Old 05-30-2018, 08:28 AM   #15
PRAY
PRAY's Avatar
Drives: 2016 2SS
Originally Posted by Daniel20162ss View Post
Any work on a “stage 3” cam on a projarged car yet? Also, do you plan to do the heads and a intake? Wondering what diff these things would make power/tq wise
I haven't even considered a STG 3 yet. I don't see the need. I think on stock tires with 15lbs of boost or so all dialed in this cam will make 1K rw without much issue.
Old 05-30-2018, 08:29 AM   #16
PRAY
PRAY's Avatar
Drives: 2016 2SS
Wow, sick numbers. Should run 9.70s in good weather. My car slowed down with a 15 degree temp change and DA was 2500. Bad weather is hear so no more good times for a while. That car should be wicked.
I am hoping for 9.30's in good weather all dialed in. We will see how it does in bad weather in a week or two. We are putting a DS and axles in it soon. I think a re-stall will be in order as well to get down into the 1.3 60ft's. I did go a best of 1.42 last time out and pulled the tires.
Old 05-30-2018, 01:02 PM   #17
oldman
Drives: SS 6 speed of course
I have the smaller cam, but do have heads and a MSD with 103 mm TB. For just plain looks I'm saving my sheckels and maybe one day I got a Goetz intake. I do like the idea of going for 8 addition injectors on either the MSD or the Goetz and a piggyback computer that starts at 1 PSI and goes up from there. I'd probably put an Air /Fuel trigger and cut power to the coil packs if the car ever runs lean. It would be a pretty simple logic circuit.
If boost = 3 PSI or above, If Lambda = .95 or above, and if air flow (via either second MAF or a tap on the existing MAF = 400 CFM or higher), then shut off spark. This should also stop any false triggers that may occur during normal driving or auto X. Also would program in something like if boost ever goes to 14 lbs = shut off spark. Just in case.
Old 05-30-2018, 08:17 PM   #18
PRAY
PRAY's Avatar
Drives: 2016 2SS
I am going to go out on a limb and say ported heads and IM/TB at the same boost level would be close to 50rw. But that's just me.
Old 06-04-2018, 02:02 PM   #19
ProCharger
Drives: Many C7's
Great results man! Glad to see you are enjoying that P1X.
ProCharger is offline   Reply With Quote
Old 06-04-2018, 03:08 PM   #20
PRAY
PRAY's Avatar
Drives: 2016 2SS
Thanks. Should be hitting the track Saturday night. Weather will be terrible but the track is supposed to be prepped. We will see. If I can knock out a 9.5 in the heat I will be pretty happy.
Old 06-12-2018, 12:08 PM   #21
markblackwell
Drives: 2015 991 Turbo S, 2016 Camaro
What if any suspension mods does this car have?
markblackwell is offline   Reply With Quote
Old 06-12-2018, 12:10 PM   #22
PRAY
PRAY's Avatar
Drives: 2016 2SS
None.
Old 06-13-2018, 12:59 PM   #23
markblackwell
None.
Thank you and good luck on Saturday hope you bust out a 9.5x
Old 06-20-2018, 10:17 AM   #24
hitmix300
2016 loaded 2SS
hitmix300's Avatar
Drives: Maverick X3 Turbo R
where is the timeslip bro
the suspense is killin me
hitmix300 is offline   Reply With Quote
Old 06-20-2018, 10:37 AM   #25
PRAY
PRAY's Avatar
Drives: 2016 2SS
First pass in +3,050 DA. Customer let off after the 1/8. Still plenty of tuning to do. I made another post in here about it.
https://www.camaro6.com/forums/showthread.php?t=531216
Old 07-20-2018, 05:24 AM   #26
mark moseley
Drives: 2016 2ss camaro
We still have a little bit of work getting it dialed in, but this thing is moving pretty good! Thanks Pray Performance!
https://www.facebook.com/1320Videos/videos/10156649252357112/
mark moseley is offline   Reply With Quote
Old 07-20-2018, 01:09 PM   #27
oldman
The guy just keeps getting faster..
Old 07-20-2018, 01:17 PM   #28
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Solid work, folks!
JDP Sales is offline   Reply With Quote
