#15 | |
I used to be Dragoneye...
With properly adjusted mirrors, you can watch a car go from the rearview, to the sideview, to your peripheral vision seamlessly. |
#16 |
![]() ![]() Drives: Former 2016 Camaro 1LT Join Date: Jan 2017
I will try re-adjusting the mirrors. I usually have had 4 door cars and can see through the rear doors glass that blind spot so it could be I need to get used to using just the mirrors after i adjust them. My C4 is a 2 door but has huge rear window glass and it is easy to see all around and behind.
2006 C6 Corvette Manual, 2019 Silverado, 1997 Jeep Wrangler
#17 |
![]() Drives: 2017 2SS black on black on black. Join Date: May 2017
Properly adjusted seat and Mirrors. As mentioned about the mirrors, rear view, side view, peripheral.
Consider this. Its like driving a big Van truck. You have giant blind spots. Note how truckers use their mirrors while driving. Looking right, front, left, and keeping track of traffic as mentioned. And when backing into a garage or parking stall, the same thing, use your mirrors. The blind spot detectors work great, as well as the back up camera. But you need to use your mirrors. After a while this becomes second nature. |
#18 |
![]() ![]() Drives: Tesla M3 LR-AWD [Former 1SS owner] Join Date: Jan 2018
Don't feel bad. Most don't adjust their mirrors correctly. As repeated above many times, adjust them more outward.
#19 |
![]() Drives: 2017 Arctic Blue 2SS Join Date: May 2015
I traded in a pickup truck for my 2014 Camaro. The visibility difference to me at the time was astounding. After one near miss like you mentioned, I looked up mirror adjustment and never had a problem in the next 3 years of ownership.
Now with my 2017 Camaro, I have the blind spot indicators but I have never been in a position where I have noticed them on and there been a car that I haven't seen. The inside line of the next lane ends on the inside corner of my side view mirrors and I have very little overlap between side view and rear view mirrors, none of my fender is visible from my normal driving position. This can be disorienting at first, but doesn't take long to adjust. Maybe 2 days or so. Usually in threads like this, someone is quick to post the infographic of proper mirror adjustment. |
#20 |
![]() Drives: 2016 Camaro 2SS Join Date: Nov 2016
GM really screwed up not making the blind spot monitoring standard on ALL models, not just the 2SS. I don't know what I'd do without it. Like you said you can't see anything if you turn your head because of the giant b and c pillars plus small window.
Sent from my iPhone using Tapatalk |
#21 | |
![]() ![]() ![]() ![]() Drives: '16 2SS GD1 MX0 NPP F55 IO6 Join Date: Jun 2013
Rear mirror, center and then move slightly toward driver side of rear window. Side mirrors, adjust outward until there is no overlap between rear view mirror from 20-30 ft away. On the road,, when done correctly, you should notice that when a vehicle starts to leave your rear view mirror (passing you), that they begin appearing in your side view mirror. And when they leave your side view mirror (still passing you), they are now visible along side your car without the need to turn your head over your shoulder. The rear quarter windows are pointless because the seats do not allow you to position yourself far enough back to require them. If you have a 2SS, you'll notice that the auto-down mirror function actually pulls the mirror in slightly and tilts it down for curb checks. If you need to see straight down the side of your car, then you can lean your head a little toward the mirror and you'll just barely see the edge of the rear wheel arches. Prior to backup cameras, the appropriate tilt of side view mirrors was to set the bottom edge of the mirror at the same height as the back/lower edge of your car, so you would know that when a curb started disappearing from the mirror it was going under your bumper. Now with the cameras and auto-down features, you can set the mirror tilt to a more head oriented position based on your desired seating position. And even in a bunker, blind-spot monitoring is not required. It is only a popular feature because so many people don't know how to drive safely. A lot of people out there actually think the old 10 & 2 thing is still true, but it's not. When both hands are on the wheel, they should not be above 9 & 3. One reason is because of arm injuries from airbags and cab-forward windshield designs during a crash. The other reason is that you are limiting your range of control before you must let go of the wheel to move your hands. The best position is actually 730 & 430, where you can rotate a single hand 270-degrees without releasing your fingers from the wheel. Every effort should be made to retrain your brain to stop placing both arms over the top of the wheel and blocking your view of the instrument panel without the need to move your hands. |
#22 |
![]() ![]() ![]() ![]() ![]() Drives: Crush ZLE M6 | 2000 Corvette FRC Join Date: Jun 2010
Look out the side window you intend to change lanes into. Ensure there are no cars directly next to you, or slightly ahead. Let the bald eagles fly that you chose Camaro for and move into the spot you just ensured is open. No mirrors needed. No looking back needed.
Jokes aside (although I kinda DO do that).....I’m old school and learned to adjust my mirrors so that you can just barrrrrrely see your fender in it still. Gives a good visual reference point. I’ll have to try the “new” or “correct” method others and that article illustrate. I predict I will have a hard time growing accustomed to it. |
#23 |
![]() Drives: Red Hot SS 1LE Join Date: Dec 2015
From what I read just buy a Mustang! Those cars are perfect!!
#24 | |
Retired fr GM + SP Global
Drives: 2017 Camaro Fifty SS Convertible Join Date: Mar 2017
OP... You have a 2LT with RS...does that include the Side Blind Zone Indicator in the sideview mirrors?
A8 | MRC | NPP | Nav | HUD | GM Performance CAI | Tony Mamo LT1 V2 Ported TB | Kooks 1-7/8” LT Headers | FlexFuel Tune | Thinkware Q800 Pro front and rear dash cam | Charcoal Tint for Taillights and 3rd Brakelight | Orange and Carbon Fiber Bowties | 1LE Wheels in Gunmetal Gray | Carbon Fiber Interior Overlays | Novistretch bra and mirror covers | Tow hitch for bicycle rack | |
#25 |
![]() Drives: 2022 SS 1LE Join Date: Aug 2017
You can also move your head/body forwards to increase the range of visibility from the side mirrors. I've learnt to physically lean forwards while looking in the side mirrors to increase the range of coverage. Even with correctly positioned mirrors, this is a very quick move that's an easy habit to adopt but gives me even more assurance that I've not missed anything...
As others have said, whatever method you adopt, make sure you test it thoroughly so when a car passes you (or you pass them but either way do it slowly) you're able to track them all the way and not lose them for a second... Hope this helps, Pete. |
#26 |
I initially wanted the 2SS for the electronic assistance as the complaints about the Camaro's visibility wasn't flattering. Even the well-known publications were outright critical of it.
The 2SS had these features, so that was what I was going to get in the name of safety. The other features weren't that important. Then I test drove the 1SS and bought it without a second thought. I saw absolutely no need for any blind spot assistance. The windows and mirrors had all the important points covered. And to top that off, my wallet secretly thanked me on the way home. |
#27 |
![]() Drives: 2016 Summit White Camaro SS (2SS) Join Date: Oct 2016
I'll be the sucker to suggest it, blind spot mirrors. https://smile.amazon.com/s/ref=nb_sb...=348DXMGMCA0XA
If you can swallow your pride and handle the aesthetics hit. |
#28 |
![]() ![]() ![]() ![]() ![]() Drives: 18 Silverado 1500 Join Date: Dec 2015
Lol! Best advice.
