Old 04-24-2018, 12:03 PM   #15
WhiteNight
WhiteNight's Avatar
Drives: MB 1SS
Forza controller. Open and close with remote in any setting. I has it and I like it.
WhiteNight is offline   Reply With Quote
Old 04-24-2018, 01:03 PM   #16
TDS
TDS's Avatar
Drives: 2019 Jeep Rubicon Sold:2017 ZL1 A10
Originally Posted by Gonasurvive View Post
Wow, they kick you from the track? There was a ton of really loud cars there. How many runs did you get in? I got four in, but I am pretty much all stock except K&N air filter. I left pretty much after we talked and didn't get a chance to watch you, PIR was getting extremely busy.
Only 3. One against someone and 2 other sound checks
Travis
SOLD ZL1 Summit White, A10, Black Strip, PDR, ZL1 floor mats
Ordered 2/11, 2000 2/14, 3000 2/20, 3100 2/24, 3300 3/7, 3400 3/8, 4300 3/16, 4B00 3/21 Bayed at train yard in Ohio, 4200 3/26 All Abroad for the West Coast, 4800 4/4 Deliverd to portland train yard, 5000 4/7 3:00AM Deliverd to Dealer, 6000 4/7 6:45PM Delivered to Customer
TDS is offline   Reply With Quote
Old 04-24-2018, 01:10 PM   #17
TDS
TDS's Avatar
Originally Posted by TheRealJA105 View Post
Put cats on your car that will quiet it down. Or pull the exhaust fuse and weld the valves partly shut to your desired dB level. Or make up some reducing tips that you could just clamp on the outer pipes maybe for ease of reversal.
I think I would blow the cats out once I am done with my mods. Somting in the tips may not be a bad plan
Travis
Old 04-24-2018, 01:13 PM   #18
TDS
TDS's Avatar
Originally Posted by Can'tHave2MuchHP View Post
Laguna pipes?
I googled those. Lol
Travis
Old 04-24-2018, 01:15 PM   #19
TDS
TDS's Avatar
Originally Posted by chrest View Post
PIR?
i was afraid to hear this... i have same setup and was concerned about them booting me. My car is LOUD.
How did you run?
Yes PIR
Track had no rubber on it, could not get any traction.
Was hoping to hit Woodburn this weekend but looks like rain
Travis
Old 04-24-2018, 01:18 PM   #20
TDS
TDS's Avatar
Originally Posted by Squatch View Post
I have not run at PIR yet, but was planning on it this summer, but My car is all stock so I am sure I'm quiet enough. I didn't know PIR had a noise DB requirement though...sucks.
I ran stock there last year and was fine. It used to be 110 before 9pm and then 104 after 9. Now max is 104 all the time. It is a city park now is what I was told
Travis
Old 04-24-2018, 01:33 PM   #21
datboi448
datboi448's Avatar
Drives: 2013 2LT RS, 2017 ZL1
Originally Posted by JamesNoBrakes View Post
Boring flat? No way.
no everywhere is flat, plenty of twistys and hidden turns
datboi448 is offline   Reply With Quote
Old 04-24-2018, 02:16 PM   #22
chrest
chrest's Avatar
Drives: 2017 Camaro 2SS
yep. people move into neighborhoods knowing a track is there, then complain about noise
2017 NGM 2SS NPP M6 MRC
Vortech SC, 2" TSP LT No Cats, Borla X, Eibach,
Hurst shifter
603hp/547tq
chrest is offline   Reply With Quote
Old 04-24-2018, 02:17 PM   #23
chrest
chrest's Avatar
Originally Posted by TDS View Post
Yes PIR
ill be down there. I refuse to think this rain will be a thing lol. Been looking forward to this weekend for too long
Hurst shifter
603hp/547tq
Old 04-24-2018, 02:19 PM   #24
copper3000
Troy
copper3000's Avatar
Drives: 2018 ZL1 Camaro
Originally Posted by datboi448 View Post
Move to one of the free states
copper3000 is offline   Reply With Quote
Old 04-24-2018, 02:38 PM   #25
TDS
TDS's Avatar
I am hoping your right
Travis
Old 04-25-2018, 10:52 AM   #26
Rlhay2
Rlhay2's Avatar
Drives: 2017 ZL1
Originally Posted by Wolvie70 View Post
Open, when fuse pull is performed it leaves them in the open position.
I forgot some are just pulling the fuse.
One simple option is a toggle switch to a 12V+ source to close the valves regardless of the signal from the ECU.
From the Forza website:
A Special Note about the Gen6 Camaro and C7 Corvette
Both the Gen6 Camaro and C7 Corvette have advanced control of the exhaust bypass valves incorporated within the Driver Mode options. This gives you the ability set-up the behavior of the bypass valves using built-in functions. Generally, however, to select opening of the bypass valves, you must be in one of the sport or track options. You have limited ability to have the exhaust bypass valves open in other modes, for example ECO or Tour. With the Forza controller, you can completely override the Driver Mode control and open the exhaust bypass valves at any time in any Driver Mode. And, you can do it quickly without having to scroll through options on the driver mode. And, with a simple touch of the button, you can return control of the exhaust bypass valves to the vehicle. In addition, you can also program the Forza controller to work through the car's HomeLink® system.
Using the Forza controller on your Camaro Gen6 or Corvette C7 gives you full independence using the Driver Mode menu. You can set up defaults on the car and then with a push of the button, you can immediately open the valves independent of the Driver Mode settings. Push the other button and return control of the exhaust bypass valves back to the car.
Perhaps the description is wrong but it states the valves can only be opened regardless of the ECU setting. No mention of the ability to close them upon discretion.
Rlhay2 is offline   Reply With Quote
Old 04-25-2018, 11:52 AM   #27
TDS
TDS's Avatar
I read it the same way you did. You can override to open but no override to shut.
I am going to get out the multi meter this weekend and see how it works.
Travis
Old 04-25-2018, 12:03 PM   #28
CT ZL1
CT ZL1's Avatar
Drives: 2018 ZL1
Whats the difference (besides price) between forza controller and the Mild to wild controller??
Past Rides
13 Porsche 911 4S
17 BMW M4
16 Shelby GT 350
07 Saleen Mustang
02 M3 Comp Pack
79 Corvette
CT ZL1 is offline   Reply With Quote
