#15 | |
![]() ![]() Drives: 2017 50th Anniversary 2SS Join Date: Sep 2016
I've got the same tires and the exact same problems!. I was hoping with the warmer weather coming that they might start gripping better but so far anything 70 degrees or under it's dicey.
#16 |
![]() ![]() Drives: 2016 Camaro 2SS Join Date: Mar 2016
Sounds like torque management to me you will never know without logs tho. These cars act so differently at the track vs the street once you deviate from a stock tune its ridiculous. Does the car let you do the burnout without any issues?
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB Rotofab ARH 1 7/8 longtubes hi flow cats AFM deleted E85 11.0@124.9 11.65@118.8 pump gas,stock tune/exhaust New combo: Pray Performance Heads/cam MSD intake manifold and Circle D 3C 554/491 on E85 all work & tuning done by Pray |
#17 |
![]() Drives: 1SS Summit White 6 speed Join Date: Jul 2017
Update
Got returned and car runs much better Will post a thread about it
16 1SS M6 White
Magnuson 2.3 Heartbeat Roto Fab Solo Performance Cat deletes and Axleback Hurst short shifter #'s coming soon Riaction coilovers 1LE sway bars BMR mm BMR chassis brace Flow one 19" wheels wrapped in Mickey Thompsons 02 Z28 M6 35th anniversary 80k miles T-tops Leather Bolt ons Joy to drive this classic every day! Daily Driver |
#18 |
![]() Drives: 2018 red hot 1le Join Date: Apr 2015
I am having an issue after my Vortech install. I believe my throttle is closing in one spot because I here the bypass loose boost and and then car just stops. It only does it 3 times out of ten at medium throttle in 2nd gear and sometimes 3rd at 3-3500rpm. If you do a pull from 1st through4th no issues at all. I have checked everything that is mechanical and can’t find it so I am waiting for my tuner to take it back and see if it’s in settings somewhere. I have an 18 and he said tuning looks different on the 18s than the 16 or 17. I seem to be the ginnea pig for the 18 and I am not liking it one bit. Any suggestions would be appreciated.
#19 | |
My initial tune was waaaaayy off I found another guy with alot of experience with 6th gens and he corrected everything
16 1SS M6 White
