Old 01-10-2018, 12:23 PM   #15
Bongos2U
Drives: Hopefully 6th gen Camaro
Originally Posted by ecko04 View Post
Yeah very dicey situation.
When I picked mine up from Iowa driving back to D.C., I planned the route and gave myself several days to make it back just in case weather took a turn for the worst in the Midwest. When the sun began to set for the day, it was time for me to check in for the night.
Snow tires may not be the best fit for your climate. If it rarely snows then snow tires may be worse for your situation than all season tires. Depending on where you live, a set of all season, or snow, rubber and wheels will suffice until the spring rolls around.
When I lived in PA, I had a dedicated set of Blizzaks and steel wheels. Now in Maryland, a decent set of all season rubber does the trick with -1” wheels.
Bagged and tagged the summer set for the winter.
Sent from my iPhone using Tapatalk Pro
GM should at least offer all-season tires on the SS as a no cost option from the factory.
Bongos2U is offline   Reply With Quote
Old 01-10-2018, 12:35 PM   #16
SuperSound
SuperSound's Avatar
Drives: '17 Camaro 2SS A8
There was some dumbass driving his GT350 around here the other day in 20 degree weather with snow/ice still on parts of the road. Don't know how you can that kind of money but be that stupid. My car was safely parked in the garage for this reason.
Old 01-10-2018, 01:12 PM   #17
fastball
Drives: 2017 Camaro 2SS 6MT
Originally Posted by brettman View Post
Get a "WEATHER BEATER". I put my Camaro away and drive my 07 (39,000 miles) Silverado 4X4. Hell, I see a small accident is close to a "TOTAL" on these cars. Not to mention the "SALT" damage up here...Just a thought. Good to hear you didn't lose it.
With winter tires, this car is a blast in the snow! Very good traction on my 20" Blizzaks, and I tried her out at the mall parking lot after we had our last big snow and turned off all the electronic nannies - you can really get this car to do what you want it to do in 6" of snow!
fastball is offline   Reply With Quote
Old 01-10-2018, 01:24 PM   #18
Frank237
Frank237's Avatar
Drives: Kubota 2640, 83 BMW R-65, 2017 1 SS
And yet....There are all sorts of posts stating they do fine in cold weather with the stock Goodyears/Summer performance tires. I have a hard time believing that.
Frank237 is offline   Reply With Quote
Old 01-10-2018, 01:49 PM   #19
SuperSound
SuperSound's Avatar
My understanding is under 45-40 degrees, there is reduced traction. Under 32, there is a strong possibility of cracking on top of more reduced traction.
I have drove mine in that 32-40 degree range with no real issues, but also I'm consciously driving much more careful, using the Snow/Ice mode as well.
Old 01-10-2018, 01:58 PM   #20
Stig eh
Drives: 2017 SS 50th Jan 17 2018
Agreed and more to the point GM should offer a set of tires complete at each dealer at a great cost as the dealer or new car owner could sell ost of the original equipment tires for the summer at almost what the all season cost or for more
Stig eh
Stig eh is offline   Reply With Quote
Old 01-10-2018, 02:13 PM   #21
fastball
Not something I'd even think about trying. In the temps we've been having, down to 0 with -10 degree wind chills, the tire will never begin to warm up no matter how long your drive is.
Maybe that's something worth trying to invent. Tire heaters for winter driving.
Old 01-10-2018, 02:31 PM   #22
ctrlz
some members here have had the run-flats swapped out for all-seasons at the time of sale as part of the deal
Old 01-10-2018, 02:51 PM   #23
1CEBITN
Drives: 2017 Camaro SS Vert w/2SS
This might be a side conversation but those of you who have thrown out the run-flats for all season tires, what is your plan if you are several hundred miles from home on a trip and you have a blow out that is not pluggable? I don't for the life of me know why manufacturers seem to think they don't need a spare tire with run-flats. I hit a pothole in my 335i years ago, which had runflats, and it put a gash in the sidewall so the runflats were of zero use. Luckily I had bought myself a spare tire kit from a 5-series so I made it home. Nobody carries tires in the sizes our cars use so you will be stuck for 2-3 days waiting on a tire if you aren't close to home when something like that happens.
1CEBITN is offline   Reply With Quote
Old 01-10-2018, 03:11 PM   #24
Allez
Allez's Avatar
According to the manual you can have reduced traction under 40 degrees, and the possibility of cracking under 20. I drove mine yesterday with the temps in the upper 30s with no problem; I was a bit more cautious, though.
Allez is offline   Reply With Quote
Old 01-10-2018, 03:23 PM   #25
SDG23
SDG23's Avatar
Drives: 2017 Camaro SS M6
I still have the stock summer tires on mine and got it out a few days back when it was about 20 degrees out. Traction wasn't a "sure" as usual, but as long as you drive remotely normal it's not likely going to cause a problem. I got sideways twice, but that was purely by intent Even if it's cold out, once the tires warm up a bit you should be okay, again if you drive reasonably.
2017 Camaro 1SS - Bright Yellow - 6spd
SDG23 is offline   Reply With Quote
Old 01-10-2018, 03:52 PM   #26
SuperSound
SuperSound's Avatar
AAA or other roadside assistance companies are the best option. Your story is exactly why RFTs are not worth it to begin with IMO.
Ah knew there were 2 temps given but didn't remember what they were exactly.
Old 01-10-2018, 04:06 PM   #27
L99BEN
L99BEN's Avatar
Drives: 2023 BMW M4 Competition
Originally Posted by mako22 View Post
If there are any of you out there that (like me) figured they could "get by" this winter without getting all-weather tires on your Camaro - let this be your warning.
I took my chances in 20 degree weather today and took the car out of the garage on the stock tires. On the highway, I went to make a simple lane change with light acceleration and completely lost traction - car went sideways one way, then the other before I got it under control. Fortunately no one was in the far left lane or I would have been in a massive wreck.
And yes I understand it this is my fault, lesson learned.
You probably hit black ice..
I've been daily driving mine 80 miles a day on summer tires without issue. Definitely less traction on cold salty Maryland roads in winter but nothing out of control unless I hit black ice. When real cold out, I drive like the roads are wet from rain.
2023 BMW M4 Competition (daily)
2022 ZLE M6 (weekend toy)
2022 BMW X3m40i
Past:
2022 Tesla S Plaid
2020 Shelby GT500 sold
2019 Hellcat Redeye-traded for new GT500
2019 ZL1 A10 - sold (meh)
2019 Tesla M3P
2016 Hellcat Challenger - A8 sold but never forgotten
2016 Camaro 2SS M6
2014 Mustang GT A6
2012 Mustang GT M6 "brembo" 3.73/FBO
2012 Camaro SS L99 (Wife's)
- slow
L99BEN is offline   Reply With Quote
Old 01-10-2018, 04:15 PM   #28
Kise
Kise's Avatar
Drives: 16' 2SS, 06' Silverado SS
I feel like ive seen your Camaro around the sommerset or Lexington area before.
Kise is offline   Reply With Quote
