Old 05-10-2018, 11:39 AM   #15
rjacobs
Drives: none
Originally Posted by ZL1 1LE View Post
What color is the RPM?
black
rjacobs is offline   Reply With Quote
Old 05-10-2018, 12:31 PM   #16
Scootabill
Scootabill's Avatar
Drives: 2018 Mosaic Black Metallic ZL1 10AT
Originally Posted by rjacobs View Post
Gates makes the RPM and the Green, and a few others.
I have HEARD the RPM is the better belt for our purposes as the Green is VERY stiff because they are truck belts i.e. like big ass diesel trucks.
BUT the green belts can be had for like 30-35 bucks where as the RPM belts are ~2x as expensive(50-60).
As far as part numbers, on a fully stock LT4 the Gates numbers are K080852HD(green) or K080852RPM.
There is actually a TSB out for the Corvette Z06 that has the dealer install the green belt.
According to Gates' website the Camaro belt # is K080828RPM. The K080852RPM is listed for the Corvette.
Scootabill is offline   Reply With Quote
Old 05-10-2018, 12:52 PM   #17
rjacobs
Drives: none
Good call.
I was going off another thread for LT4 motors and didnt catch it was on Corvette Forum.
Whats the difference between Corvette and Camaro LT4 motors?
Accessory drive routing? Tensioner setup?
Edit: a K080828HD(green) belt doesnt seem to exist(google fails to yield any results), yet there are guys running the green belts on these cars... I am simply going by the difference on the Corvette belts being RPM or HD subfixes while the main number stays the same.
Old 05-10-2018, 01:15 PM   #18
Scootabill
Scootabill's Avatar
Good call.
From what I can see the 'Vette belt is just over 2" longer.
Old 05-10-2018, 02:40 PM   #19
ZL1 1LE
@zle_blackwing
ZL1 1LE's Avatar
Drives: 2018 ZL1 1LE
black
Originally Posted by DangerZL1 View Post
I found a pic of the RPM which shows it as black and about $54. Just to check I pulled up a pic of the HD which is definitely green.
Thanks guys, I have an aversion to those green ones.
Old 05-10-2018, 04:54 PM   #20
VAZL1
VAZL1's Avatar
Drives: 17 ZL1
Why is that?
2017 ZL1 Coupe M6, Red Hot
Mods; AFE Pro 5R CAI, Kong Ported Blower and Snout, NW 103 TB, Griptech 2.31 Upper, Kooks 2",JMS Voltage Booster, Flex Fuel, Mighty Mouse CC,Jannetty Racing Tune, 680 rwhp
VAZL1 is offline   Reply With Quote
Old 05-10-2018, 06:57 PM   #21
rjacobs
Drives: none
yea thats obvious...
I was talking about the physical motor in the Z06 vs. the ZL1 which would make the vette require the longer belt.
Old 05-10-2018, 07:00 PM   #22
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
Originally Posted by VAZL1 View Post
Why is that?
More than likely because the Green HD belts are meant for diesel trucks or something like that and their RPM series or whatever the name is, is stickier and meant for supercharged applications. The Green belts are harder and not as sticky. But some have had durability issues with the RPM belts...
Old 05-10-2018, 08:44 PM   #23
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
just ordered GM 19353135 as a backup replacement
Old 05-10-2018, 08:48 PM   #24
waterman
waterman's Avatar
Drives: Grandad's C2 L89
Subscribed for Gates and GM part #s.
Thank you gentlemen.
2018 ZL1 1LE sw/PDR
Old 05-10-2018, 09:05 PM   #25
17CamaroZL1
Life's Short, Live Fast!
17CamaroZL1's Avatar
Originally Posted by SJFGTO View Post
Good point. I was very careful to avoid anything like that, although it was the very first thing that came to my mind when it happened.
The other thing I thought of was that I had taken the rain baffle out from beneath the hood. It is a crazy thought, but I wonder if that created enough turbulence or air flow in the wrong spot to impact the integrity or positioning of the belts. Just a shot in the dark.
First I've heard of any broken belts. I don't think the rain diverter would cause it, as the car was designed to run without it, and I've had mine off for most of the car's life, with no issues.
12/26/2016 Ordered!
2/8/2017 Built!!
3/2/2017 Brought Home!!!
Old 05-10-2018, 09:11 PM   #26
travislambert
Drives: '17 ZL1
Here's my spare:
travislambert is offline   Reply With Quote
Old 05-10-2018, 10:04 PM   #27
ZL1 1LE
@zle_blackwing
ZL1 1LE's Avatar
Why is that?
Just aesthetics. It screams aftermarket, not stock.
Old 05-11-2018, 09:43 AM   #28
BMWM.D.
BMWM.D.'s Avatar
Drives: ZL1/335i
Originally Posted by travislambert View Post
Here's my spare:
Attachment 934820
That’s what I have on my car.
BMWM.D. is offline   Reply With Quote
