Old 11-16-2017, 11:30 AM   #15
Camaro85
Drives: 2015 SS
Originally Posted by Rob Camaro View Post
So I’ve been reading that Apple’s IPhone 8 and IPhone X are not compatible with wireless pads in GM vehicles (except for a select few of 2018 models, which Camaro is not one).
I have a wireless pad in my 2017 Camaro 2SS and I ordered an IPhone X, but did so before finding this out. Hmm.
So the topic here in this thread, is do you think GM will make an upgrade kit that we can install or the dealer can install that will work with IPhone X and IPhone 8?
Millions of people will have these phones, I don’t see how GM could not offer an upgrade fix for GM vehicles with incompatible wireless pads.
Thoughts?
Best option is to get a Galaxy 8. Same specs as the X but 1000 bucks cheaper
Camaro85 is offline   Reply With Quote
Old 11-16-2017, 11:39 AM   #16
Mr. Meh
Drives: Sold
Originally Posted by pkssauce View Post
I would also mention that millions of people have been using wireless charging phones for years now and the supplied charging pad has been a problem since day one. The technology in the pad is fine, it's a wireless charging standard, the problem is the pad size. They clearly designed the pad 4-5 years ago when phones were smaller, today's phones don't even fit.
For me it was only a minor disappointment as you are required to plug the phone in for AA to work and you get a better quality charge out of that anyways.
That's not entirely correct. The problem isn't just a pad issue. That's true for Phablet sized phones like Apple's + line or Notes and such.
However, an iPhone 8 regular size does indeed fit in the pad dock for a 2016 Camaro SS and a 2017 Camaro ZL1. It simply will not engage the charging routine with Apple's Qi support.
My Note8 will momentarily engage, but it's such a precise spot to hold it, I can't keep it there long enough.
There's more to it than just a pad and there are actually 2 different specs these days. Qi and PMA.. There used to be 3, but two of them merged.
My Note 8 can do Qi and PMA, the iPhone8 only handles Qi. So, there's something in the charging pad that doesn't allow Apple's Qi implementation to work (I've not tried other Qi options)
Mr. Meh is offline   Reply With Quote
Old 11-16-2017, 03:23 PM   #17
pkssauce
pkssauce's Avatar
Makes sense. Not trying to war, honest question: Doesn't this make it an Apple problem, not GM?
Ordered: 2SS Nightfall Gray, NPP, MRC, navi, auto, low gloss black wheels, black bowties
TCFCB4
1000: 12/08/2015
2000: 12/08/2015
3000: 12/10/2015
3000: 12/12/2105 - TPW 1/11/2016
3100: 12/18/2015 - TPW 1/18/2016
3300: 12/23/2015 - TPW 1/11/2016
3400: 12/24/2015
3800: 01/19/2016
4300: 01/20/2016, 4200: 1/28/2016, 4300: 1/29/2016, 4B00: 1/30/2016, 4200: 2/7/2016 (train), 4800: 2/19/2016, 5000: 2/22/2016, 6000: 2/25/2016
pkssauce is offline   Reply With Quote
Old 11-16-2017, 03:32 PM   #18
Mr. Meh
Drives: Sold
http://www.air-charge.com/about-us/a...eless-charging
and the link in that article to the Apple KB
https://support.apple.com/en-us/HT208148
So, that would seem to suggest that a 2018 and newer Camaro should allow it to charge an iPhone8.
if that is indeed the case AND it's just the charging module in the rear area, then it's ~possible~, those of us with 16/17 Camaros could buy the new charge plate piece and plug in to our harness **
**assuming that the input to the module is plug/power compatible and it's just internal to the module circuitry that allows for the Qi certification to work.
would be interesting to see the part numbers for this piece for a 2016, 17 and 18 Camaro and see where the numbers vary and then open one to see how much is different.
**EDIT (did my own search) **
2016 - 17 Camaro - Wireless charging module: MODULE - GM (23248791) and says it replaced part 13508881
I can't find the P/N online for free for the 2018s.. There's a couple paywalled services manuals though.
Old 11-16-2017, 03:41 PM   #19
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
It's just an induction pad, at it's core...there's GOT to be a way of removing the old unit, and putting a new one in, even if it doesn't fit quite right, using the existing power supply...
EDIT: I just saw the above post about 2018 models...I can confirm that the iPhone X does NOT charge in my 2018 Camaro :(....yet, I wonder if we can yank out one of the pads from the above models and plug it into our cars....
Old 11-16-2017, 03:46 PM   #20
Mr. Meh
Drives: Sold
So, even on your 2018, which shows from Apple it's Qi certified, it still doesn't pick up and charge?
Also, at least from this chart -- it claims it's the same module as that's the SUV center console in the picture.
https://www.gmpartsdirect.co/oem-par...odule-23248791
Old 11-16-2017, 04:02 PM   #21
Martinjlm
Retired fr GM + SP Global
Martinjlm's Avatar
According to the Apple tech I spoke to, Qi has Low Power and High Power protocols. Some phones can operate with one, some phones can operate with the other, some can operate with either. Apple iPhones only work with High Power. Camaro pads are Qi Low Power.
Old 11-16-2017, 04:41 PM   #22
Mr. Wyndham
I just tried again.
Even if I take off the Apple-approved phone case, no dice.
It blipped the charging logo once as I placed it down, then it immediately lost signal. I may bring it to the dealer in the Spring just to see what they say. Sadly putting the car away for the winter tomorrow.
Old 11-16-2017, 04:43 PM   #23
Sven59
HAMMER PILOT
Sven59's Avatar
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado
I just tried again.
Same thing happens with my galaxy S8+. It fits in the area, just won't charge.
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
Sven59 is offline   Reply With Quote
Old 11-20-2017, 02:45 AM   #24
Rob Camaro
Rob Camaro's Avatar
Drives: 2017 Chevrolet Camaro 2SS
This is exactly what I read on another site. Apple has released a list of 2018 GM vehicles that are compatible with iPhone X (most being trucks and SUV’s). Camaro was not on that list. But I would assume that one could just purchase a 2018 GM charging unit for one of those compatible vehicles from the parts dept or other source and install it. In theory it should work.
By the way, my IPhone X fits on the charging pad, snug but fits. So in the case of IPhone X users, changing the charging unit could solve the problem, if that is an option.
Rob Camaro is offline   Reply With Quote
Old 11-20-2017, 05:03 AM   #25
TJay74
This isnt GM issue, they put a industry adopted and standard wireless charger into their vehicles. They cant help the fact that Apple once again has decided to go outside the norm instead of following the industry standard.
Apple has done this for years, with their Bluetooth stack with their file transfer system and now with their charging protocol.
Old 11-21-2017, 01:01 AM   #26
Rob Camaro
Rob Camaro's Avatar
From the list of brands that are compatible with Apple, it seems most all the other brands are except GM (excluding select 2018 models). Apple made note that that GM did not meet the requirements for Qi certification. Looks like fault may be on GM, rather than Apple.
Old 11-21-2017, 07:20 AM   #27
majik755
majik755's Avatar
Drives: 2017 Camaro RS Fiftieth Anniversary
The specs for wireless charging are changing so quickly, this is not surprising. They've already announced a higher speed charger for the next iPhone X. Judging by the list of phones that don't work with GM chargers maybe it would be best to figure out how to convert the area to usable space instead of a charging pad, can certainly use some storage in the cabin..
majik755 is offline   Reply With Quote
Old 11-21-2017, 05:23 PM   #28
Bigdog9586
Drives: 2016 Z06 coupe
What you are claiming is the GALAXY 8 IS FREE. I think your brain has been to close to the charger.
Bigdog9586 is offline   Reply With Quote
wireless charging
