Old 01-10-2018, 11:20 AM   #15
HDRDTD
OK, here's a stupid question from an old fart with bad eyes, Why do they say the Camaro in the pictures is a ZL1 1LE ?
It's missing the tall wing at the rear of course, but I also don't see the front dive planes (canards) that the 1LE comes with.
With both items missing (at least to my eyes), what makes it a 1LE ZL1 ???
Old 01-10-2018, 11:25 AM   #16
Ricco
Ricco's Avatar
Drives: 2018 ZL1 Vert A10
2015 Z06/Z07 (with CCM brakes), at 3533lbs, stopped from 60-0 in....91 feet!!!
While I'm not refuting that these are valid comparisons, there are additional factors that can go into these stopping distances. The Tires being a primary factor, heat and heat retention being others. CCB were designed for racing where they are subject to sustained and prolonged periods of heavy braking that may not necessarily be possible with iron brakes.
Bottom line, more factors to consider when selecting your brake materials than just a single stopping distance test.
Just food for thought.
2018 ZL1 Vert - 854Whp / 791Wtq
2016 BRZ
2013 X5D
2005 STI
2001 2.5 RS
Previous cars in chronological order
2016 GT350, 2014 MEV Rocket, 2013 Nissan Qashqai + 2, 1.6L Diesel, 2010 Nissan Note 1.5L Diesel, 2012 Dodge Ram 2500 6.7L Cummins, 2009 Subaru Impreza STI, 2005 Dodge Ram 1500, 2004 Mini Cooper S, 1997 Subaru Impreza Catalunya special Edition, 1992 Daihatsu Charade GTti, 1978 Mk1 Ford Fiesta
Ricco is offline   Reply With Quote
Old 01-10-2018, 11:27 AM   #17
Ricco
Ricco's Avatar
I think there are additional pictures where you can see the front splitter and canards more clearly.
I think the car is also running the 19" 1LE wheels and 1LE brake Caliper and similar rotor size.
+ 1LE Tail lights.
2016 BRZ
2013 X5D
2005 STI
2001 2.5 RS
Old 01-10-2018, 11:31 AM   #18
phobos512
Drives: 2017 Audi S3
Turn up the brightness on your monitor, or edit the pic to increase the brightness/contrast. I can see the diveplanes clear as day on my monitor. And as Ricco said, it's got the smoked tails.
phobos512 is offline   Reply With Quote
Old 01-10-2018, 12:23 PM   #19
DevilsReject97
Nightmare
DevilsReject97's Avatar
Drives: Your mom crazy in bed
It has all of the items that make it a 1LE except for the wing. Additionally, it is missing the blacked out 3rd brake light.
I am simply going to say that this was probably just a test mule car and nothing more than that. The only way a Z/28 comes out in this generation is if its something that just destroys the ZL1 1LE in terms of performance. I just don't see GM wasting time building it.
Otherwise, you're going to get a car that's just a bit more than a SS 1LE with some better parts...
Old 01-10-2018, 12:34 PM   #20
Mountain
Mountain's Avatar
Originally Posted by URBAN LEGEND View Post
Hmm. Yet Vettes can have them... GM better put these damn brakes on this 🚘.
Why? In all seriousness, why?
Old 01-10-2018, 12:56 PM   #21
FringBirdAloha
Drives: Pre-production ZL1 M6
105 more horses would destroy a ZL1 1LE.
FringBirdAloha is offline   Reply With Quote
Old 01-10-2018, 01:48 PM   #22
URBAN LEGEND
URBAN LEGEND's Avatar
They’ll last longer on the street, I like the initial brake bite, less dust, lighter, It’s a part they already have, and I like the looks.
🔺22 RS E TRON GT
🔺21 Model S Plaid
URBAN LEGEND is offline   Reply With Quote
Old 01-10-2018, 03:10 PM   #23
ZL1 1LE
@zle_blackwing
ZL1 1LE's Avatar
Drives: 2018 ZL1 1LE
I'm real curious...a little Devil's Advocate work, here:
- Few, if any racing series allow CCM disks.
- Most racers (esp. Porsche) ditch their Carbon brakes for iron replacements for track days due to wear and price.
- They cost a ridiculous amount of money to replace...and they're brittle while servicing.
- Different compound, more aggressive racing pads are more readily available for iron brakes.
- The '14 Z/28 (with CCM brakes), at 3858 lbs, stopped from 60-0mph in 97 ft.
- The '18 ZL1 1LE (with same-sized iron brakes), at 3837, stopped from 60-0mph in 91 ft.
GM/Al have said they didn't see a benefit to using the CCM brakes in either fade resistance or braking distances, so they couldn't justify the cost in utilizing them on the car.
So why do we consider these brakes worth anything other than a party piece?
Weight savings but, at what price?
Old 01-10-2018, 04:46 PM   #24
camaro5
camaro5's Avatar
Drives: X-15 Velocipede
Originally Posted by FringBirdAloha View Post
If it is a Z28, it’s not going to be naturally aspirated. There’s no doubt there are mules running around with LT5’s in them. But develop a new DOHC NA for the Camaro?... nope. Plus any release of an LT5 based Camaro would be at least a year after the ZR1. But we can be sure it’s in the plans.
I think there may have been some fallout over not offering CC brakes and they may be implementing a brakes package.
It would make sense to create a Z/28, mainly based on the fact of a 5.5L coming. Why? The Cadillac DPi’s just switched to a 5.5L (hmmm...). The next Corvette will have a 5.5L (hmm...). The GTLM/GTE Corvettes run 5.5L’s (#muchdata #proven). With that, it makes sense to homologate to the GT4 Camaro, which opens up a business case for the option to create a Z/28 road car. Right now, the GT4 engine is a GM Performance/GM Racing frankenstein. Cost, complexity, durability and marketing wise, it’s a better move to go with the Corvette C8 5.5L.
Take a ZL1 1LE, remove the LT4 and shove in a 5.5L DOHC, or even HOHV, you reduce weight. Remove the rear seats, strip down the creature comforts...
With a 5.5L, you get a more stabil engine for high RPM. You can still get the power performance needed through a shift in the RPM band. Also, a 5.0+L V8 is still large enough to get good mid-range torque. A 5.5L also helps in pro racing because a 5.5L restricted is more efficient and stabil than a 6.2L (BOP - heat management/combustion efficiency) and fuel economy is better. So, a 5.5L also makes sense for the race cars.
The LT6 5.5L DOHC 32 valve is the base 2020 Corvette motor
LT7 is the twin turbo version - Z06
The engines are already a done deal.
Say goodbye to 6.2L and hello to 5.5L DOHC.
Obviously this will all come to the Camaro as it always does.
Will they put the 5.5L in a Z28? Time will tell.
Gen.7 Camaro (Late 2021 release as a 2022) will definitely get the 5.5L DOHC V8's.
l
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer
STANDARD DISCLAIMER
camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever,
whether express, implied, or statutory, including, but not limited to, any warranty of merchantability
or fitness for a particular purpose or any warranty that the contents of the information will be error-free.
camaro5 is offline   Reply With Quote
Old 01-10-2018, 04:50 PM   #25
FringBirdAloha
l
This is Camaro6 not Camaro7. The 2020 whatever they call it isn’t getting a DOHC. The most likely candidate is the LT5. End of story.
Old 01-10-2018, 05:28 PM   #26
hashtag
hashtag's Avatar
Drives: 2018 ZL1 A10/2018 GT350R #JR603
That power plant in my opinion would not outpower the LT4. Track times better than the ZL1 1LE? They have their work cut out for them
2018GT350R+2018 ZL1 "Red Hot" A10 w/ PDR, Nav, Carbon Fiber Hood insert, Carbon Fiber Dash Insert, Carbon Fiber Fuel Dior & Sun Roof. T/M T-Body, Roto Fab & Borla S Type.
hashtag is offline   Reply With Quote
Old 01-10-2018, 05:30 PM   #27
hashtag
hashtag's Avatar
Probably a $7K brake option on the 2019 model year.
Old 01-10-2018, 06:05 PM   #28
Chub2000
Chub2000's Avatar
Drives: 2018 camaro zl1 , 2007 porsche GT3,
I totally agree. I pulled my ceramics off of my GT3. A replacement set from Porsche costs $22,000...
Chub2000 is offline   Reply With Quote
