#15 |
2016 loaded 2SS
Drives: Maverick X3 Turbo R Join Date: Feb 2015
installing the LT4 LPFP; started last night but didn't get the job finished off. using a pneumatic nibbler (powered tin snips basically) help make the job very easy to gain access without dropping the fuel cell.
Took the car for a couple rides and seen i had a trans line leaking. I addressed it by doubling up on the high pressure clamps on each side of the line. I just need to throw the car on a lift and flush/fill the fluid. ![]() hoping to have the e-boost 2 controller & 5psi springs installed by thursday so i can switch between boost levels for e85/93 flex fuel. ![]() ![]()
#16 |
2016 loaded 2SS
Obtained a ecs boost a pump from a co-worker today and will wire it in this weekend. Using an output from the e-boost 2 to turn on the BAP @ 2psi of boost. This should help the low pressure fuel system performance on corn fuel.
Ran into a pretty large issue with the car when i noticed some compression blow by at the injectors. Apparently the injector bores were very dirty and when re-installing the LT4 squirt guns the seals got damaged. I'm working on getting the proper sized reamer from a friend to clean out the bores & re-install them with the new seals pressed & sized on.. I've tried pipe cleaner, spray gun cleaners, brake clean & nothing is taking this nasty stuff off. Real good learning lesson here. Any northern car that see's salt is probably bound to see some corrosion on their motor in the worst places. ![]() these special tools for the seals are ridiculously expensive. thank goodness for good friends who wrench often. ![]() ![]()
#17 |
2016 loaded 2SS
Completed the car last night; so long as no more issues pop up.
Borrowed some special tooling from a friend to clean the injector bores up; that certainly should correct the seals getting demolished during injector installation. We opened the intake valve on each cylinder and used a vaccum in the intake running to make sure we sucked out any dirt that the reamer dropped into the combustion chamber. Also installed & wired the boost-a-pump. I mounted/permanately wired the afr gauge & eboost2 controller. Once the dreaded michigan weather gets nicer, i'm looking forward to completing the tuning with Ted J. ![]() ![]() ![]()
#18 |
2016 loaded 2SS
Well, Ted gave me the go ahead for a small WOT pull in 4th gear last night.... all I can say is WOW. It's like 40 degree's here and it was sprinkling so it took a lot of courage to make the pull; but managed to make three.
While i swapped on the rear DR's, I changed out the rear diff fluid in hopes of getting rid of the rear end groaning. Can't wait for better weather to really get this car dialed in. ![]()
#19 |
2016 loaded 2SS
#20 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1SS 6MT NPP Join Date: Feb 2010
You have earned some serious applause.
![]() ![]() I look forward to you next update.
#21 | |
2016 loaded 2SS
6.5psi from 5psi springs on 93 fuel. Should see a 10.5 on stock hellion springs (7 psi)
#22 |
![]() Drives: Camaro 17 SS Join Date: Jan 2017
Looking good bro. Also don't know if you spoke with Turbosmart but the BOVs stay open until they no longer have vacuum applied. With your kit where do you get your oil supply?
#23 | |
2016 loaded 2SS
#24 | |
![]() ![]() ![]() ![]() ![]() Drives: 17 SS a8 Join Date: Feb 2010
best et 5.83@121 with the 5.3 http://www.camaro6.com/forums/showthread.php?t=465472 |
#25 | |
#26 | |
2016 loaded 2SS
![]() Pretty bummed out on this, but I'm not willing to install a camshaft right now. Thanks Parish; I didn't try any launching techniques at all. Do you know what is the highest i can get it up to before the tires break loose on the stock stall?
#27 |
It depends on your tires, brakes, track...
Typically get the tires sticky, if your not picking up gravel on the return road they are not warm enough. Then you stage, push the brakes HARD, start to brake stall, let the light turn green but don’t go, then brake stall harder and try and find the limit of when it spins or pushes through the lights, then let er rip. Typically if it spins or pushes the run won’t be great but you try and learn when that happens and let the car go right before that happens. If you have a boost gauge that might be 1psi, it might be 7psi. Before I posted my budddy is running 5psi, that is his boost level, not his boost at launch. I bet he is only leaving at a lb or two and has room for improvement but any bit helps.
#28 | |
2016 loaded 2SS
