Old 01-22-2018, 10:34 AM   #15
speedraider
speedraider's Avatar
Drives: 2016 Z06, 2017 ZL1
I will I'm letting the paint dry more so If I do need to pull off the paint stays on lol!
speedraider is offline   Reply With Quote
Old 01-22-2018, 11:15 AM   #16
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
I may use silicone to hold on to fill gap as far as holding then on they look good I was worried about tape having a gap slightly.
Old 01-22-2018, 11:43 AM   #17
speedraider
did you remove the mirrors to paint them. If so, how do you remove them
Old 01-22-2018, 12:07 PM   #18
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Just watch lethal camaro you tube on door trim
Old 01-23-2018, 06:05 AM   #19
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Yes..
easy to do
I used 400 grit wet sanded..
I used the Primer by Spraymaxx W hardner
I Used Hot rod Satin by spraymaxx W hardner
I just taped glass friend from gm sent me glass removal technique but it said the glass could break so I just taped up glass
Be sure to do the cracks lines very good first and between mirror glass and frame.. then coat the entire surface. this will ensure no areas left uncovered..
