Old 02-05-2019, 03:51 PM   #15
PRAY
PRAY's Avatar
Drives: 2016 2SS
Jim told me about it, I got it to work and then told him how. We both run them now with a couple other guys.
Old 02-05-2019, 04:37 PM   #16
18ss376
Drives: Camaro
Does a gear change require a tune?
18ss376 is offline   Reply With Quote
Old 02-05-2019, 04:40 PM   #17
PRAY
PRAY's Avatar
Drives: 2016 2SS
Absolutely. You gonna have to bite the bullet and tune that thing bro.
Old 02-05-2019, 05:04 PM   #18
18ss376
Drives: Camaro
Jannetty has sent me my tune, just not for a rear gear change. I still have other mods to do before I get to gears.
Old 02-05-2019, 05:30 PM   #19
Immoralus
Immoralus's Avatar
Drives: 2017 Camaro 1SS A8
This would help with roll racing I imagine ...or am I wrong in assuming this?
Immoralus is offline   Reply With Quote
Old 02-05-2019, 06:03 PM   #20
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
How are they holding up? Are the 3.27 gears as strong as the SS 2.77s?
Old 02-06-2019, 01:51 PM   #21
KonigWolf
Drives: 2016 2SS A8
I'm just curious what fittings are needed/used to loop the diff cooler lines.
16 Summit White 2SS-MRC-NPP-A8 :: PrayPorted IM - LT5 TB - Mishimoto Catch Can - RotorFab - E85 - TSP 2" LongTubes - Speed Engineering X/Mid Pipe
DIY Hpt Tune - DR - 1.75-60' - 7.47@95 - 11.56@120 with +2676DA
KonigWolf is offline   Reply With Quote
Old 02-06-2019, 11:27 PM   #22
Gasoline_Farts
Drives: 19 SS 1LE
Does this mean you could swap the SS 3.73 into an RS-V6?
Gasoline_Farts is offline   Reply With Quote
Old 02-07-2019, 07:44 AM   #23
PRAY
PRAY's Avatar
Drives: 2016 2SS
If you get the correct rear diff it is a direct bolt in with a hub swap. Cooling lines and all. I have about 40 10.00 passes on mine and a 9 sec pass and about as many 1.37-1.38 60ft's so I would say it is plenty strong. I only had 8 miles on mine when I made my first pass. I wish I would have broken it in better. I do think it is slipping some. I have a new one sitting in the garage I need to install at some point and do a proper break in on. My other 10.10 car has one that we beat the piss out of as well with no issues.
Old 02-07-2019, 11:07 AM   #24
USAFS197
USAFS197's Avatar
Drives: 2018 Audi TT RS
I just watched a video the other day about Renick Performance tossing the 3.73 rear end set into an ATS-V A8. Apparently it pulls pretty hard.
2018 Audi TT RS
2019 Audi RS3
About as fast as the TT RS
2019 Camaro ZL1 1LE
Sold
2018 Camaro SS 1LE
Sold
2019 Corvette Z06
Sold
Sold
Old 02-07-2019, 04:27 PM   #25
Snowblind
Snowblind's Avatar
I have run the 3.73 in my A8 SS and I can tell you the car was an absolute blast to drive on the street too.
Old 02-08-2019, 09:15 AM   #26
Dustya
Drives: Overkill Supercharged 2016 CamaroV6
Its all swappable Pinion Flange, Axles, Axle flanges.. I am currently running SS axles and Axle Flanges on the v6 manual 3.27 LSD In my A8 V6 - Its pretty awesome its all so modular, same hubs etc..
I feel like the 3.73 would make the A8 gears way to short the 8l45 and 8l90 trans gearing is slightly diff But I know my 5th gear is like 135mph with the 3.27 going from 120mph 4th gear with the 2.77 - 3.73 would put me around 120 mph in 5th gear leaving me to shift into 6th gear. I know the 8l45 and 8l90 have very close 5th gear ratio 1.26 compared to 1.27 and 6th gear is 1.0 on both.
the 3.27 seems perfect your in the powerband but still gives you wiggle room to improve in 5th gear. I am currently trapping 125-126 leaving me some headroom in 5th gear which is nice before I was running out 4th gear right to the end shifting into 5th left me running a bit slower and running out 4th just gave me no head room. Having to shift into 6th with the 3.73 is going to set you lower in your powerband RPM wise as 6th gear is longer then 5th gear. the 3.27 seems to be the sweet spot for the 2.77
Now I just need to get the tune figured out learning this stuff is just as overwhelming as it is fun!
Hyperhawk - 2016 Camaro 2LT RS - First LGX in the 12's and 11's Current record holder 11.0@125
Follow me on Instagram https://www.instagram.com/hyperhawkcamaro/
Youtube https://www.youtube.com/channel/UCHR...-ilSpV3gMQnTuA
Supercharged with Overkill Superchargers http://www.v6superchargers.com
Dustya is offline   Reply With Quote
