#15 |
![]() Drives: 2017 Summit White Chevy Camaro 2SS Join Date: Jul 2016
#16 |
LT4 M6
Drives: 2018 ZL1 1LE Join Date: Nov 2010
#17 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
if I am jacking the whole car up I start at the rear under the diff and jack the whole rear end up, place the jack stands on the ZL1 Addons pads (I leave my pads on all the time). Then I slowly jack each side up and put a stand under the front ones as well.
Works every time for me, as long as you take it slow while you are jacking the car up. |
#18 | |
#19 | |
By lifting the rear up by the diff I am spreading the load across the back of the car, then lift each side of the front up and I am only putting 1/4 to 1/3 of the cars weight on that side of the lift point while jacking the car up. |
#20 |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
I have a set of these 56" Race Ramps for oil changes and whenever I need to get under it...
https://raceramps.com/car-ramps/gara...56-race-ramps/ |
#21 |
![]() Drives: 2017 Camaro SS 1LE Join Date: Jan 2017
Used 2x12's as a poor man's race ramp. Stacked 2-3 high and stagger them with a bevel cut on each one. Works well.
#22 | |
Sure, why not?
Drives: 2016 Camaro 2SS, Jeep JKU Rubicon Join Date: Mar 2015
#23 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '18 1SS 1LE Join Date: Sep 2017
#24 | |
Sure, why not?
#25 |
LT4 M6
With the zl1 addons mag pad and lift points. Along with flat top jack stands. It's way easier to jack the car up on all 4's then it is to drive up on the ramps IMOP. Wish I never bought the ramps.
#26 |
![]() ![]() Drives: 2023 2SS, 2018 1SS 1LE, 1993 Z/28 Join Date: Jun 2018
I switched from heavy ramps I built by bolting together a stack of beveled 2x12s to one-piece 56" Race Ramps more than 10 years ago. I've never had a problem with the Race Ramps, and I love the fact that I can just hang them on the wall out of the way when I'm done using them. The front splitter on a 1LE clears the ramps by about 2", and the 8" lift is high enough for an oil change.
![]() When I need all four corners of the car in the air, I use a low-profile jack with a polyurethane pad and V-shaped or flat-top jack stands with polyurethane pads. There used to be a company called Protech Products that had a wide selection of pads and jacking accessories, but their website has been "down for maintenance" for awhile. I'll have to take a look at the ZL1 Addons products. |
#27 |
![]() Drives: 2018 Hyper Blue 1SS 1LE Join Date: Sep 2014
I use Race Ramps for oil changes. Low risk and easy drive on.
#28 |
![]() ![]() ![]() ![]() Drives: 2018 1SS 1LE, 2015 RAM Ecodiesel Join Date: Oct 2017
I bought race ramps, but really dont need them for oil changes. They are super expensive and I used them once. I installed ZL1 Addons jack pads and use a low profile jack. I jack the car (and use a jack stand for safety) on the side opposite the drain plug (jack on driver side).
