#15 |
![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS Join Date: Aug 2016
Very nice power bump, happy for you. Just wish my ECS had worked like that.
Some info for those who don't know, this kit is actually a Vortech, but with a badge saying 'ECS' instead of 'Vortech' on the supercharger. Something to look out for mikey1107, if you are going to run your car on a road course, I'd suggest getting the base SS track-pack brake deflector kit to catch a little air under the car. Reason being, this kit compromises the passenger-side brake cooling duct in 2 ways: it blocks a good portion of it with the intercooler, and the brake duct is cut substantially for clearance. Since you did not do the install yourself, I'm guessing you might not have been aware of this, and wanted to mention it in case it's relevant to your use of the car. |
#16 | |
![]() Drives: 2017 SS Join Date: Sep 2011
I thoroughly read the install instructions and I was aware of it but it’s good info to have out there. My car is primarily a daily driver and I do not get many opportunities to track it but when I do I’ll use the track brake deflectors as you mentioned. ECS may have to chime in on this but I thought I read a post that they said they make a couple of changes to the Vortech kit but overall it was Vortech. Thanks! Sent from my iPhone using Tapatalk
2017 SW SS
#17 |
Do you know what size pulley you have on it? If your car is bone stock I bet you are getting more than 8psi. Get yourself a catch can to vent that crank a little better. Great numbers man!
#18 | |
The Procharger kit completely removed the drivers side ducting. I'm not running that side radiator so I probably fashion something for the brakes, I was thinking of a cool air induction setup for the air filter
#19 |
I left my driver side cooler on and actually moved it closer to the front. You took yours off completely?
#20 |
Drives: 2016 2SS Camaro Join Date: Sep 2016
His baseline numbers were practically the same as mine on our Dynojet. My A8 only made 385 stock. Nice gains! I made about 8psi when I first installed the kit.
#21 | |
#22 | |
On the pulley subject, I'm also wondering what pulleys yours was supplied with. Recently I found my invoice and it said 8psi 30 tooth supercharger, but my kit came with a 32t installed on the supercharger. |
#23 |
ECS supercharger installed
On the pulley subject, I'm also wondering what pulleys yours was supplied with. Recently I found my invoice and it said 8psi 30 tooth supercharger, but my kit came with a 32t installed on the supercharger.[/QUOTE]
I just counted, mine has 32 teeth. Sent from my iPhone using Tapatalk
2017 SW SS
#24 |
Yep, I figure if anything I'd go to a better center unit and / or Mishimoto passenger side. I really would like to get rid of the oil to water cooler and run something like the Mishimoto oil to air setup, but I got a big honking intercooler in the way. This is literally my first car that the entire front is taken up with heat exchangers or duct for heat exchangers.
#25 |
![]() Drives: 2016 1SS A8 Camaro with MRC and NPP Join Date: Oct 2016
Congrats !!! .... Your results were very similar to mine (398rwhp/389tq stock #s and with ECS boost 550rwhp/510tq) on a 100% stock A8 SS so now that more of these kits are making it out its showing some nice consistency in results.
So far in its current state I have liked and enjoyed this kit (the price is right I am having a few things on this kit changed soon to make way for future plans and adding a few other items so we shall see how that goes .... hopefully we see the results at the track were I want them the most ![]() -Jon
2016 HB Camaro 1SS A8 with MRC and NPP 398rwhp/389tq stock #s(11.84 @ 117 DR only, ECS boost 550rwhp/510tq (dynapack #s) , same boost + AEM water/meth + ARH Headers/mids 600 rwhp+ (dynojet #s) TTP)10.8 @ 129.
2020 Ford Explorer 2003 SVT Cobra Coupe (just your average KB Terminator Cobra). 2013 Focus ST (e30 Tuned). 2004 Dodge 3500 Cummins Dually 6 spd manual (tow rig). 1997 Jeep Cherokee (Lifted and Locked XJ off-road rig). |
#26 | |
If you buy the Vortech only version of this kit it is not the same exact kit as the ECS setup. However, the version of the kit with the larger Paxton HU (ie 2200R and etc) will have much more ECS involvement from what I understand but they have not finalized this setup yet. -Jon
#27 | |
To help those out looking at superchargers here is a list of head-units and their ratings. Vortech V3-SI 3.6 ratio, Flow 1150cfm, Max HP 775 Procharger P1SC 4.10 ratio, Flow 1200cfm, Max HP 825 Procharger P1x 4.10 ratio, Flow 1275cfm, Max HP 875 Procharger D1SC 4.10 ratio, Flow 1400cfm, Max HP 925 Paxton Novi 1500, 3.61 ratio, Flow 1400cfm, Max HP 950 Procharger D1X, 4.10 ratio, Flow 1500cfm, Max HP 1000
2016 NFG SS A8/Whipple 2.9/Fuel System/Flex Fuel Last edited by KingLT1; 06-10-2018 at 10:05 AM. |
#28 | |
).Basically what I'm saying is that in the end of the day any of those head units listed are capable of toasting a stock gen V LT1 bottom end on full tilt so I wouldn't get too caught up on the size of the super charger on a mostly stock car ... Now if we are talking a stroked 416,427 or nasty 376 build then yes you would want as much flow potential as possible. And wnta1ss I have mentioned before I was sorry to hear about your issues with the ECS kit but I have to believe your issue is tuning (this kit can be hard to tune for some shops because of the location of the sensor in the Intercooler especially if your car is an A8 makes the tuning even more difficult but some shops now have this figured out or just use speed density but its not optimal). Also now we have more results from this kit that are almost exactly like my results were in the beginning so I have a hard time believing that your results are the "norm" for this setup. But either way I feel for you that the results weren't as hoped in your situation/setup and I wish you luck in the future! Just a thought on that. -Jon
2020 Ford Explorer 2003 SVT Cobra Coupe (just your average KB Terminator Cobra). 2013 Focus ST (e30 Tuned). 2004 Dodge 3500 Cummins Dually 6 spd manual (tow rig). 1997 Jeep Cherokee (Lifted and Locked XJ off-road rig). Last edited by RageWorx; 06-10-2018 at 10:35 AM. |
