Old 10-04-2018, 07:34 AM   #15
Nsxmatt
Drives: 2017 Camaro
Originally Posted by init4fun View Post
I launched the car at progressivly higher RPM until it started to puch the front tires locked throgh the beams and each time the car dead hooked but never bogged. I played with tire pressures from 20 to 30psi with the best time coming at 26psi. Best 60' was 1.76.
Being an A8 there's not much driver dialing it to do. Launch it and hold the pedal down.
From what I have read from countless others is don't footbrake it. Leave at idle and punch it which will flash the converter and launch you harder. A 1.6 60 will get you 11's as is.
Nsxmatt is offline   Reply With Quote
Old 10-04-2018, 08:32 AM   #16
init4fun
Drives: 2017 50th Anniversary
I tried both. Foot Braking it and stabbing the throttle from idle. Two best runs came from foot braking it around 1500-1600. Stabbing from idle rasied the 60' into the 1.85 range.
init4fun is offline   Reply With Quote
Old 10-04-2018, 08:35 AM   #17
PRAY
PRAY's Avatar
Drives: 2016 2SS
That's only if you are on a tire.
Old 10-04-2018, 10:06 AM   #18
Nsxmatt
Drives: 2017 Camaro
He's running DR's and is saying it's dead hooking.
Old 10-04-2018, 10:16 AM   #19
PRAY
PRAY's Avatar
Drives: 2016 2SS
Thanks. Off idle smash then.
Old 10-06-2018, 03:22 PM   #20
51FIFFT
Drives: 2017 2SS M6 FIFTY @51fifft
My best is a 12.3 bone stock M6, on a shitty/leftover prepped track ( weekday fun drags )
run consistent 12.5's. My next step is drag pack, after that I will be hitting up PRAY. I'm still on the fence with my build, not sure if I want to go P1X or just do FBO. Goal is 600 WHP.
Keep practicing you'll get it.
51FIFFT is offline   Reply With Quote
Old 10-08-2018, 09:00 PM   #21
DiGiam
DiGiam's Avatar
Drives: 2016 NFG SS A8
Trade it for a 19 A10 mustang..lol j/k.
2016 NFG 1SS A8. Pray ported intake manifold, Rotofab dry cai, kooks 2" catted longtubes, E85,
DiGiam is offline   Reply With Quote
Old 10-10-2018, 02:45 PM   #22
init4fun
Pray,
I tried both methods. Best runs were foot braking to 1500-1600 then smashing it to the floor. Simply samshing it to the floor lost a .10 on the 60', .08 on the 330' and was down almost 1.2 mph at the 1/8.
Best 2 of the 5 runs were foot braking.
Old 10-10-2018, 03:12 PM   #23
Snowblind
Snowblind's Avatar
I'm really looking for an 11.99 time slip and wondering how to get there without voiding the warranty. I'm currently buying a a set of 305/40/18 DR's and plan to run on a cool night in the early spring.
What else is required?
Have you tried some weight reduction ?
Car is basically stock with 315/40/18 Nt05R radials, Pray ported TB and CIA cols air kit with the dry filter. DA was -241
With a DR and negative DA you should be there no question.
Best 60' was 1.76 so it's hooking great.
I don't know the characteristics of Nitto's but my Mickeys liked 20 lbs when I was near stock and 18lbs now.
Again, a 1.76 60' should be plenty in negative DA to get you an 11 slip but I would lower the pressure some more than 26 and leave at idle, it's been proven over and over again to be the best technique for quickest e.t.
I also disagree on the A8 comment, knowing your car and launching it correctly seperates the men from the boys. Good luck man, hope you get it.
Old 10-11-2018, 04:25 AM   #24
PRAY
PRAY's Avatar
Drives: 2016 2SS
Pray,
You have to execute the off idle smash perfectly. There is much more to it than just smashing the gas. But if you have a technique that is working for you then rock it bro.
Old 10-11-2018, 09:07 AM   #25
init4fun
Snowblind,
I've not unbolted anything from the car but i have made sure that there was nothing in the car. Removed everything from the glove box and truck. Car is also running radials on the rear with a set of knock off vette wheels. The combo is about 4 lbs lighter than stock so nothing major. I'm looking at using a buddies set of skinnies on the front so that should help.
I completely agree that the negative DA should have put me in the 11's. When I came back and the time slip showed a 12 I was shocked as the run "felt" better than anything previous.
I'll play with pressures when I go back next weekend. If I went below 24 the car would bog leaving so I bumped it up until the 60' stopped improving but I dropped below 20 so i'll give it a shot.
The only think I can think thaty might be effecting the car is all of the transmission issues the car has had. The trans has been replaced twice and it's on it's 4th converter so I'm wondering if something isn't 100% with all of that.
If I get within a tenth I'll start pulling stuff out of the car to get there and stick my skinny buddy in the car.
Old 11-08-2018, 11:49 AM   #26
SDecker190
Drives: 2017 2SS Hyper Blue DM Exhaust A8
I have 8 passes with low DA in the last few weeks
Sunday October 21st
11.83,11.82,11.91,11.95
The DA was at -18 and last run was at 350.
No Back seat and 1/4 tank gas.
Friday November 2nd
12.09,11.99,11.95,11.97
DA around 100 to 350 but more humid.
With back seat and half tank gas.
My setup is a 2017 2SS with A8 , K and N filter, 28" drag pack with mickey Street SS. NO tune ETC.
thats 7 upper 11 sec passes out of last 8.
I launch at 1600 to 1700 foot brake all nannies off on 24 lbs air 305/45/17 rears and cut 1.69 to 1.77 60ft times trap 114.5 to 115.5.
The tires Dead hook its very impressive off the line.
I run 50lbs in the sportsman fronts
Bone stock just Drag pack and air filter.
Best street tire run stock size but firestone indy 500 is a 12.07 march 31st with launch control.
My converter has been replaced in the last 2 months if that makes a difference.
SDecker190 is offline   Reply With Quote
