Old 05-03-2018, 12:57 PM   #15
Drsagacity
Drsagacity's Avatar
Originally Posted by hitmix300 View Post
sucks that currently the positive displacement guys are limited on fuel; i mean centri and turbo guys have endless options/combinations for intake manifolds & aux fueling.
i wonder if the new intake manifold for the zr1 will be backwards compatible with the lt4/lt1 motors so we can run PD blowers with 8 additional injectors. I suppose the maggies wont bolt up to that manifold tho.
the real question is if we can program the ecm from the zr1 to our cars to use the factory pcm for the additional fueling
***CROSSES FINGERS***
/rant
I am not sure what this means. The HPFP is going to start hitting limits regardless of blower. When it starts dropping you will need to upgrade it.
I started to look into adding an aux pump, but was advised against it, so I took a different path.
Are you saying you would run stock LT1 fuel system to 650whp?
776whp/745wtq (12psi)
2018 Corvette Z06 vert- Black
To be tuned by JRE Racing
TBD performance
Old 05-03-2018, 01:44 PM   #16
Drsagacity
Drsagacity's Avatar
Damn...let's add e85, front crank seal and an oil vent of some sort...
TBD performance
Old 05-25-2018, 08:07 PM   #17
Drsagacity
Drsagacity's Avatar
Ok. Completed the order of parts today. Thanks to Ted Jannetty on the assist.
We are essentially going to finish the install with the items to complete the Jannetty Super Street Brawler package:
ZL1 intank pump
LT4 fuel injectors
LT4 hpfp
Voltage booster
E85 sensor
Front crank seal
Gauges afr and boost
Rough idle cam kit
Kooks LT Headers with high flow cats
Forged drop in pistons
We decided that running on e85, we will stay with the 85mm pulley which will put me at bout 9psi.
In all, I would expect to end up in the 700rwhp range through the a8.
Parts should arrive in a couple weeks and then we will probably take a couple weeks to install.
TBD performance
Old 05-25-2018, 08:52 PM   #18
laynlo15
Drives: 2022 Lt1 A10
OMG he's at it again. Ha
Old 05-25-2018, 10:18 PM   #19
Joe's_cool_1le
Drives: Black 2017 Camaro SS 1LE
Saw this on the site. You get this too?
https://jannettyracing.com/collectio...re-fuel-pump-1
ZL1 intank pump
LT4 fuel injectors
LT4 hpfp
Voltage booster
E85 sensor
Front crank seal
Rough idle cam kit
2017 1LE SS Black - Mods - Forged - lowered compression - BTR custom Cam - Whipple, 3.500 upper and 8.0 lower pulley, Roto-Fab, 1 7/8 Kooks headers, off road pipes, & 3" Kooks full exhaust. LT4 fuel system, with Alky single nozzle running 100% meth. (not installed yet) DSX Tuning flex fuel and DSX tuning Aux pump
Joe's_cool_1le is offline   Reply With Quote
Old 05-25-2018, 11:12 PM   #20
Drsagacity
Drsagacity's Avatar
Now the undercover project just got real. I had to start my prep work and start dropping hints, watching videos with the kids, “wouldn’t it be cool if our car sounded like this?”...”There is nothing better than the lope of a cam.”
Phone call with the guys (with wife in earshot, “yeah, I was thinking about dragging it out, but figure out what it will cost if we just do it all now.”...
Subsequent discussion with the wife, “talking to the guys about the work, it really makes sense to do more than I had planned and get the car done now...it will be easier to just get it done and it will make the car much safer...plus, I really want the sound of that cam loping.”
Message conveyed...prep work done...now it’s time.
Next weekend, we may get to run the car in some roll racing event, but really, in a couple months, I can’t wait to get out on a test-n-tune night and see how she does when the transformation is complete.
I would guess on tires I would trap in the 126-127mph range now (Laynlo trapped at 129.9 at this point)...I should be a bit slower since my Vert is heavier. Once done, I would expect a trap in the 137-138 range.
It will certainly be one of the baddest cars around... for cruising to the golf course with the top down.
TBD performance
Old 05-25-2018, 11:19 PM   #21
Drsagacity
Drsagacity's Avatar
I don’t think I saw that in the list...not certain though. There were a ton of different parts.
TBD performance
Old 05-25-2018, 11:40 PM   #22
Joe's_cool_1le
Actually was the first time I've seen it.
Old 05-26-2018, 02:50 PM   #23
Drsagacity
Drsagacity's Avatar
Originally Posted by misterjaayy View Post
Other than pistons, rods, and a cam what else do you have planned for phase two? 100whp is a little optimistic for just a cam isn’t it?
When JRE did exactly what I am doing he had 725rwhp on E85 and 9.2psi. Since I am an A8, let’s say our goal is 700rwhp.it should be a very reasonable target.
TBD performance
Old 05-31-2018, 03:46 PM   #24
JANNETTYRACING
JANNETTYRACING's Avatar
I race gas and more boost I see no problem making 800 RWHP.
Ted.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 05-31-2018, 04:59 PM   #25
L78toLT1
L78toLT1's Avatar
Ted.
Ted, Would you feel comfortable going there if he was still on stock pistons?
On a related note, I'm getting ready to load your 2nd tune on my maggie equipped 2ss. I'll send you the datalogs, if it will ever stop raining down here in Georgia that is!
Baby Blue
Old 05-31-2018, 10:44 PM   #26
Drsagacity
Drsagacity's Avatar
Fuel system in office...came home to find the cam sitting at my front door. Waiting for pistons and headers...then the work begins. I will probably get my HP Tuner setup this weekend and make sure I have backups of the original tune, current tune...
Getting close! I think my wife is disgusted every time I come home and check the front door for a new delivery.
TBD performance
Old 06-01-2018, 06:53 AM   #27
laynlo15
I wonder why.
Old 06-01-2018, 08:39 AM   #28
JANNETTYRACING
On my own car yes on really good fuel.
Not on a customer car though to many variables.
Ted.
