View Poll Results: Which plugs with current mods (post #1)?
Stock AC Delcos 42 53.85%
NGK LTR5IX-11 Iridium IX Spark Plug (4344) Stock Heat Range 18 23.08%
NGK (6509) LTR6IX-11 Iridium IX One Step Colder 18 23.08%
Brisk USA RR15YS One Step Colder 1 1.28%
Brisk USA RR17YS Stock Heat Range 1 1.28%
Multiple Choice Poll. Voters: 78. You may not vote on this poll
Old 04-17-2018, 10:01 PM   #15
Brianw36
SNSTRSS
Brianw36's Avatar
Drives: 2016 Camaro 2SS A8
Stick with a stock heat range plug on a stock to mildly modified engine. going to a colder plug is going to cost you power and efficiency otherwise.
What do you consider mildly modified?
2016 Black Camaro 2SS A8 NP
Brianw36 is offline   Reply With Quote
Old 04-17-2018, 10:02 PM   #16
Brianw36
SNSTRSS
Brianw36's Avatar
Originally Posted by KonigWolf View Post
I set them to .035.
How much are you spraying? Are you running e85 and spray? Have you done any internal work?
Old 04-17-2018, 10:25 PM   #17
sav03cobra
SS Copbait R.I.
I would consider Mine and Konigs vehicles to be mildly modded, at least since they have most N/A Bolt-ons.
sav03cobra is offline   Reply With Quote
Old 04-17-2018, 10:48 PM   #18
KonigWolf
Drives: 2016 2SS A8
My car is at the body shop, so I haven't gotten a chance to spray or Dyno tune yet. My street tune has the car running good with no issues in the logs. When I get the car back, I'm gonna put it on the Dyno to make sure I have the timing and fuel correct an not leaving anything on the table, then start at 50 and work my way up to 100dry. If I'm not satisfied with my results, I'll convert to a wetshot.
I am running E85 full time.
Nothing internal as of yet. I'm waiting to see what full bolt gets me, if anything more, an then the nitrous.
16 Summit White 2SS-MRC-NPP-A8 :: PrayPorted IM - LT5 TB - Mishimoto Catch Can - RotorFab - E85 - TSP 2" LongTubes - Speed Engineering X/Mid Pipe
DIY Hpt Tune - DR - 1.75-60' - 7.47@95 - 11.56@120 with +2676DA
KonigWolf is offline   Reply With Quote
Old 04-18-2018, 08:05 AM   #19
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
bolt-on with no power adders or internal engine mods. even a heads cam/car with stock compression would be fine on stock heat range plugs.
Old 04-18-2018, 10:28 AM   #20
KingLT1
KingLT1's Avatar
Correct...you will want 2 steps colder and non projected tip for a 250 shot of nitrous. 1 step colder would probably be fine on a 150 shot.
Old 04-18-2018, 11:10 AM   #21
Brianw36
SNSTRSS
Brianw36's Avatar
With a gap of .35?
Old 04-18-2018, 02:00 PM   #22
KingLT1
KingLT1's Avatar
.35 sounds right for a 7 heat range NGK, but I am not sure on a 8. might need .28 for that plug.
Old 04-22-2018, 06:30 PM   #23
sav03cobra
SS Copbait R.I.
Man so much love for the Stock AC Delco Iridium's....
Old 12-08-2021, 07:23 PM   #24
Nitefall17
Drives: Camaro 1SS A8 Vert
You are correct I put stock AC Delco plugs back in this week and it does run better than the 1 step colder NGK plugs I put per tuner.
Nitefall17 is offline   Reply With Quote
Old 12-09-2021, 03:08 PM   #25
1LEThumper
1LEThumper's Avatar
Drives: 2020 2SS 1LE
I don't know how many of you have seen this, dealt with it, or wondered....
So my stock 2020 SS 1LE started to get a lot of build up on the tail pipes around 10-11k miles for what seemed like no reason. Depending on the light, I could at times see puffs of smoke come out of the tail pipe during a 3rd gear or 4th gear pull as it was long enough I could kind of watch the mirror if the road was clear. Typically when you get puffs during a pull it means it's knocking. I could never really hear the engine knock so I don't know if it was false knock or not. I tried a tank of 100 octane...car wouldn't do it. Back to 93 and it would do it again. I tried a few different octane boosters and some would clear it up while others just seemed to make it better but still there.
What I didn't do was do a ECU log to see if it was knocking. I don't have access to HP Tuners at home so I had to go off feel and just the visual signs of it.
Now this is a daily driver with maybe a trip or two to the track during the year if I have time so it sees a lot of stop and go as well as some decent hard driving at times.
I was thinking I would try a slightly colder plug on the car as well as a few other things.
I'm going to bring up oil....personally I wouldn't think this would matter much but I did two changes this past weekend. One was move from the Driven DI40 oil to the DI30 oil as well as move to the NGK 6 heat range plug.
The plug to me was an easy choice. It probably isn't that far off from needing a 6 range anyway. My GT350 uses a 6 heat range plug stock and they don't make that much power than the LT1 (526 vs 460) so to me that's within range of something to try even stock.
On the oil side of things...I have read for years on the low speed knock events with DI cars so I have been using Driven in it since it was new and went DI40 since they call for a 0-40 oil in them anyway. I figured I would ask Lake Speed to see what he thought about it and this is part of what he had told me..
"If your 2020 has the stock bearing clearance, go with the DI30 instead. The lower the viscosity, the less knock tendency......
The 5W-30 will be better for the short trip driving. Using either the 100 Octane as an “additive” or the Driven Defender Plus Booster will also give you a little more protection, but I’d just try the DI30 first.....
Yeah, the knock in DI engines is a thing. The oil can help. I bet the colder plug will help as well. The knock is worse at low engine temps, so that is one reason the lower viscosity oil helps.
Lake Speed, Jr.
Total Seal Piston Rings"
I am sending off the DI40 that I drained from the car for an oil analysis by Lake to just see what comes of it.
Since last weekend I can say there is no real change in oil pressure. I figured it would be slightly lower but from the PDR file logs so far if it is, it didn't change more than 1-2 psi from what I can see. So far on this tank of fuel it would appear that build up on the tips has been greatly reduced but there is still some there. I have not seen any puffs but time will tell I guess if any of this. will help / stop or do anything to protect it.
Take with it what you will, just figured I would try a few things without going flex fuel or E85 all of the time. Shocks me the car would have issues on pump fuel and I don't know if I am the only one that sees things like this with theirs or not.
1LEThumper is offline   Reply With Quote
Old 12-09-2021, 08:01 PM   #26
Nilly Welson
Drives: Camaro Super Sport, Six on the Stik
Originally Posted by sav03cobra View Post
Hafa Adai Fellow Camaro6ers,
Looking to simply replace my 2016 Camaro SS spark plugs.
My current mods are JRE tune, TSP headers w/o cats, tsp xpipe, CAI CAI, Pray Ported IM, and Katech Ported TB.
When I do spark plugs I also plan to add the MSD wires, do you guys recommend running the stock AC Delco Plugs? Or can I run NGK?
When looking for NGK I can’t seem to find a cross reference number, anyone know what they threw in theirs? Any reason to do a step colder? Can you please provide a part number?
Thank you for the help!
If your car is running right I'm pretty sure you won't see any difference from stock.
Nilly Welson is offline   Reply With Quote
Old 12-10-2021, 05:33 AM   #27
s346k
s346k's Avatar
Drives: like an old lady
i'm running stock heat range plugs and 5-40 diesel oil. car runs fine. bolt-ons & ethanol for over 15k miles now.
Old 12-22-2021, 06:56 PM   #28
Nitefall17
Lake Speed, Jr.
Do you have catch can???
