precious time with every shift. Each shift requires 0.25 sec with ignition timing at about 0 - that's over a full second of a low 9 sec pass with heavily reduces power. The TH400 will happily shift under full power.
SO - with a PD you're in good shape with the stock converter up to the point that the transmission can't handle it anymore. I'm not saying that you won't be slightly faster with a higher stall, but as the car get faster it's less necessary.
The centri gets benefit from the converter, higher RPM at the line will allow it to get higher boost and further into is power range for better 60's.
Not sure if this exactly answers your question, but it summarizes my A8 learning to date...
Ok. Off topic for this thread, but I need to know, which wheel/tire setup were you running in that pass? Do you recall what Hp you needed to dip into the 9’s? I assume you were near 700rwhp.
TBD performance
Old 07-22-2018, 07:56 AM   #22
wnta1ss
Now I have some first-hand info on the subject you are questioning. I tried a base (for stock motor) centrifugal blower kit, an ECS/Paxton, with a stock torque converter on my 2017 SS with A8. Had a drag pack with radial tires, ptb, driveshaft loop, smaller battery. Quarter mile time was 10.92@125 with a 1.63 short. Temp on a car display was about 82 as I recall before making this run.
