#15 |
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
Yes, JMS comes with it's own wire harness, you only spice 1 wire at the FPCM.
Plugs in at the gas pedal. Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com |
#16 |
![]() Drives: 16’ 2SS A8 HBM Procharged Join Date: Jun 2017
I was very pleased to see the results of adding this to my car. Ted suggested I get one, and at first I debated on do I REALLY need this thing? Like the car didn’t actually run out of fuel, but it was clearing dropping low side pressure at WOT in the higher RPMS. But since he has never steered me wrong before, I went with it.
All I can say is wow. Comparing the data logs with the same tune, without the booster it dipped to low 40 PSI. With the booster it never dropped below 70PSI. This thing is the real deal.
16' 2SS A8 Hyperblue | P1SC-1, Race IC | JMS fuel pump voltage booster | Jannetty custom tune | Elite E2-X catch can | M017 Wheels
#17 | |
#18 |
This needs a bump
#19 | |
![]() Drives: 2018 Camaro ZL1 Join Date: Feb 2018
Also, assuming it does work, how high should I regulate the voltage to at WOT if I'm trying to get to 800whp? |
#20 | |
We have never installed an MSD on a Gen6 Camaro so I can not comment sorry. Ted.
#21 |
Got it. Thank you.
#22 |
![]() Drives: 17 camaro ss Join Date: Mar 2018
*Subscribed*
#23 |
![]() Drives: 2017 Camaro SS 2ss Nightfall Gray Join Date: Aug 2018
Would I need to retune my car if I installed this? I don't plan on upping the boost but if it will make the car safer why not. Also how difficult is the install?
ACS front spoiler, rear spoiler, side skirts and rock guards (gloss black). Real carbon fiber dash insert, real carbon fiber gear bezel, GM dark tail lights, Gm black badges(Emblems and ss)
Powder-coated gloss black factory 5 spoke split wheels Roto fab Biggulp CAI Full paint correction with cquartz finest ceramic coating Whipple 2.9 ARH Long tube headers with High flow cats 1le sway bars F&R BMR Upper and lower trailing arms Hurst short throw shifter |
#24 | |
Yes you need to make some changes in the FSCM to allow the JMS to work as intended. IMHO, If you want "safer" then you need to upgrade the entire fuel system to LT4 and add the JMS booster.
#25 | |
Typically after we get everything we can out of the FPCM the JMS is just plug and play instant improvement of fuel pressure. Ted.
#26 | |
https://www.camaro6.com/forums/showp...8&postcount=22
#27 |
![]() ![]() Drives: 2018 HBM ZLE Join Date: Aug 2017
How would a dsx low side system compare to this? I understand price difference but just wondering if this would be a better route for me
#28 | |
Ted.
