03-26-2018, 03:15 PM | #15 | |
Drives: 2019 ZL1 1LE A10 Join Date: Jan 2015
https://my.chevrolet.com/content/dam...tion-guide.pdf
Ryker #29
2019 ZL1 1LE A10 2015 Z/28 #809 |
03-26-2018, 03:52 PM | #16 |
Drives: Grandad's C2 L89 Join Date: May 2017
2018 ZL1 1LE sw/PDR
03-27-2018, 12:21 PM | #17 | |
Drives: 2018 ZL1/1LE Red Join Date: Oct 2013
The slight difference is...they are saying 15w50 -only- for ZL1 1LE, and most likely they are assuming the 1LE variant will be a road course use car running harder/longer. (I'd rather they come back with a year-round 5w40 or 0w40 like i had in the ViperGT or GT3RS. Never a issue with cooling, oil temps nor failure). In-fact just swapped back to 5w30 yesterday until the next track event. (Pennzoil UltraPlatinum, good stuff)
BobR
2018 ZL1 1LE (Red) - New Dec 2017 2015 ViperGT (Gunmetal w/Red stripes) 2013 ZR1 Anniversary 2014 ZL1 - BrightYellow, 6sp 2011 Porsche GT3RS - White w/red graphics 2009 Porsche C2S 2001 Ferrari 360 |
03-27-2018, 03:06 PM | #18 | |
2018 1LE, NASA Instructor
Drives: 2018 Camaro SS 1LE Join Date: Jan 2018
What it means is that if you are not pushing as hard or running on a cooler day or a less demanding track you will have more headroom (i.e. will be taxing the oil and cooling packages less). I've tracked a C7 Z51 with 5W30 oil for 3 years, and that car would go to 300F oil temperatures in the blink of an eye, and had to be temperature managed (shifting ~1,000RPM below redline) to prevent hitting the engine protection ("limp") limits. I'm doing 5W40 in the SS 1lE, because I want to be able to push more (closer to redline) and want a little bit more headroom, and even less warranty questioning possibilities. My guess is the GM still needs to complete "likely worst case scenarios" this summer on the ZR1/ZL1-1LE before adjusting recommended track oil down to 0W40. |
03-27-2018, 05:05 PM | #19 | |
Drives: '17 ZL1 Join Date: Jul 2016
I don't disagree with what you've stated here, and "Likely worst case scenarios" seems like a good way to put it. I'm just skeptical about the theory of the ZL1 and ZL1/1LE having different oil specs due to the 1LE being slightly more track capable. Mechanically, the worst case scenarios for both cars should still be very similar. The most significant difference is much more likely to be the owners and where/how hard they drive. I've also considered that maybe there is difference in the emissions systems which would make the reason for different oil recommendation obvious, but I'm not aware of any such difference. I think this question is a great question for Ask Al, but this process is moving so slowly I'm starting to lose interest. The Corvette forum's Ask Tadge seems to move at a much better pace. I too suspect we'll see this change in their recommendation.
