Old 03-17-2018, 12:07 AM   #15
BigShow1960
BigShow
BigShow1960's Avatar
Drives: 2017 1 Camaro + Chevy Avalanche
The dealership reached out to Chevy tech resources. As expected the caster can't be changed with OEM parts. The only suggestion was to lower the front end or raise the rear, not doing that.
They were able to set the front camber to -2 degrees and tweaked the the back end alignment. They only charged me for the front end alignment. There's a one time use alignment bolt that they used. I don't know if it's just the expectation or if the alignment but, steering feels tighter and quicker.
They did one of my complimentary oil changee with 5W-40 rather than 5W-30 at no additional cost to me.
Happy for now. Next weekend I'll be at Wild Horse Pass Motorsports
BigShow1960 is offline   Reply With Quote
Old 03-20-2018, 05:23 PM   #16
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
I strongly recommend getting set up with a lifetime alignment package. Then check the toe constantly! I got the lifetime alignment from Firestone for $180 and I'm going to get it checked before every track day.
Old 03-20-2018, 05:38 PM   #17
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
If it's good at all Firestone dealers find one for the "track alignment" before hitting the track, and another for a "street alignment" after track day.
Guys at each shop will be like "How's this guy's alignment always get so screwed up every time he comes in?"
This way they won't think you are getting them to set up your car for track days "free" all the time.
Old 03-20-2018, 06:03 PM   #18
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
Every time you adjust camber they are reusing the 1 time use TTY bolt. I tell them to leave the Camber alone (already at track spec) and only fix the toe. Camber is fine to daily in track spec, toe is what will chew through your tires. It gets knocked out often with these huge tires.
Old 03-20-2018, 06:39 PM   #19
JeffFox
Drives: 2018 2SS Coupe A8
Originally Posted by carguy55 View Post
I just went over the 1500 mile break-in (no track days yet) and I've went from a new tire tread depth of 7/32 to mostly 5/32 with a few at 4/32. Basically means not even driving that hard I'm losing 1/32 per 750 miles. Can't wait to see what happens on hot summer track days at COTA
Wow that is crazy fast treadwear.
JeffFox is offline   Reply With Quote
Old 03-20-2018, 09:19 PM   #20
BigShow1960
BigShow
I bought a lifetime alignment at Firestone, they couldn't get the track camber. There's a one time use OME bolt that the dealership used. Now that the camber has been set, I wonder if Firestone can keep me at -2?
http://www.camaro6.com/forums/attach...6&d=1500607140
Old 03-21-2018, 09:12 AM   #21
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
Once camber is set it stays put much better than toe. So yes. They can just adjust the toe and leave your camber alone. Just be sure to tell them every time you get the car aligned that the Camber will show out of spec but to leave it and only set the toe.
Old 03-21-2018, 03:42 PM   #22
Sharkfighter
Drives: Bmw
Are many people only getting 5k miles out of the oem tire?
Sharkfighter is offline   Reply With Quote
Old 03-21-2018, 03:50 PM   #23
7speed
Drives: 21 SS
I have almost 11,000 mi and my tires are at 3/32.
FBO, E85
11.1@123
7speed is offline   Reply With Quote
