Old 12-21-2017, 12:28 PM   #15
SuperSound
SuperSound's Avatar
Drives: '17 Camaro 2SS A8
So we need to find out your build date and then you know who to complain about lol
Sent from my SM-G950U using Tapatalk
Old 12-21-2017, 12:30 PM   #16
Nightfall SS
Nightfall SS's Avatar
Drives: 2016 Camaro 1SS
that should be on the sticker in my door jam right? I ask before I do the 5 minute walk to get back to my car in the parking lot lol.
1. Phastek detachable front license plate bracket 2. Blacked out Bowties 3. Blacked out sidemarkers/third brakelight 4. Rotofab dry/no soundtube CAI 5. VMAX ported throttlebody 6. Kooks 1 7/8 Longtubes with Hi-Flow Cats 7. EFI Tuning Flex Fuel kit and tune 8. HP Tuners NGAUGE 9. Zeitronix ZT-2 Wideband(reads on NGAUGE) 10. Ported MSD intake manifold 11. CORSA XTREME axle back w/ dual quad black tips
12. Racestar Darkstars 17X9.5 with Mickey Thompson ET Street SS 305-45 17 Radials 13. Kicker 3-way door speakers. DYNOCOM mobile dyno trailer: 471hp/490TQ@97degrees ambient/ethanol percentage=80%
Nightfall SS is offline   Reply With Quote
Old 12-21-2017, 12:44 PM   #17
Nightfall SS
Build date 09/15
Old 12-21-2017, 12:59 PM   #18
JFM-jr
JFM-jr's Avatar
This is odd for sure
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB
Rotofab
ARH 1 7/8 longtubes hi flow cats AFM deleted E85
11.0@124.9
11.65@118.8 pump gas,stock tune/exhaust
New combo: Pray Performance Heads/cam
MSD intake manifold and Circle D 3C
554/491 on E85 all work & tuning done by Pray
JFM-jr is offline   Reply With Quote
Old 12-21-2017, 01:11 PM   #19
JFM-jr
JFM-jr's Avatar
If I were you I would unplug them and see what happens. Your ECM and BCM are still programmed as a manual so that AFM hardware should not be functioning
Rotofab
11.0@124.9
Old 12-21-2017, 01:14 PM   #20
Nightfall SS
Yep thats what i am going to do as soon as i get the car home. I wonder if other m6 cars still have the wired connectors from a shared wiring harness but are just tucked away since there arent any valves to connect them to.
Old 12-21-2017, 01:17 PM   #21
jimmypop13
Drives: 2016 camaro ss
I would definitely try to unplug them and see what happens. You simply shouldn't have those valves. I'm wondering if the previous owner had the exhaust valve rattle and they replaced it with an A8 exhaust. They were doing that at first bc they replaced mine for the rattle and then it came right back. There were no signs of it being replaced either. But how would they plug them in if that was the case!
2016 camaro 2SS hyper blue/Kalahari, A8, MRC, NPP, sunroof, SW headers through axleback, Circle D 3600rpm TC, Pray ported IM/TB, E85
Sold: 2002 Z28, NBM, M6, 460rwhp, 2009 HHR SS
RIP : 2002 WS6 Black, A4, 355rwhp
jimmypop13 is offline   Reply With Quote
Old 12-21-2017, 01:36 PM   #22
Nightfall SS
Oh yeah i could see that being a possibility. Ive not experienced the rattle with my npp though i dont use it either having pulled the fuse. If that was the case though, only way they can plig them in is if all cars have a,common wiring harness and the connectors are just tied off somewhere on the m6 cars i guess.
Old 12-21-2017, 02:47 PM   #23
jimmypop13
Yup. Give it a try. If you get codes, they won't be permanent if you plug them back in. Permanent codes are a thing now but it takes a while for coffee to become permanent status
Old 12-21-2017, 03:21 PM   #24
Nightfall SS
So unplugged and let it run for 10 min in the garage. No codes. Im going to leave them unplugged and just bag and ziptie the connectors out of the way and drive it around. If codes do come later ill mention it on this thread for everyones knowledge. Thank you to everyone who provided assistance or even questioned the validity of this. Its things like this that expand our knowledge base on these cars. Hopefully if some other poor bastard besides me runs into this, they should be able to do a search and have this insightful thread pop up to help them
Old 12-27-2017, 06:47 PM   #25
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
Mine does not have them, and I have an M6. Yours is an EARLY build?
Old 12-28-2017, 04:57 AM   #26
Nightfall SS
It was a Sep 2015 build. As discussed earlier in this thread, thinking either the factory oopsed or it was taken in at some point maybe for whatever reason and the dealer put an a8 back section on it by mistake. I have put a few hundred miles on it without them plugged in and no codes. so even though they plugged it in the system wasn't monitoring them thankfully.
Old 12-28-2017, 09:50 PM   #27
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
Your BCM does not switch them so it bypasses them. No real effect with them just sitting there.
