#15 |
The heads are off. Notes:
1) better have a 13mm hex drive, cause my inclusive set did not. 1/2 drive IMO 2) selection of 3/8 extensions and whobbles will make life easier 3) drain coolant before hand, cause I could not find the drain cock from the top 4) uncap the headers or the head bolts can't come out (header in the way) 5) there is not one but TWO ground straps in back of the driver's side head Notes on head: Intake port is really tall, means flow. Exhaust port is hideous. If I did not already have headers I would be looking at Victor JR heads and Kooks headers for it. LOL Looking at it I'm going to pull the short block and trans from the top.
#16 | |
![]() ![]() Drives: '17 Red hot 2ss, 16 Focus RS Join Date: Aug 2015
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance |
#17 |
![]() Drives: 2017 Camaro SS 1LE - Krypton Green Join Date: Jul 2017
When reinstalling the rocker arms, is there any valve lash adjustment? Specific order of tightening them down? Do they just get torqued down? It’s been a while since I’ve done a cam on a car and I’m not familiar with this engine.
#18 |
Decent write up man, especially for a guy who doesn't do this stuff all the time. I did mine in the car and didn't do near as many steps. Just watch that chain, if it falls off you are screwed haha. I use to do this daily for work, and still do it on a pretty regular basis though. Like you said, there is always more than one way to do any given job. What cam did you go with and what do you think of the performance you got?
#19 |
Here are some pics of mine still in frame;
#20 |
Torque them down when they are on the base circle. 24ft lbs iirc
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance Last edited by Dubchitts; 01-22-2020 at 03:47 AM. |
#21 | |
"Spitfire" 427ci
#22 |
#23 |
I'm going to go with Pray. That way he'll have a pretty close tune for it right away. Hopefully minimizing the fine tuning
"Spitfire" 427ci
#24 |
Edited step 28. Trans removal
"Spitfire" 427ci
#25 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 2SS M6 Join Date: Jun 2013
you have to be on the base circle of the cam befor you torque the rockers down or your torque will be off because your compressing the valve spring
#26 |
![]() Drives: Camaro Join Date: Mar 2016
For those that have a lift, it is MUCH easier to just drop the entire front cradle with engine/trans attached then trying to pull the engine out the top.
#27 |
![]() ![]() Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C) Join Date: Jun 2017
So I’m pulling the motor now for the first time to do a forged internal build. I’m going to leave the transmission in the car unless there is a crazy reason why I shouldn’t, any issues with pulling the motor and letting the transmission there? I’m not touching the transmission mount, any ideas?
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw |
#28 | |
"Spitfire" 427ci
