Old 01-14-2018, 01:47 PM   #15
Busted43
Busted43's Avatar
Drives: 2018 zl1,A10,16 GLC300
Originally Posted by Badmojo View Post
What is the maximum safe RWHP that the stock LT4 fuel system with a tune can support? Can the stock system support a pulley/exhaust car?
+1
2018 ABM,A10
Kooks 2” headers no cats, NW 103 Tb, Kong ported blower with 2.31 pully, Elite E2x catch can, Cordes under hood expansion tank, Flowmaster axle back, Rotofab dry filter,Mustang Dyno # 647whp/674wtq.
Busted43 is offline   Reply With Quote
Old 01-14-2018, 04:31 PM   #16
ZL1 1LE
@zle_blackwing
ZL1 1LE's Avatar
Drives: 2018 ZL1 1LE
Originally Posted by WEAPON-X View Post
Absolutely, always run a catch can, even with port or meth injection.
Firstly, thanks for sharing your knowledge. Secondly, do you have a recommendation for a catch can for the ZL1 LT4?
Old 01-14-2018, 05:44 PM   #17
waterman
waterman's Avatar
Drives: Grandad's C2 L89
ZL1,
I have been researching this extensively for a few months. Background; I have seen first hand the result of valve coking, aftercooler/intercooler varnishing and combustion chamber deposits on Tier level (ECM equipped. emissions compliant) four stroke marine diesels that are not equipped with breather bypass and catch cans. All a result of direct injection.
After communicating with numerous vendors, I was most impressed with Mishimoto, Mightymouse and Elite Engineering. When Elite released the EX-2-2 stage CC it became a no brainer for me. Whatever route that you decide to pursue, make sure that you find a system that bypasses the OEM PCV. Without that bypass, all of the corrosive and clogging byproducts of blow by will continue to be introduced to your intake and then ultimately into your combustion chamber and onto intake valves.
I helped a friend install a can on his Z06 at just shy of 2000 miles. Although there was no varnishing on the intercoolers yet. The amount of oil and undoubtedly other nasty compounds inside of the SC was appalling. I only lifted the SC so there was no way to see the back side of the intake valves or the piston tops.
A CC will without question, be installed on my Z as soon as it arrives.
The question always arises; If a CC is so important, then why doesn't GM install them OEM? Easy answer, extra maintenance with a risk. If you don't remember to drain your can, your LT4 will be in a world of sh*t.
2018 ZL1 1LE sw/PDR
Old 01-14-2018, 07:14 PM   #18
WEAPON-X
WEAPON-X's Avatar
Drives: ZL1 ATS-V CTS-V C7Z Range Sport SC
Great Thread...!
Now we need a list of what the stock fuel system can handle.
Hope to see you guys back at the Fest this year too.
I have our X packages up now, so you can see we can go all the way up to our X800 package without touching the fuel system and we've hit nearly 700whp/wtq on our dyno with it!
Originally Posted by MR 45TH View Post
Great write up, and thanks for the info
What would you say is on target?
That depends on the tuner, we've seen some cars come in from other shops being nearly 20% off; however, that's just asking for trouble IMO. The OEM system with 10psi wants 2,900 PSI of fuel pressure to overcome cylinder pressure. When increasing the boost 3-5 PSI, the cylinder pressure increases too, so I recommend staying as close to target as possible. It will always fluctuate some, but I like to see about -5% minimum.
Originally Posted by Busted43 View Post
+1
This is subjective depending on the dyno of course since some are loose and some are stingy, but we can run our stage 4 pulley with it and hit nearly 700whp on our dyno. We did this on Hempstead's car here. I need to find his dyno to post up. Eddie @ WEAPON-X was supposed to be getting Mike's build thread up here soon anyway.
Our X800 package is about as much as you can get out of the OEM fuel system without modification:
https://weaponxmotorsports.com/produ...-zl1-gen-6-lt4
WEAPON-X is offline   Reply With Quote
Old 01-14-2018, 07:16 PM   #19
WEAPON-X
WEAPON-X's Avatar
We're about to release a pretty revolutionary catch can, I've been working on it for a little while, trying to get back to it because I need it on my ZL1 with the turbo. Until then, this is what you'll want:
https://weaponxmotorsports.com/produ...te-cts-v-ls-lt
Old 01-14-2018, 08:39 PM   #20
ZL1 1LE
@zle_blackwing
ZL1 1LE's Avatar
ZL1,
Thank you!
Old 01-14-2018, 08:40 PM   #21
ZL1 1LE
@zle_blackwing
ZL1 1LE's Avatar
Thanks, any idea how long until release?
Old 01-14-2018, 10:07 PM   #22
ReevZL1
ReevZL1's Avatar
Drives: 2019 Chevy Camaro ZL1 A10
Thanks again Weapon X for all the innovative parts you guys design, engineer, make and test. I'll be ordering your port injection, fuel system package soon!
ReevZL1 is offline   Reply With Quote
Old 01-15-2018, 10:37 AM   #23
Ricco
Ricco's Avatar
Drives: 2018 ZL1 Vert A10
Great post. Still makes me wonder what combination of all of these options you recommend, based on power goals.
2018 ZL1 Vert - 854Whp / 791Wtq
2016 BRZ
2013 X5D
2005 STI
2001 2.5 RS
Previous cars in chronological order
2016 GT350, 2014 MEV Rocket, 2013 Nissan Qashqai + 2, 1.6L Diesel, 2010 Nissan Note 1.5L Diesel, 2012 Dodge Ram 2500 6.7L Cummins, 2009 Subaru Impreza STI, 2005 Dodge Ram 1500, 2004 Mini Cooper S, 1997 Subaru Impreza Catalunya special Edition, 1992 Daihatsu Charade GTti, 1978 Mk1 Ford Fiesta
Ricco is offline   Reply With Quote
Old 01-15-2018, 02:26 PM   #24
ZL1_IslandBreeze
Drives: camaro
outstanding writeup for the LT4
i went with #2,3,4,5 and flex fuel
did not want meth for all the quoted reasons... others dont mind meth but as you state its an option.
very happy with the build as a daily driver...
again, great writeup!
ZL1_IslandBreeze is offline   Reply With Quote
Old 01-15-2018, 04:37 PM   #25
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
This absolutely needs to be a sticky. There's questions about this damn near everyday. Good job Ben.
Old 01-15-2018, 04:39 PM   #26
Can'tHave2MuchHP
Drives: Fast
Yes it can support a Pulley/Header/Intake/Tune build. The LT4 should be able to do about 630-650 RWHP on 93 with no supplemental help.
Old 01-15-2018, 06:56 PM   #27
TDS
TDS's Avatar
Drives: 2019 Jeep Rubicon Sold:2017 ZL1 A10
Sub
Travis
SOLD ZL1 Summit White, A10, Black Strip, PDR, ZL1 floor mats
Ordered 2/11, 2000 2/14, 3000 2/20, 3100 2/24, 3300 3/7, 3400 3/8, 4300 3/16, 4B00 3/21 Bayed at train yard in Ohio, 4200 3/26 All Abroad for the West Coast, 4800 4/4 Deliverd to portland train yard, 5000 4/7 3:00AM Deliverd to Dealer, 6000 4/7 6:45PM Delivered to Customer
TDS is offline   Reply With Quote
Old 01-15-2018, 08:01 PM   #28
Harry76
Harry76's Avatar
Drives: 2018 ZL1 A10 Nightfall Gray
This is an excellent thread Ben, I plan on coming to see you this spring to see about a few more mods.
Here's my Dyno Sheet.
Harry76 is offline   Reply With Quote
cam, fuel, injectors, port injection, pump
