Old 11-14-2017, 08:06 AM   #15
CCS71
LFX to LT1
CCS71's Avatar
Drives: 2017 Camaro Fifty 2SS M6
Originally Posted by Jimbotron View Post
This may be a dumb question but where are you guys hooking up the charger to? Direct to the battery or to the connections under the hood? Thanks for any advice, I have never had a car that I parked for the winter only motorcycles.
Jim
The responses are likely to be split on this. The "easy on/easy off" option is to use the clamps; red one on the remote positive terminal under the hood and the black (negative) clamp grounded to a part of the frame nearby.
2013 Rally Yellow 1LT - Traded
2017 Camaro Fifty 2SS; Sequence #270 - Sunroof/Nav/NPP/MRC/6speed
CCS71 is offline   Reply With Quote
Old 11-14-2017, 08:22 AM   #16
camaromike77
camaromike77's Avatar
Drives: S O L D
Jim
I use the connections under the hood..........
Club F1FTY
Old 11-14-2017, 06:45 PM   #17
KLG
KLG's Avatar
Drives: 2016 2SS Convertible
Jim
I use a Battery Tender.
I connected the BT "plug-in" cable to the battery and routed the cable out into the trunk area and wire-tied into place.
For charging the battery, I just plug-in the cable from the Battery Tender and lower the trunk lid fully but do not latch it.
KLG is offline   Reply With Quote
Old 11-14-2017, 06:47 PM   #18
sengli
sengli's Avatar
Drives: 2015commemorative vert 2SS
I did the same as KLG, did. My connection goes to the battery, and is in the trunk.
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded
2015 commemorative vert 2ss
sengli is offline   Reply With Quote
Old 11-14-2017, 06:50 PM   #19
Lerch98
Lerch98's Avatar
Drives: 2017 2SS black on black on black.
some of those cheap battery tenders are not battery tenders, they are trickle chargers.
Check to see if it is a real battery tender. A battery tender tests the battery and will charge when needed (avoids overcharging) and will even cycle the battery by applying a little load. (battery Maintainer).
I use the one that came with the car; says Camaro on it.
It works very well, and I connect it to the terminals under the hood.
I also use this device on my trucks, and early model cars.
Lerch98 is offline   Reply With Quote
Old 11-14-2017, 08:39 PM   #20
Baggy1
Drives: 2017 50th
What is the difference between a High Performance AGM starting battery and a High Performance AGM deep cycle battery?
Which one are we using in our Camaros?
1. High Performance AGM (Absorbed Glass Mat) starting batteries
2. High Performance AGM (Absorbed Glass Mat) deep cycle batteries
3.Standard Flooded lead-acid and AGM (Absorbed Glass Mat) batteries (large)
or 4.Standard Flooded and AGM (Absorbed Glass Mat) batteries (small)
Baggy1 is offline   Reply With Quote
Old 12-16-2017, 11:46 AM   #21
BaconWrapped
BaconWrapped's Avatar
Drives: 2017 Camaro SS
All,
A general question about the correct current rating to be used... 0.75, 1.1, 3.5, or what?
BaconWrapped is offline   Reply With Quote
Old 12-16-2017, 11:59 AM   #22
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
#3....But honestly it doesn’t matter for what we’re doing. I’ve been charging AGM’s for 10 years on boats cars etc. I use battery chargers that don’t have any type of AGM switch, I’ve used chargers that do have an AGM switch, and for general charging, you can use any charger out there. The most important thing is that you’re not using a “trickle charger”, you’re using a “three stage (or 4) intelligent battery charger”. That doesn’t mean it has to be expensive. All the new “battery tenders”-brand-name-.......work fine.
https://www.amazon.com/dp/B000CITK8S..._t1_B000CITKCE
Old 12-27-2017, 05:19 PM   #23
Marko
Marko's Avatar
Drives: Camaro
Can someone post a pic of the connections under the hood ?
Or should I just connect to the battery In the trunk?
Marko is offline   Reply With Quote
Old 12-27-2017, 06:10 PM   #24
Marko
Marko's Avatar
Drives: Camaro
Just looked up the charging connectors under the hood. Wouldn’t it be a lot easier to hook up a trickle charger under the hood? I use a trickle charger that has small clamps.
Old 12-27-2017, 08:39 PM   #25
MR 45TH
MR 45TH's Avatar
Drives: 2018 ZL1
Yes it would, be which is why I hook it up under the hood.
2018 ZL1…Many mods to come
MR 45TH is offline   Reply With Quote
Old 12-28-2017, 12:05 AM   #26
RandRZL1
RandRZL1's Avatar
Drives: 2018 ZL1
I have found smart charger’s work better (read more consistently) when connected directly to the battery. Able to “read” the battery more accurately.
RandRZL1 is offline   Reply With Quote
Old 12-28-2017, 03:12 AM   #27
V8RWD
V8RWD's Avatar
Drives: 2017 Camaro SS 50th
What do you mean by more consistently? Reading, vs unable to read? How much difference?
V8RWD is offline   Reply With Quote
Old 12-28-2017, 05:19 AM   #28
Driski
Drives: 2016 Camaro Convertible 2SS
Why not just disconnect the battery in the trunk? Why do I need to trickle charge at all?
2SS Convertible, MRC, NPP, A8, Garnet Red, Blk Bowties
GM CAI, Ported TB, Kooks Headers, E85
Driski is offline   Reply With Quote
