#15 |
![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS Join Date: Aug 2016
Yes the blower itself should be capable of much more power than advertised for this kit. Makes me wonder why my kit was so weak and also that Corvette's was just about as bad as mine. The whole point of my post was to let the OP know the truth, which is, when you hot rod, there's a chance it will break, and there's also a chance that you won't get the gains/results that are advertised or talked about on the internet. Most of my complaints obviously revolved around ECS because that is who I personally had the poor experience with, but obviously it's possible to receive these poor results or poor customer service from another company as well. I did mention there was an Edelbrock customer here who got underwhelming results, pretty similar to mine I think. We've also seen 1 or 2 forum members have their Whipples physically break. I seem to recall there was a Procharger customer on the forum who was not happy with his kit either. Buying a supercharger really is rolling the dice. Might be happy, might be pissed off.
#16 | |
![]() ![]() Drives: 2016 Camaro 2SS Join Date: Mar 2016
Its funny you bring all of this up as its something I never really considered as a possibility. 100 RWHP is 2/3 the expexted result.
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB Rotofab ARH 1 7/8 longtubes hi flow cats AFM deleted E85 11.0@124.9 11.65@118.8 pump gas,stock tune/exhaust New combo: Pray Performance Heads/cam MSD intake manifold and Circle D 3C 554/491 on E85 all work & tuning done by Pray |
#17 |
So you dyno'd 395whp before and 482 after on the same dyno in similar conditions?
#18 | |
If my kit had done what it was supposed to do for % gain, my dyno result would have been around 545hp. Which means it was over 60hp below par. Should have gained 150hp, actually gained 87hp. |
#19 |
Same dyno, SAE corrected. Conditions were not the same, was cooler for the stock pulls, so the stock pull correction factor was a minus and the supercharged pull correction factor was a plus. I did try the car on the dragstrip, in cooler air than the dyno pull was in, and confirmed that it was very slow, so it absolutely was not making anywhere near mid-500s for hp, not by a long shot. Car was easily 6mph slower than it should have been, I am not nit-picking here, the thing was WAY off what it was supposed to be.
#20 |
wow that is crazy. who did the tune?
#21 |
![]() ![]() ![]() Drives: 2017 Camaro 2SS Nightfall Gray vert Join Date: Jan 2018
I had a Procharger on two Corvettes and have opted for a Magnuson blower for the Camaro.
1. Results are based on lbs of boost. On this forum, we have people discussing results and leaving out the most important characteristic, lbs of boost. In other words, to compare apples to apples, always ask what boost they are running. Some people will provide misleading information as they display the stock rwhp numbers and do not discuss boost levels. In other words, comparing a Procharger at 10-12psi vs a Magnuson at 7-8psi. The more boost you run, the more risk you are taking...but the more power you will get. What is more important is the torque curve and Hp curve characteristics and that takes me into point 2. There are pro’s and cons for each configuration. 2. All of the major manufacturers are good choices, but it comes down to your plans...where do you want to end up? As an example, my first go around, I went Procharger and didn’t understand that to stay in the powerband I also needed to add gears and a converter (on my auto) and I needed gears (on my m6). These changes made stock drivability not ideal. Because of my previous experience, I started with my end goal in mind and want to avoid some of the mistakes I made last time around. Because I didn’t have a clear outcome in mind, I learned by making mistakes. My advice is to think through your goals then it becomes pretty straight forward. As an example, are you looking to have a great streetcar that can destroy pretty much everything on the road, your decision is different than if you want to build a track car. Building a track car will have different results if you are thinking quarter mile vs road course.
Magnuson Heartbeat SC - Tuned by JRE Racing 776whp/745wtq (12psi) 2018 Corvette Z06 vert- Black To be tuned by JRE Racing TBD performance |
#22 | |
![]() Drives: 2016 1SS A8 Camaro with MRC and NPP Join Date: Oct 2016
My car was the one ECS used for testing (featured on the website) and the car has been rock solid so far no complaints. As far as power I was right at 550rwhp/510rwtq at ~7psi on 93oct (you are correct doesn't really reach 8 psi but gets close on the base pulley). We all felt that for a 100% Bone Stock A8 SS to go from 398/389 to 550/510 with nothing else other than a set of new spark plugs/this kit+tuning was what we were hoping for and was not bad at all. Also I've trapped 126 mph a few times so again its doing work in the real world just fine for how conservatively its tuned currently (LT4 fuel system going in soon). Again I think it sucks you had issues with this setup and wish you the best of luck with whatever new direction you decide to go in -Jon
2016 HB Camaro 1SS A8 with MRC and NPP 398rwhp/389tq stock #s(11.84 @ 117 DR only, ECS boost 550rwhp/510tq (dynapack #s) , same boost + AEM water/meth + ARH Headers/mids 600 rwhp+ (dynojet #s) TTP)10.8 @ 129.
2020 Ford Explorer 2003 SVT Cobra Coupe (just your average KB Terminator Cobra). 2013 Focus ST (e30 Tuned). 2004 Dodge 3500 Cummins Dually 6 spd manual (tow rig). 1997 Jeep Cherokee (Lifted and Locked XJ off-road rig). |
#23 |
![]() Drives: Hyper Metallic Blue Magnuson 2300 Join Date: Mar 2018
To supe or not.
Mr Supersport18,
My 2016 2ss is at Lingenfelter right now getting a Magnuson blower and American Racing Headers. They assure me that engine life will be based on how you drive - Just like if the engine stayed stock. If you beat it up, things will break. Drive it with some self control and it will last for years. I get it back roughly The first week of may. I'll give updates once I get it back. Can't wait! |
#24 | |
#25 |
Well, I'll throw my worthless two cents in here. I am a firm believer that a stock
block is good (safe) to 10 LBS of boost. I have NOT dealt with the (stock SS) fuel systems yet. But we all know: Alt, Tune, Driving style,....etc are just a few factors in longevity of motor life. On the upside, my stock LT1 block with the mods (SC, headers, CAI and correct tune) has made a world of difference. I wish I could support this with numbers. However the dyno pulls were worthless as were the info. (scam, soon to be corrected) When guys sit in the passager side and some drive it. (motorheads) And state: HOLY CRAP, I think it works..lol. |
#26 |
![]() Drives: 2016 Camaro 1SS Join Date: Jan 2016
I was the edelbrock guy that got such mediocre results, and the reason was the sky high IAT’s. It was summer and I had raced a corvette on the way to the dyno. Then got there and shut the car off for an hour with the hood up. Then it was my turn to dyno, and inside the dyno room it was hot with a tiny fan. Car put down like 495 whp until the third run when we literally put a leaf blower pointed towards the IAT sensor to get the IAT’s down some. Then it pulled like 511.
A year later I went back in silmilar conditions and it did 530 on back to back pulls, but with plugs only gapped at .032” (too tight and suppressing power) but with the killer chiller installed to control IAT’s so there wouldn’t be so much timing pulled like the first dyno session. The edelbrock IAT sensor location is in the hottest location they could find, and really caused the car to dial back power when it’s hot out. In the summer, without a killer chiller, my car feels WAY down on power versus when it’s under 75-80 degrees out, especially in city traffic which is all my car sees. Now when it’s under 75 out, the car is fast and always puts a big smile on my face. That’s why the killer chiller is such a benefit to maintaining good power in the summer, at least with an edelbrock car with their tune anyway.
2016 Nightfall Gray Metallic 1SS 6MT, Edelbrock E-force supercharged, Killer Chiller with 3-way bypass, catch can ***FOR SALE, MESSAGE ME IF INTERESTED***
Previous: '12 Mustang GT 6MT (12.47 @ 115.88) '09 G8 GT (11.86 @ 120.47) '05 GTO 6MT (slow, lol) '01 Grand Prix GTP converted to turbo, high 11's |
#27 |
|Engineer|
Drives: 2016 Camaro SS Join Date: Aug 2016
I hear too wide a grin can rip your face apart, so there's that.
#28 | |
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
I can assure you that your installer or tuner or both missed something, we specialize in fixing these kind of problems. I had an ECS supercharged car come to my shop for a tune, we went over the install fixed a few things that were installer error and tuned it to 598 RWHP on 93 octane fuel. The supercharger kits are solid, it is the install and tune that can make or break the kits. We have never had a lower power output without being able to find the culprit and fixing it on the spot. If we can every be of assistance give us a shot. Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com |
