Old 01-02-2018, 04:22 PM   #15
hou30guy
Drives: 2011 convertible 2ss/rs
If i remember right you wanna be some where around 11.2 to 11.7 depending on set. Anything lower than 11 ur pig rich
Sent from my SM-N950U using Tapatalk
hou30guy is offline   Reply With Quote
Old 01-02-2018, 10:56 PM   #16
laynlo15
Drives: 2022 Lt1 A10
11.2 is rich, I think mine is around 12.2 to 12.5 on the dyno and data logging at the track. To rich is loosing hp
Old 01-02-2018, 11:36 PM   #17
oneredry
HYPER SS
oneredry's Avatar
Drives: 2016 Supercharged 2SS
So your suggestion by my screen shots, that I need a re-tune? or will the lower pulley even it out?
Ordered: 1/15/2016
2000 status 02/01/16
3000 status 02/29/16
3400 status 03/07/16 TPW of 03/14/16
4200 status 03/17/16 in transit!
Delivered 03/23/16
2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points.
| AWE touring - resinated catback with link pipes.
oneredry is offline   Reply With Quote
Old 01-03-2018, 04:03 AM   #18
hou30guy
Retune as 12.5 on a wot is wayyy to lean
Old 01-03-2018, 04:12 AM   #19
wnta1ss
Drives: 2017 Camaro 1SS
It should be pointed out that hou30guy has an older LS motor with port injection. This car is an LT1 with direct injection, which could need to be tuned differently than the old port-injected setups. He is talking about a different engine.
Old 01-03-2018, 05:37 AM   #20
laynlo15
That is correct that his is a Jack Shaft Maggie with an LS motor. The direct injection is a totally different breed for tuning and afr, timing, etc. My last dyno when mine made 669 rwhp it was right around 12.3, pulls before that have all been above 12 but not over 12.5 at wot.
Old 01-03-2018, 07:12 AM   #21
oneredry
HYPER SS
oneredry's Avatar
yeah, lets NOT talk about LS engines. now I seem to be a bit more confused. after re-reading the thread again...
Ordered: 1/15/2016
Delivered 03/23/16
Old 01-03-2018, 07:15 AM   #22
hou30guy
My fault if this isnt a ls fourm, when Tapatalk pops up a notification on my phone it dont tell me ls or lt
Old 01-03-2018, 09:52 AM   #23
laynlo15
LT1 and Lt4 forum.
Old 01-06-2018, 12:31 PM   #24
JANNETTYRACING
JANNETTYRACING's Avatar
Originally Posted by oneredry View Post
on my Maggie. Stock is 98MM and just purchased a 95MM...
1) how much boost will the pulley add?
2) will I need to buy a new belt?
3) assuming I'm going to need a re-tune.?
I just also purchased Ted's recommended plugs from another thread I had a while ago. (Thanks!)
Currently its putting down 527ish at the wheels. I'm not thinking needing a fuel upgrade, but eventually will (just not this year) I've already dumped a ton of money into this so its off the table till next Christmas. Still flirting with the 2" headers, but not completely sold on the "is it worth it" cause.
Thanks in advance.
I think Mike did a pretty good job of answering your questions, if there is any thing missed please ask.
The 95mm pulley will give you about 1 psi more boost and will work with your current belt and stock cal on 93 octane, a custom cal will get you the most power out of the extra psi of boost.
Just for reference - the stock belt will work all of the way down to an 80mm pulley. if you want to go to a 75mm or 70mm you'll need a slightly shorter belt.
If you're at sea level, the smallest pulley the stock fuel system (with higher octane) will support is ~90mm. As you go up in altitude you will be able to run smaller to compensate for the lower air density.
Happy New Year!
Mike
www.jannettyracing.com
email tedj@jannettyracing.com
Old 01-06-2018, 12:44 PM   #25
oneredry
HYPER SS
oneredry's Avatar
Copy that. Thanks Ted!
Ordered: 1/15/2016
Delivered 03/23/16
Old 01-15-2018, 03:05 PM   #26
oneredry
HYPER SS
oneredry's Avatar
So I just received my new pulley in the mail. I would expect bolts to come with it? Unless the bolts that are holding on the current pulley is NOT tq to yield bolts. I'm guessing that's fine to just use the old bolts that holds the pulley on the snout? will I need Loctite?
Ordered: 1/15/2016
Delivered 03/23/16
Old 01-15-2018, 03:37 PM   #27
JANNETTYRACING
Not torque to yield, reuse bolts, yes use loctite.
Old 01-15-2018, 07:45 PM   #28
laynlo15
Which pulley did you end up getting?
