#15 |
![]() Drives: 2017 SS 1LE Join Date: Jun 2011
#16 | |
no real power goals, just wanna bolt on a super charger with out having to throw money into fuel, injectors, cam, pistons, etc... everything ive read says i should be able to do that safely on 7lbs and make 150-170 extra |
#17 |
![]() Drives: 2ss Join Date: Jan 2018
If that's all you are wanting then check out the website I provided you via DM, you could do a stage II tuner kit with the upgraded p1x head unit, race bypass valve, larger intercooler, extended warranty for around what they are quoting you for that base system and "shipping." You could even stay with the HO style kit without the race bypass or larger intercooler and come out way ahead than what they are quoting you for that kit up there, and I didn't pay a dime for shipping.
#18 | |
#19 |
![]() Drives: 2016 SS Hyper Blue Join Date: May 2017
I stand corrected with the exhaust so there is only 3 items that are standard with 1le and ss
#20 | |
If you are for sure having someone else install it and plan to tune it then stick with a tuner kit so the extra 300 or so bucks for the complete kit can be saved to put towards paying your tuner, if you decide to do the work yourself and throw a generic tune on it and get it tuned later get the complete kit for a few hundred bucks more. Edit : It does say in the booklet that for 2017 you get a tune certificate in your kit that you send in with your ECU to get your tune programmed. Last edited by Inkedmongo; 05-26-2018 at 10:47 AM. |
#21 |
![]() Drives: 2017 50th Camaro SS Join Date: Jul 2016
My son and I did the install in less than 6 hours.
50th Anniversary Edition |Borla Atak and 60606 mid pipes| Kooks 1 7/8" | ProCharger Stage II |305/45/17 DRs | Circle D 3500 stall | LT4 fueling | Custom made Lowside Aux Pump | Alky Control Meth | DSX E85
#22 | |
#23 |
P1x seems to be worth the extra cash, faster boost and cooler boost, and less HP to make the boost in small amounts. But the price difference is negligible.
#24 |
#25 |
![]() Drives: 2017 1SS A8 Nightfall Gray Join Date: Feb 2017
As of last month you would have to send it to procharger for a 2017
#26 |
#27 | |
Put some heat on the bolt when removing it for 30 seconds to a minute , big breaker bar and something stout to hold flywheel from turning I used a vacuum kit to refill the coolant to avoid air in the system but thats just me being picky. You may have to shim the bumper out a hair with washers so the intercooler doesnt hit I think you can read the instructions on Phastek website
#28 |
I ask Procharger last month and you still had to send it so unless something has changed in a month you will still need to send it
