Old 01-16-2018, 07:00 PM   #15
SC88
Twin Turbo
SC88's Avatar
Drives: 2016 2SS
I'm not sure what trigged it but I had the same thing pop up on mine when I installed the Magnuson.
it will quickly go away after a few key cycles.
Boost, Boost & More Boost
Instagram = BoostedSS
SC88 is offline   Reply With Quote
Old 01-16-2018, 09:31 PM   #16
laynlo15
Drives: 2022 Lt1 A10
Nothing has ever popped up on mine that I've noticed.
Old 01-17-2018, 09:03 AM   #17
chrest
chrest's Avatar
Drives: 2017 Camaro 2SS
i want to keep it! someone figure this out!
2017 NGM 2SS NPP M6 MRC
Vortech SC, 2" TSP LT No Cats, Borla X, Eibach,
Hurst shifter
603hp/547tq
chrest is offline   Reply With Quote
Old 01-17-2018, 09:51 AM   #18
MP3BOOSTED
MP3BOOSTED's Avatar
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C)
Probably something we can post for AL
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw
MP3BOOSTED is offline   Reply With Quote
Old 01-17-2018, 10:52 AM   #19
MR 45TH
MR 45TH's Avatar
Drives: 2018 ZL1
Originally Posted by chrest View Post
Someone figure this out!
I was thinking the same thing
2018 ZL1…Many mods to come
MR 45TH is offline   Reply With Quote
Old 01-17-2018, 11:22 AM   #20
brettman
Drives: 2016 Camaro SS
I have not seen that (I WISH I HAD) I would sub battery volts for boost any day.
Now I am interested, I'll have to talk to my PPL at GM. I have to believe it is a program that is triggered by the 3bar MAP. Sad (my friend) the GM guru retired.
brettman is offline   Reply With Quote
Old 01-18-2018, 09:07 AM   #21
tireslayer0331
tireslayer0331's Avatar
Drives: 2016 2SS
My car didn't have a 3 bar MAP when I installed my procharger, I had the same thing come up. I believe it is from disconnecting the battery for a period of time during the install, mine went away shortly after. I wish we could use it as an actual boost gauge though!
2016 Camaro SS- , D1SC, 4.38" pulley, LT4 HPFP
tireslayer0331 is offline   Reply With Quote
Old 01-18-2018, 05:31 PM   #22
ProCharger
Drives: Many C7's
Likely a setting in the body control module for the dash... for another engine platform.
Would take some serious coding to get it to work for a car its not programed for.
NOTE: Mustangs have a "boost" gauge as well, however, its only calculated and is nowhere near accurate.
ProCharger is offline   Reply With Quote
Old 01-19-2018, 01:33 PM   #23
parbreak
Drives: 2017 50th Camaro SS
so what triggered it? the car is untuned. nothing done but the install of the vortech. The 3 bar Map IS installed. I literally only started it to check for leaks or issues and what not prior to towing to my tuner. That gauge showed up only PRIOR to the car starting, then it switched back to the battery as soon as the car fired.
If you don't mind my asking, what MAF 3 bar did you get and where from?
50th Anniversary Edition |Borla Atak and 60606 mid pipes| Kooks 1 7/8" | ProCharger Stage II |305/45/17 DRs | Circle D 3500 stall | LT4 fueling | Custom made Lowside Aux Pump | Alky Control Meth | DSX E85
parbreak is offline   Reply With Quote
Old 01-19-2018, 01:34 PM   #24
parbreak
And never get an answer??
Old 01-19-2018, 03:32 PM   #25
chrest
chrest's Avatar
it came with the kit.
this is the one
https://www.summitracing.com/parts/n...2525/overview/
Hurst shifter
603hp/547tq
Old 01-19-2018, 04:19 PM   #26
DSX Tuning
Drives: 2019 Corvette ZR1
It probably has something to do with how you set the Sensor Config under MAP in Engine-Airflow-General.
DSX Tuning is offline   Reply With Quote
Old 01-19-2018, 10:45 PM   #27
toohighpsi
Drives: 2015 C7 Z06 M7
And there's apparently more than 1 version, the 2018 ZL1 I had on the dyno today had the same gauge, except with a par of 4 lobe rotors in the middle
Old 01-20-2018, 02:18 AM   #28
SilverSS1LE
SilverSS1LE's Avatar
Drives: 2017 Summit White 2SS A8
so your saying theres a chance it can be there to stay?!
Mod List: Stock (for now)
SilverSS1LE is offline   Reply With Quote
