#15 |
![]() Drives: 2017 Camaro 1LE Hyper Blue Join Date: Apr 2017
I seem to remember grabbing 5th in the 130s as well.
#16 |
"M1SS1LE"
Drives: 2017 SS 1LE Join Date: Dec 2015
Here you go
#17 |
2018 1LE, NASA Instructor
Drives: 2018 Camaro SS 1LE Join Date: Jan 2018
Great - thanks for posting the actual screen shots.
Another question if anyone remembers or can watch the video....on 3rd->4th shift done at/near redline, what does the RPM drop down to? Just trying to figure out where you land on the powerband after an upshift, particularly since I plan to shift 1,0000-1,5000 RPM short of redline on my first track day (break in and all). Just wanted to know if I'd land too low to accelerate out. |
#18 |
![]() Drives: 2018 HBM SS 1LE Join Date: Jun 2017
Is second really good for 80? Well, maybe I'm driving like a bigger jackass than I thought.
#19 | |
"M1SS1LE"
#20 |
![]() Drives: 2017 Camaro SS 1LE Join Date: Apr 2017
kjk3888, I can confirm those second hand. On the Yas Marina Circuit I commonly found the rev limited in 2nd, 3rd, and 4th just due to the length of the straights and the tall gearing in this car. Based on my speeds I was right north of 140 in 4th on the long straight, about 110 in third, and really close to 80 in second. I will also say that this car turns into a dog in 5th. It accelerates, but not as vigorously. Any time I grabbed 5th, it almost felt like a bog.
I did a T56 swap with 4:10 gears in my third gen Camaro and it is much more fun to shift because you go through the gears so fast. I think the gear spread on our cars is not suited for track use. It works, but GM should have changed the ratios for the track oriented packages. |
#21 | |
1khp_1le
Drives: 2019 1LE/ss 2014 ss/rs summit white Join Date: May 2016
#22 |
![]() ![]() Drives: 2018 Camaro SS 1LE Join Date: Jul 2018
Let's see the video... :-)
Everyone says the LT1 will blow with boost on a long pull...I'm hoping not.
#23 | |
![]() Drives: Chevrolet Camaro Join Date: May 2020
0-60 and 1/4 mile reality in Texas
My BEST, on DIRTY, DUSTY, low grip DFW Texas access rds and finishing slightly uphill in A10, was a 12.2 sec 1/4 mile in A10, recording also, my best and ONLY 4.2 sec 0-60 time!!! Learning LC on the M6 was NOT easy learning curve, and I STILL botch my throttle position going from 1st to 2nd a third of the time LOL Having said that, in same no access, access road, I managed a BEST 1/4 mile of 12.3 with manual, however, it showed a 0-60 of only 4.6 seconds?! Having said that, a couple weeks later, I found some reasonable asphalt, still a bit dirty and kind of a hump, and I clicked my FIRST EVER (and only to date), 0-60 time matching best of A10, with a 4.2 seconds!!! IN A MANUAL WHOO HOO!!! I’d ONLY ever clocked 4.3s in attempting a 0-60 time only, in my A10... so this is ONLY 0-60 only attempt that I’d clocked a 4.2, the other one was during a 1/4 mile attempt. That being the case, I truly believe, in 58-63* temperature, on a flat and clean asphalt surface, no burn out, no prep, mathematically a 11.9 sec 1/4 mile is a GIVEN, but I think under ideal conditions, an 11.7 sec 1/4 mile is possible?! Ps the onboard computer never shows the speed at 1/4 mile, which might be a nice addition to the software, Chevy??? But all things being equal, a best time of 12.3 with a 0.4 seconds too slow 0-60, on crappy conc-phalt in Texas, let’s me know better numbers are most assuredly doable!!! |
#24 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '18 1SS 1LE Join Date: Sep 2017
Your throttle position should be on the floor, can't really botch that.
'18 1SS 1LE Black, PDR
#25 | |
Yeah, that works in Mustang GT, I’ve had 4, go to my YouTube channel and research before thinking I’m a noob?! All due respect, of 100+ Autocrossers, Starter says, “Other than the (2 Pro driven) Teslas, you DO look the fastest off the line!” https://youtu.be/Y6SPtw8Kfm8 |
#26 | |
![]() ![]() ![]() ![]() ![]() Drives: 2013 C6Z06 Join Date: Nov 2016
#27 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
I made an Excel sheet for this when I was bored in the past. Made it for a few cars I had.
I have read about the LC in the manual but I don't recall reading NLS just yet.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
#28 | |
First time on the Continentals and I got a good chirp which the Goodyears never did, Goodyears either grabbed or silently spun. It took me some time to actually try the NLS as it goes against decades of instinct, when I finally tried it I was hooked. Do some research before thinking I'm a noob.
| Tags |
| m6 tremec gear ratio ss 1le |
