Old 12-23-2017, 10:36 PM   #15
ninetres
ninetres's Avatar
Drives: Crush ZLE M6 | 2000 Corvette FRC
As far as the fuse debate, my car sounded 100% the same with the fuse installed or pulled. No difference in any driving scenario. I firmly believe people are hearing a “placebo” effect if they think pulling the fuse makes any difference while in track mode. City, freeway, cruise, WOT.....whatever, sounded indetical on my car.
ninetres is offline   Reply With Quote
Old 12-23-2017, 10:37 PM   #16
KyBoy
KyBoy's Avatar
Drives: '17 2SS H50
I agree.
Heath
1100 - 5/26
0000 - Cancelled - 7/5
Contacted Becky - 7/1
2000 - 7/5
3000 - 7/6
3000 - 7/11 TPW 8/1
3100 - 7/18 TPW 8/1
3300 - 7/20
3400 - 7/21
4300 - 8/3
5000 - 8/5
6000 - 8/13
Old 12-23-2017, 10:49 PM   #17
JayhawkSS1LE
JayhawkSS1LE's Avatar
Drives: 2017 SS 1LE
Originally Posted by SK GT View Post
You guys that deleted your secondary cats...Do you also have your fuses pulled?
Just curious if you are okay with the new found volume all the time.
Thanks
No fuse pull
17 SS 1LE.
JayhawkSS1LE is offline   Reply With Quote
Old 12-24-2017, 02:25 PM   #18
Brewmaster
Brewmaster's Avatar
Drives: 2017 2SS 50th Anniversary
There is a noticeable difference with the pause pull vs track IMO. But, the difference is only when cruising or coasting on decel. The factory system closes up on the highway, that is the only way the car passes federal noise drive-by spl. I made a wireless circuit to enable/disable NPP fuse from Homelink, and you can tell it when you change it while driving.
Brewmaster is offline   Reply With Quote
Old 12-24-2017, 06:01 PM   #19
ninetres
ninetres's Avatar
My car sounded identical on cruise and decel with and without fuse. No difference what-so-ever.
Old 12-24-2017, 06:12 PM   #20
KyBoy
KyBoy's Avatar
Drives: '17 2SS H50
+1
Heath
1100 - 5/26
2000 - 7/5
3000 - 7/6
3000 - 7/11 TPW 8/1
3100 - 7/18 TPW 8/1
3300 - 7/20
3400 - 7/21
4300 - 8/3
5000 - 8/5
6000 - 8/13
Old 12-26-2017, 06:39 PM   #21
Cruz'n 45th
Cruz'n 45th's Avatar
Drives: 2020 Convertible 2SS Red Hot
Sound clip?
[QUOTE=JayhawkSS1LE;10019998]I kept the stock NPP and put in the Borla 60606 mid pipe (<$600) that removed the secondary cats. Primary cats are still in place. Tone changed, a little deeper. More crackles and pops. What I notice most is under WOT. It is the sound I was looking for. I had thoughts of spending money on an axle back before and glad I didn't.[/QUOTE
Jayhawk - I've ben thinking about the same setup but wanted to hear how it sounds. Can you a sound clip? Thanks!
2020 2SS Convertible, Red Hot, Black Rally Stripes, Performance Exhaust, 5 Spoke Low Gloss Wheels, Adrenaline Red Seats, and A10
Cruz'n 45th is offline   Reply With Quote
Old 12-26-2017, 07:28 PM   #22
Tcamaro
Drives: 16' 2SS
NPP here along with gutting both secondary and primary cats along with the vortech it's plenty loud at full throttle. I have been asked several times what brand exhaust I have. I just couldn't see spending the $$ after getting the NPP
Tcamaro is offline   Reply With Quote
Old 12-26-2017, 07:36 PM   #23
jimmypop13
Drives: 2016 camaro ss
Originally Posted by Yellow6thGen View Post
Kooks has a system my ZL1 is over at R&D for new exhaust and headers.. if anything put headers on first then switch. I went with the MBRP Cat back with no headers and oh it was loud but not to loud. But for under 700.00 can’t beat it.... Sounds amazing over Stock, but no quite mode. My ZL1 has 4 settings from stealth to Track... I don’t want to loose the stealth or touring, Sport settings to Track as well wide open... I will let you know in a few weeks as estimate was 3 weeks because holiday.
It's really just two settings. Open and closed. Stealth stays closed. Tour is closed except I've heard it will open at WOT. Sport and track are identical, open. And it will still close in both those modes after like 30mph, at least on the autos
2016 camaro 2SS hyper blue/Kalahari, A8, MRC, NPP, sunroof, SW headers through axleback, Circle D 3600rpm TC, Pray ported IM/TB, E85
Sold: 2002 Z28, NBM, M6, 460rwhp, 2009 HHR SS
RIP : 2002 WS6 Black, A4, 355rwhp
jimmypop13 is offline   Reply With Quote
Old 12-27-2017, 10:10 AM   #24
slick3
Drives: Garnet Red - 20 ZLE
Sport will close when you are at constant steady state throttle and not accelerating.I will hear it open back up when I get to a stop light when in sport. Track does not close. Ever..... at least it doesn't in my M6.
slick3 is offline   Reply With Quote
Old 12-27-2017, 10:42 AM   #25
Kise
Kise's Avatar
Drives: 16' 2SS, 06' Silverado SS
if you have the stock exhaust and have the NPP rattle, the fuse pull eliminates the rattle upon acceleration in which the rattle can be really loud entering the highway. ive had the epoxy fix twice and a whole new exhaust and it started 20 miles into the new exhaust.
Kise is offline   Reply With Quote
Old 12-27-2017, 10:50 AM   #26
AchiliesSS
AchiliesSS's Avatar
Drives: 2017 Black on Black 1SS
JBones, and guys I did delete my npp muffler and had a y pip installed right after the pinch section on the pipe and kept factory tips. The turnout was a lot more volume but only accelerating and at wide open, but when its in touring or even cruising in any mode its no drone or noticeable exhaust noise only when i am accelerating or revving. To put it, in tour mode if you are at a light and rev it, it sounds weak and quite but in track or sport it is loud, way louder than the npp. It is just slightly louder in touring than the factory. I will have to post a video when I get a chance from the rain. ill post a video of the setup and the sound. It was odd still having a camery or honda comparable stealth mode and still having a way louder than npp loud without mufflers. Only thing is I have the factory raddles from the tips which I will get around to doing a fix for it. all of this was 225 at my exhaust shop.
AchiliesSS is offline   Reply With Quote
Old 12-28-2017, 10:57 AM   #27
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
afe power headers and exhaust and no ragrets here lol
Old 12-28-2017, 12:03 PM   #28
marknagy13
Markoon13
marknagy13's Avatar
Drives: Camaro 2SS
Here's my setup with catless Kooks long tubes and MBRP catback exhaust. Every once in a while it can get annoying on a cold start if I'm really tired in the morning and don't want to hear loud noises but other than that, it was worth every penny to make this thing sound like a race car.
marknagy13 is offline   Reply With Quote
