Old 11-19-2017, 04:12 PM   #15
Soleil
Soleil's Avatar
The OEM 1LE are
Front 20x10 ET 20
Rear 20x11 ET43 if I am not mistaken. Please correct me if I’m wrong.
How do you get 295 on 10” and 335 on 11”?
Soleil
Old 11-19-2017, 04:59 PM   #16
ride98red
ride98red's Avatar
Drives: 2017 Summit White Chevy Camaro 2SS
Originally Posted by ex-SS-ve View Post
I dont run spacers. At all..
I'm not doubting ya man...but I can't understand how it's fitting without rub. Must be differences between the 1LE and the SS. Lethal (Mat) had issues with his 315's rubbing. Yes, his tires were R888's vice your MPSS so the MPSS's must run skinny.
At 7:20 of the below video, Mat highlights his opinion on rub and also mentions that he is running 5mm spacers with the 315's. Now, he has the MRR rep 1LE wheels but according to MRR, they are the same spec as OEM (+23et/+43et)
Nonetheless, your can looks absolutely gorgeous! Nicely done.
https://youtu.be/NQZggYFeTTM
ride98red is offline   Reply With Quote
Old 11-19-2017, 09:03 PM   #17
ex-SS-ve
ex-SS-ve's Avatar
Originally Posted by Outahand View Post
Looks great.
How do you like the tire so far compared to stock?
This should work on a ZL1 if our wheels have the same offset.
it will work on a zl1 no problem. Thanks.
Originally Posted by Soleil View Post
The OEM 1LE are
Front 20x10 ET 20
I have never looked at the offset. So im not sure what it is. I do know they are 20x10 & 20x11. Not sure what other evidence you need me to prove that i have 335 tires on factory wheels.
Thanks. But honestly i do not know who this “lethal matt” guy you speak of is ive seen many guys try to run 11s and fail terribly because offset wasnt correct. Not sure how his little 315s rubbed when they run far more narrow than a mpss with 13.5” section width. But thanks.
ex-SS-ve is offline   Reply With Quote
Old 11-19-2017, 09:09 PM   #18
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
The OEM 1LE are
Front 20x10 ET 20
I have a spare set of 20" OEM SS 1LE rims with 285/305 MPSS's. I agree they are narrower than the Goodyears. I did those a year ago. If I had seen pics like these, I would have gone the same way.
RUQWIKR is offline   Reply With Quote
Old 11-20-2017, 05:20 PM   #19
Soleil
Soleil's Avatar
@ex-SS-ve,
You don’t have to prove anything. I was just wondering as my wheel configurator keeps telling me that 295 do not fit on 10” and 335 do not fit on 11” maybe I have to contact Michelin to get an approval. Here in the EU we have other rules and regulations.
As I said before your car looks awesome if you have some more pics
Please
Soleil
Old 11-20-2017, 06:10 PM   #20
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
PSS run a rounded sidewall. So going to a 295 up front just squares it out with the wheel.
Old 11-22-2017, 12:55 AM   #21
ex-SS-ve
ex-SS-ve's Avatar
@ex-SS-ve,
Please
It wasnt meant in a bad way.
I had to do all sorts of overrides with discount tire to get these tires. They gave me a hard time after they showed up. I was like dont worry about it. The hardest part of the swap was removing the original tires. The new ones went on no problem..
Old 12-29-2017, 04:47 PM   #22
BurnOne
BurnOne's Avatar
Drives: 2018 Camaro ZL1
Is the rear fender well any deeper on the 17 1LE compared to the 16 SS??? I like the idea of putting 335's on my 16 SS...
BurnOne is offline   Reply With Quote
Old 12-30-2017, 04:45 PM   #23
Soleil
Soleil's Avatar
As far as I know are the fender of all ´16 -´18 Camaro the same. From LT to ZL1. Only the front of the ZL1 is bigger.
Soleil
Old 12-30-2017, 05:57 PM   #24
DenverTaco07
DenverTaco07's Avatar
lethal camaro's issue was with the wiring harness in the rear driver's side well, this harness is routed differently on the 1LE and ZL1. Not sure what wheel he was using, but not a chevy wheel...so could also play a role in his issue- he uses spacers too.
Old 12-30-2017, 06:03 PM   #25
DenverTaco07
tire rack says section width of mp4s 305 is 12.3 inches, same as oe tire....
how they look chincy?
oh, tread width is
11.2 michelin
11.8 goodyear
Old 01-04-2018, 07:09 PM   #26
Smashn808
Smashn808's Avatar
Drives: SS
Those look perfect. I’m at 6k miles and may go the same route soon.
2017 HBM 1SS 1LE w/PDR
Past:
2009 Cadillac CTS-V, 6-speed manual
2008 Corvette Jet Steam Blue, manual
2005 Cadillac CTS-V, Stealth Gray
2003 Corvette Z06, Black
Smashn808 is offline   Reply With Quote
Old 01-04-2018, 07:35 PM   #27
DFW1LE
DFW1LE's Avatar
I can't find the Pilot 4s on tire rack in 335/30/20, where did you find that size?
Frankenstein Engineering Dynamics Stage 1 H/C/E85 536HP/488TQ
Old 01-04-2018, 11:38 PM   #28
jimmypop13
Drives: 2016 camaro ss
He said they are pilot super sports, not ps4s.
2016 camaro 2SS hyper blue/Kalahari, A8, MRC, NPP, sunroof, SW headers through axleback, Circle D 3600rpm TC, Pray ported IM/TB, E85
Sold: 2002 Z28, NBM, M6, 460rwhp, 2009 HHR SS
RIP : 2002 WS6 Black, A4, 355rwhp
jimmypop13 is offline   Reply With Quote
