04-01-2018, 07:51 AM | #15 | |
Drives: 2017 1LE Join Date: Nov 2017
'17 Bright Yellow 1LE. PDR, STB, !CAGS
Borla 60606, 11925. Tony Mamo ported TB, ROTOFAB, !Sound Tube |
04-01-2018, 09:39 AM | #16 |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
Sorry to hear about your accident. Looks like just body panels? If so it could have been much worse if suspension got hit and bent. Fingers crossed for ya it will be fixed right and as good as new!
04-01-2018, 11:16 AM | #17 |
Drives: 2017 Chevrolet Camaro SS 1LE HBM Join Date: Jul 2017
Thank you. I think the suspension is okay. The right rear tire sustained a shallow cut to the curb protection strip and the wheel flange has a blemish not down to the metal. After some reflection on choice of body shop, I’ll be telling the insurance company to take it to Jim Ellis Collision Center. My past experience on a previous Camaro I owned was a flawless and perfect paint repair. And they’re highly trained and certified. Farther from my home but only one I hope to trust to understand this car and make it right.
04-01-2018, 11:38 AM | #18 |
Wth was that old fart thinking?
04-01-2018, 01:39 PM | #19 |
Drives: '18 1SS 1LE Join Date: Sep 2017
Rear quarter panel and door frame where door striker is mounted are part of the vehicle shell. They can replace the quarter, but where it mounts by the door striker, the door opening, looks bent up.
I think the damage is worse than it appears. |
04-01-2018, 01:47 PM | #20 |
If you get a chance check all the body gaps on the other side of the vehicle, all the way around. How's the drivers door open? How about the trunk?
Newer cars are designed to absorb impact and can bend and twist once the unibody system has been compromised. Look it over real, real good. |
04-01-2018, 05:34 PM | #21 | |
Drives: 2017 Camaro 1LE Hyper Blue Join Date: Apr 2017
It sucks that it happened but the car can be replaced. Good Luck! |
04-02-2018, 01:07 AM | #22 |
I don’t know what he was thinking other than I do know he was not thinking about stopping for the stop sign. The way he entered the roadway was as if he was approaching the intersection as if he had a green light. And it certainly wasn’t the sun in his eyes as it was to his right (West) as I was approaching from the east.
04-02-2018, 01:14 AM | #23 |
I know . The fit and finish of all other panels on the car are fine. No binding or misalignment. Although the passenger door did open and close post-collision, now it won’t since rolling the window down to hear guidance from the wrecker driver when unloading it. I heard the window bump inside the door and guess it somehow has permanently locked the door. To replace the quarter panel is going to require some serious expertise I believe so that’s why, in addition to being 1LE, that I’m taking it to Jim Ellis. Besides Chevrolet, they are renowned experts for Porsche, Audi, etc.
04-02-2018, 06:12 AM | #24 |
I just hope everything can be made right.
04-02-2018, 02:33 PM | #25 |
Thank you. It’s at the collision center now. Will be toward the end of the week before I hear an estimate from both the collision center and the insurance company. On a feel-good note, the service writer thinks it’s repairable but did grit his teeth. Said he can’t write up a realistic estimate until his tech cuts the panel off to inspect for underlying damage. He did assure me they use only OEM parts and repair processes as I knew they would based upon my prior experience some 12-13 years ago with my 4th gen. He also described to me how he will direct the repair as far as repainting is concerned for a back-to-factory appearance with no tape lines or overspray. Interestingly, he’s the same guy that took care of me several years ago and remembered me so that felt good.
04-02-2018, 04:07 PM | #26 |
Sounds like your car is in good hands.
Best of luck. |
04-05-2018, 04:12 PM | #27 |
Today Jim Ellis Collision Center did the initial repair appraisal...$11,327.43 for parts, labor and paint. This is just the starting point. A supplemental will likely follow raising the overall cost. At my insistence, only new OEM parts will be used where necessary. Fortunately, my USAA appraiser (also present) didn’t give me a hard time since the car is less than 2 years old (build date 1/2017). The guy there overseeing and directing the repair, Larry Stidham, is calling for substantial disassembly (a good thing) so that when the car is painted it will be consistent with factory appearance and free of any tape lines or overspray (the only thing I’ll accept). The initial projected time to completion I’m told for now is 6 weeks . But, I’d rather it be done right as opposed to rushed. Part of the extended time is to allow the solvents in the paint to evaporate before my Xpeled panels can be redone. Finally, after it’s repaired, I will get it appraised to determine the fair, not necessarily the insurance offer, diminished value. Once it is all said and done, USAA will send GEICO (at-fault party’s insurance) the bill through subrogation.
04-05-2018, 04:20 PM | #28 |
I'm thinking six weeks is being optimistic.
My guess on the damage was closer to $14,000, stuff adds up quick. |
Tags |
1le, camaro, crash, damage |
