Old 12-17-2017, 03:15 PM   #15
ZL1 1LE
@zle_blackwing
ZL1 1LE's Avatar
Drives: 2018 ZL1 1LE
How difficult/easy was dive plane removal replacement?
Did you have to pull the front clip?
It was relatively easy. The last clip closest to the center of the car was the most difficult. I was able to reuse all of the clips and even found the one from the broken piece on the dive plane.
I did not have to pull the front clip. I cranked the wheel full right and then removed 4 torx screws (# 15) from the inner fender liner and then unplugged and removed the side marker light. You access 4 of the 6 clips this way. The other 2 are accessed right thru the opening in the front.
Old 12-17-2017, 03:18 PM   #16
waterman
waterman's Avatar
Drives: Grandad's C2 L89
Good info, Thanks!
I'm thinking about CF dive planes, your insight is a big help.
2018 ZL1 1LE sw/PDR
Old 12-17-2017, 03:34 PM   #17
Badgerbimmer
Badgerbimmer's Avatar
Drives: ZL1 A10
Does anybody have the schematic for the rear showing all the parts necessary to install the 1LE rear wing?
Badgerbimmer is offline   Reply With Quote
Old 04-14-2021, 03:15 AM   #18
Alexj100
Drives: Chevrolet Camaro 1SS
Originally Posted by Lugojf View Post
Here...
I know this post is hella old, but where did u get this parts list that is super specific and detailed? Im looking for the list of rear bumper parts and cant find a detailed one like this one
Alexj100 is offline   Reply With Quote
Old 04-14-2021, 02:47 PM   #19
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
That's available online at any gm place. I have a zl1 1le diffuser for sale new but no box
Old 05-05-2022, 08:29 PM   #20
Crushed 1LE
Crushed 1LE's Avatar
Drives: 2022 ZL1 1LE
This is a pretty old thread now, but wanted to ask.....
Are the facia's exactly the same on the ZL1 and the ZL1 1LE. If I don't have to buy and paint a new facia, that is a huge savings for this build.
Also, I'm guessing the best way to install all the bits would be to remove the facia (actually, I'm pretty sure it's required).
Thanks all.
Crushed 1LE is offline   Reply With Quote
Old 05-06-2022, 05:09 AM   #21
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
They are the same minus you having to cut the holes for kanards/dive planes the slot etch marks are on the inside of the fascia still as far as I know. Can be done on the car if you can find a template that was once used before gm added the marks.
Old 05-06-2022, 09:17 AM   #22
I am pretty sure they are somewhat different because of 1) the different front splitter attachment, 2) the lower DRL housing vs the extra vent cover on the 1LE, and 3) the canards.
Now, can one hack up their existing front bumper to fit, probably, but they are definitely not the same (see also the screenshot below).
Old 05-06-2022, 09:49 AM   #23
Crushed 1LE
Thanks for the info. I know guys have cut the ZL1 cover for the canard, but it is clearly a different part #. What to do...? Paint is expensive!
Old 05-06-2022, 12:38 PM   #24
Blackbyrd
Drives: Chevy Camaro ZL1
Previous owner of mine did this and i actually want to revert back to the standard zl1. I've debated repairing the holes vs buying a new bumper..... I'm gonna have to paint either way.
If you buy a new lower lip do they come in gloss back already?
Blackbyrd is offline   Reply With Quote
Old 05-06-2022, 02:50 PM   #25
99% of these parts are paint-to-match, unfortunately. The exceptions I know about is the standard ZL1 spoiler and ground effects kits that come pre-painted, with multiple color options.
Old 05-06-2022, 02:58 PM   #26
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
There is no difference plug n play just cut the slots. I've done 3 zl1 to zl1 1le aero pkg installs.
Old 05-06-2022, 03:10 PM   #27
Are you saying gm is charging $230 extra for the 4 canard holes? That'd be... visionary, but definitely not unthinkable
Old 05-06-2022, 03:25 PM   #28
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
That's exactly what I'm saying! There was never any chopping or cutting for the bezels, grill, or splitter actually they are charging 230 for 6 slots/holes there 1 on each side on the bottom for the splitter winglets that slide through the fascia and use the plastic tabs to hold it. 3 screws in the wingless that go into the splitter and 1 hole/slot in fascia.
