Old 01-28-2018, 07:24 PM   #15
shinysun
Drives: 2016 Camaro SS
I am using this one.
shinysun is offline   Reply With Quote
Old 01-28-2018, 07:50 PM   #16
shinysun
Btw, I got reported qutie few cars had the front seal blow here in Korea, too.
The solution for it is adding another breather or opening all PCV lines and breathers to the air (seems stock pcv system is not working properly for FI engine.) , then...
https://youtu.be/2lFEjeDrrrY
the amount of the gas is different depends on the engine, but, usually you can see quite excessive blowbygas from all breathers like the link.
even with the blowbygas , the car is working well without any noise and abnormal sound from the engine and still fast (the dyno number is still the same as before)
What I am wondering is whether the engine is Ok or not with the situation.
Have anyone tried to checked the pistons and rings with the seal blown?
Old 01-28-2018, 08:05 PM   #17
parish8
Drives: 17 SS a8
Shinysun, I don’t think that yellow cap offers enough extra breathing for a boosted motor. I have a 5/8” hose from each valve cover to a catch can/breather and will probably still add a fill cap breather.
Old 01-28-2018, 08:21 PM   #18
shinysun
Nice system.
Where are the 2 x 5/8" hoses going? to air vent?
I just added a fill cap breather, but seems ok so far.
Old 01-28-2018, 08:32 PM   #19
parish8
Drives: 17 SS a8
They goto a vented catch can. You can see the top of the filter in the pic.
Old 01-28-2018, 08:41 PM   #20
laynlo15
Drives: 2022 Lt1 A10
So Parish are you going to spray a little NOS to spool the turbos?
Old 01-28-2018, 08:49 PM   #21
parish8
Drives: 17 SS a8
I all ready did. a 100 shot right off the line until it hits ~5psi. it dropped me from a 6.88 to a 6.48 in the 1/8th. I will be running a circle D converter in the spring so I am not sure what I will need to do but with some forged pistons and a converter to get the rpms up a little off the line I will be able to spray more than a 100shot if I need to. that being said with the converter I may not need too. I will have a lot of adjustability in when and how much power I want to make.
Old 01-29-2018, 01:20 PM   #22
Capt Insaino
Drives: Fifty Anniversary Camaro
I was worried about this as well, which is why I ran the Might Mouse wild catch can. One hose runs from the oil cap (The catch can came with a new fitting to replace the factory oil cap) and the other hose ran to the throttle body and capping off the valley cover connector. I hope it does the trick.
Capt Insaino is offline   Reply With Quote
Old 01-29-2018, 01:34 PM   #23
Dysan911
Dysan911's Avatar
Drives: 2017 50th Anniversary 2SS
Tight fit with the procharger but fits nonetheless.
Metco 1 way valve cover breather.
Dysan911 is offline   Reply With Quote
Old 01-29-2018, 02:47 PM   #24
oldman
Drives: SS 6 speed of course
If you installed your procharger, please look at my post on the shrouds.
Old 01-29-2018, 03:44 PM   #25
Joe's_cool_1le
Drives: Black 2017 Camaro SS 1LE
Looks like a larger issue. Was told compression was equalling lower on cylinders 4 and 6. Pulling the motor. More info to come.
2017 1LE SS Black - Mods - Forged - lowered compression - BTR custom Cam - Whipple, 3.500 upper and 8.0 lower pulley, Roto-Fab, 1 7/8 Kooks headers, off road pipes, & 3" Kooks full exhaust. LT4 fuel system, with Alky single nozzle running 100% meth. (not installed yet) DSX Tuning flex fuel and DSX tuning Aux pump
Joe's_cool_1le is offline   Reply With Quote
Old 01-29-2018, 04:08 PM   #26
parish8
Drives: 17 SS a8
Bummer
Old 01-29-2018, 05:33 PM   #27
oldman
I'm still thinking drop-in now, while the engine is apart. What boost and HP were you running?
Old 01-29-2018, 05:55 PM   #28
Joe's_cool_1le
Was sitting just over 600 @ about 9-10 PSI with about 14k hard miles. It would be hard not to do a bunch of stuff while the engines out.
