Old 06-01-2021, 10:39 AM   #15
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
there's a process that gen5diy goes thru to flash a new hmi unit for your car's specs and/or override similar car's hmi programming with your car's vin.
I think if they could update the hmi to allow a 7->8 screen upgrade - they would advertise that even if they didn't have a kit to include the necessary hardware. But they dont.
I dont think it'll be as simple as just getting an 8" hmi pkg from them and throwing the right cables and screen on it and having it work - but it might.
To test the theory, it'll only be about a 1500-1600 dollar investment (that could be entirely wrong and give you some nice paperweights (though you could re-sell the screen at least for whatever you managed to get it at off ebay)
Old 06-02-2021, 08:14 AM   #16
Gammaray2008
Drives: Chevrolet Camaro 1LT 2018 v6
Originally Posted by Nitro66215 View Post
Anything is possible. You just need the right information. You'll need at a minimum the proper HMI module I05/I06 (I say go for I06 with Nav). Have it programmed. Get the screen. And then.... the fun..... WIRING! There most likely is a difference in wiring from the HMI to the screen.
ok, thanks, where can I find everything, like the radio and its components.
Gammaray2008 is offline   Reply With Quote
Old 06-02-2021, 09:02 AM   #17
Nitro66215
Nitro66215's Avatar
Drives: 2017 ZL1 Vert - M6,SIM,CFW,NAV
Like CellSafeMode stated, it can be a process that you invest in but can't complete due to missing pieces.
I have the complete service manual for the 2016/2017 (supposed to be ok for the 2018) if you want. This has the wiring diagrams as well as partnumbers for connectors and such.
You'll need IO6 module for NAV or IO5 just for the 8" screen. I don't think the radio needs to be changed, but that is a module in itself. Then the appropriate wiring harness for it to work, or add the wires with pins based on the service manual partnumbers.
PM me and I'll get you in contact with the GM guy and programmer I used when I upgraded to IO6. Going from 7" to 8" will not be an easy task. The cost alone is most likely why Gen5DiY hasn't developed a drop in solution.
2018 2SS Vert - Hot Wheels - Indy 500 #30 - SOLD
2017 ZL1 Vert - M6 , SIM, CFW, NAV - SOLD
2017 RS 1LT 2.0T Vert - A8, Garnet Red - SOLD :-(
Added - IO6 - NAV, UHS - Enhanced Display, K4C - Wireless Charger, UV6 -
Heads-Up Display - DIY
2011 CTS-V - Black / Black - SOLD. :-(
2013 ZL1 - Black / Black - SOLD. :-(
2010 2SS - Indy 500 Pace Car. - SOLD. :-(
2002 Z28 - Pewter / Black - SOLD. :-(
Nitro66215 is offline   Reply With Quote
Old 06-02-2021, 06:13 PM   #18
cellsafemode
just note, the actual displays do not need any programming to marry to the car. Despite what dealer gm parts stores will advertise if you try buying one new.
but that does mean buying new means having to deal with a dealership in person ....hence the suggestion to source that from ebay. Just be aware that old MY's have had the part number replaced many times and there may be multiple PN's that are compatible and multiple that aren't. An original 2017 part should be ok though (2016's suffered problems that caused black screens of death - so dont buy 2016pn's even if they'll match).
Old 06-02-2021, 09:28 PM   #19
GTPprix
I hack cars.
Drives: Lots ;)
We do a decent amount of these on the K2 Truck/SUV and to be honest it sucks. You need the HMI, The Radio Module, The screen, programming for HMI and Radio and a metric ton of missing wiring; its a mess.
Chris White
Some uhhhh cars.
GTPprix is offline   Reply With Quote
Old 06-03-2021, 09:19 AM   #20
Nitro66215
Nitro66215's Avatar
Thanks Chris. I wasn't sure about the Radio. And wiring... yeah... I gathered it would be fun.
Old 06-03-2021, 09:39 AM   #21
GTPprix
I hack cars.
Drives: Lots ;)
You're welcome! this is one those scenarios where we really recommend you get an entire IP harness and pull the dash. Its WAY easier in the long run and thats still a TON of work. At that point you also upgrade the cluster and add steering wheel controls as well.
Chris White
Some uhhhh cars.
Old 06-03-2021, 09:42 AM   #22
Nitro66215
Nitro66215's Avatar
I agree. I was lucky when I did mine and already had the 8" screen. IP Harness is like $350 or so?
Old 06-04-2021, 02:34 PM   #23
Gammaray2008
Where can I find everything, like the radio 8 "" and its all components . Camaro 2018
Old 06-21-2021, 01:19 PM   #24
Nitro66215
Nitro66215's Avatar
I would work with Gen5DIY and GTPprix. If $ is no object... then it should be able to be completed.
Old 11-08-2025, 05:29 PM   #25
groque1
Originally Posted by killswitchpo View Post
I have a 2017 Camaro 1lt v6. Change your screen from 7' to 8' can be hard depending on how far you want to go. I want the full future of the 2lt, so I had a choice to trade my car in for 2lt or challenge my self. So I did, I have everything that the 2lt has except for the heads up. I don't really care about the heads up plus I think its more distracting. I have the LED trims on the door and on top 8' screen, PDR upgrades IO6, back up seniors and more, and more. Right now I'm in the process of making a video and post it on youtube.
Did you ever post the youtube video? Is PDR/I05 OR IO6 Necessary for the 8" upgrade? I already have after market lighting in the cabin.
groque1 is offline   Reply With Quote
Old 11-12-2025, 08:42 PM   #26
Nitro66215
Nitro66215's Avatar
Smile
Digging up an old one. lol. PDR isn't necessary for the 8" screen. The I06 though I think was. I preferred having I06 and the 8" anyway. I sold that car long ago. Might still have the original 7" screen in the basement.
#screenupgrade #guagecluster
