#15 | |
![]() Drives: '16 2SS Join Date: Jan 2020
#16 |
![]() Drives: 2019 GMC Sierra 1500 AT4 Join Date: Nov 2011
Absolutely none with the valves closed. Sounds like my wife's tahoe.
Valves open you can hear it some at highway speed (70-80 mph), but it isn't what I would call drone. Less than my gen V camaro had with long tubes and corsa catback. Can still hold a conversation, talk on bluetooth, listen to podcasts, etc. I run valves open 95% of the time (really just close them in my neighborhood, if i see LEO...) NPP is actually kind of amazing.
Summit White 6" Lift, 37x13.50R24's |
#17 |
![]() Drives: 2001Camaro Z28 Join Date: May 2009
great info thanks
#18 | |
![]() Join Date: Mar 2020
#19 | |
![]() Drives: DZ Join Date: Aug 2018
I just bought TSP 2" headers in January and had to ding three header tubes on the drivers side (two for the steering shaft, one on the bottom for the motor mount) |
#20 | |
![]() Drives: 2017 camaro ss Join Date: May 2021
#21 |
![]() Drives: 2018 Camaro SS 1LE M6 Join Date: Oct 2018
I took my Mbrp pipes to a shop and had then expand the splayed end so I could slide the cat pipes into the Mbrp pipes. I figured this would reduce chances of leaking. I also had the shop weld up the splayed end of the cat pipes also.
Camaro 2SS 1LE, MBRP Catback, Mishimoto Catch Can, Rotofab dry, TSP1 7/8” headers,DSX FF, Pray ported MSD, 95mm TB
492WHP 473WTQ |
