Go Back   CAMARO6 > CAMARO6.com General Forums > Z/28 Discussions
Old 01-23-2018, 08:59 PM   #15
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Originally Posted by 2SSRS@Gen5diy View Post
Only time will tell, but i dont see them updating the ZL1LE, at the risk of pissing off all the ZL1LE owners they now have, it will have a different name when it comes out, if its a N.A. car they will call it a Z/28 if its not N.A. then a new Name, i still hope for the Z/28.
Originally Posted by DevilsReject97 View Post
Could very easily see it as an upgrade package available to both old/new customers. And, I can absolutely see it being similar to them offering the 1LE package solo....
I was just going to say something like that. What if they were working on a Chevy Performance Parts upgrade?
Old 01-23-2018, 09:23 PM   #16
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Or just maybe with all that paradigm shift talk Al was subtly hinting about a LT5 Z/28...
Old 01-23-2018, 09:31 PM   #17
waterman
waterman's Avatar
Drives: Grandad's C2 L89
There are some truly amazing cars being produced and on the drawing board.
Gentlemen, It's a great time to be alive.
Aside of the missile threats and tsunami warnings, but that's a story for another day.
2018 ZL1 1LE sw/PDR
Old 01-23-2018, 10:49 PM   #18
SamHouseIII
I Carry!
SamHouseIII's Avatar
Drives: 2013 CRT ZL1
When a corporate rep, or Chief Engineer, says wouldn’t it be nice to see Sub 7 sec times, it’s been done and they know it. Not going to throw that out there and not be able to back it up.
BTW my last Trip to Yuma (YPG), Ealry Dec, heard some interesting, high Reving testing going on at the test track.
I am a Modaholic!! Please Help!! Do Not feed my addicition....See build...
http://www.camaro5.com/forums/showthread.php?t=261540
From Oklahoma, Join us on Facebook
https://www.facebook.com/groups/okcamaros/
SamHouseIII is offline   Reply With Quote
Old 01-23-2018, 11:02 PM   #19
Mr. Wyndham
I thought the exact same thing when I read that.
7:16 (official), 7:13 (claimed off-record) lap times are already ridiculous and hard to believe. The mere concept of a sub 7-minute lap time actually fries my brain a little bit.
Old 01-23-2018, 11:16 PM   #20
Artos
Artos's Avatar
Drives: A10 LT4
Never thought I would see an LT4 with a Camaro badge...seeing GM drop an LT5 produced from an assembly line is pretty easy to visualize. Gotta love the possibilities.
Artos is offline   Reply With Quote
Old 01-23-2018, 11:38 PM   #21
camaro5
camaro5's Avatar
Drives: X-15 Velocipede
LT5, strip out all those ZL1 convenience items for weight reduction
7-speed manual
Ceramic brakes
Could be hints of Z28...
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer
STANDARD DISCLAIMER
camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever,
whether express, implied, or statutory, including, but not limited to, any warranty of merchantability
or fitness for a particular purpose or any warranty that the contents of the information will be error-free.
camaro5 is offline   Reply With Quote
Old 01-24-2018, 03:20 AM   #22
MrChrisLS3
Drives: 2018 1SS M6
we’re looking at any available horsepower that will fit in the car, trying to stay relevant and on top.
I'm pretty sure this means LT5. The only way it doesn't is if they have a more powerful engine in the works for the mid engine Corvette. The issue then would be if the unibody could handle it.
The LT5 is nearly 100 more horses than the LT4, with an incredible torque band. Pull some weight here, reinforce there, some big stopping power, and some Krazy Glue tires, the Z1le might get there.
Either way, for all of us guessing what direction they're going with the Z/28, here's your answer. It's going to be another low production Halo car with only one purpose in life, to run the ring in under 7 minutes.
MrChrisLS3 is offline   Reply With Quote
Old 01-24-2018, 08:03 AM   #23
Smokin19
Drives: 19' ZL1 A10, w/pdr
Is it possible they might go with a NA LT-7 or a LT-6? I think that is something they might have up their sleeve.
http://gmauthority.com/blog/2017/03/...ock-v8-engine/
Smokin19 is offline   Reply With Quote
Old 01-24-2018, 09:15 AM   #24
Quinten_33
Quinten_33's Avatar
Drives: Silverado
The LT7 is twin turbo. However, The GM authority report is a very early one that sites the use of Dual injection and a 5.5 Liter V8. The analytic reports from the latter part of 2017 all say that a 5.5 Liter V8 would be used in the Mid-Engine Vette, and no use of dual injection was publically known until the LT5 debuted. The source of that LT6 rumor knows something that we don't.
Quinten_33 is offline   Reply With Quote
Old 01-24-2018, 09:22 AM   #25
Bhobbs
Bhobbs's Avatar
I don’t buy a 5.5 L n/a small block that can make 700 hp. Look at how much Ford struggled just to get 526, with the 5.2.
There is no engine for the Z/28 and there won’t be. That was set when Corvette decided to go supercharged with everything.
Old 01-24-2018, 09:22 AM   #26
FNxR3DNECK
FNxR3DNECK's Avatar
Drives: 2017 SS 1LE
I think we need to wait and see how deep under 7min the ZR1 will go (it will ABSOLUTELY be under 7min, probably under 6:50) before we get our hopes up about a sub 7 Camaro. Would an LT5 powered ZL1 1LE with Carbon Ceramic brakes be able to break the 7min mark? Definitely, but would Chevy put the LT5 in the Camaro is the big question there.... I think a more interesting option and maybe even more likely is a stripped out, 600ish HP Camaro with DSSVs and way more Aero that weighs around 200lbs less than a ZL1 1LE (even lighter if possible but that may be stretching the realm of possibility).
For the ZR1 Chevy took the more power + more Aero route, with the downside of some gained weight. I think the less weight + more Aero approach with slightly less power could get similar results with the Camaro.
IG: @NC_M1SS1LE
Old 01-24-2018, 09:38 AM   #27
FNxR3DNECK
FNxR3DNECK's Avatar
Drives: 2017 SS 1LE
Idk about that.... we have seen the leaked CAD images of the TT V8 for the Mid-engine Vette and what appears to be an N/A V8 as well, so who's to say that engine can't make it's way to a Z/28?!?
I too really doubt the possibility of a 700 HP 5.5L, but don't you think it is possible for around 600HP from a Dual-injection LT? Chevy went that route for the LT5 so there's probably about a 99% the rest of these new engines will also be Dual-injected.
IG: @NC_M1SS1LE
Old 01-24-2018, 09:39 AM   #28
shaffe
Drives: 21 Bronco
Don't you read anything around here, GM can easily outdo anything Ford does (END SARCASM) But yes I agree, look what ford had to do to get over 500HP. It had to rev to the moon.
There is the answer. Corvette is already a car people would be willing to spend over 100K for. they could have gone light weight, more aero, and slightly less power to beat the ACR time. They did not go that route. They went the route of throwing more power at it, with extensive aero. The ACR only weighed 3300 pounds (if what I saw was correct) Even if they dropped 200 pounds from the ZLE that would only put the Camaro at 3600 pounds. Still 300 pounds heavier than the viper and down on power. I just don't see it being an NA Camaro that does that.
And if anyone brings up the Mercury Marine 7.0L that engine won't pass emissions in it's current set up. So they would have to dial it back. How much they would have to dial it back is unknown, but if they dial back enough does it still have an advantage over the LT4 or LT5?
Yeah I could see maybe 550+ HP out of that NA 5.5. That very well could be the perfect engine for a Z/28. IMO that won't give it enough power to overcome the what the ZLE has accomplished already though
Lets keep it simple. ..
