Old 11-06-2017, 04:23 PM   #15
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
I would go for a Dexos 2 oil, like Mobil 1. That was the requirement for my 2010 SS, while Dexos 1 is the standard for all the rest of the GM fleet.
Old 11-06-2017, 04:33 PM   #16
enzia35
Drives: '16 Garnet Red 1SS
Dexos 2 is more for GM diesel engines. There is a Dexos 1 Gen 2 specification though.
'16 Camaro 1SS
'18 Miata GT
Old 11-06-2017, 05:00 PM   #17
ride98red
ride98red's Avatar
Drives: 2017 Summit White Chevy Camaro 2SS
Dexos 2 is for both diesel and gasoline engines. The link to the gen 2 dexos 1 specs were provided in a previous post of mine.
ride98red is offline   Reply With Quote
Old 11-06-2017, 05:06 PM   #18
ride98red
ride98red's Avatar
Dexos 2 is not the recommended oil for the 6th gen Camaro. And Mobil 1 comes in both dexos 1, 2, and...plain ole oil (non-licensed dexos).
Old 11-06-2017, 06:12 PM   #19
lt4camaro
lt4camaro's Avatar
Drives: 2021 LT1 10 speed auto
Originally Posted by USRobo View Post
I can't find anywhere that says Mobil One 5W-30 Fully Synthetic oil is Dexos compatible.
My guess is that it should meet or exceed the blend.
Read the label, mobil one 5-30 full synthetic has the dexos on it. All corvette's with the exact same LT1 require mobil 1 only. Full synthetic is always better than a blend ...period
lt4camaro is offline   Reply With Quote
Old 11-06-2017, 06:46 PM   #20
dpevans
Drives: 2024 Riverside Blue 2SS 1LE
I use Mobil One full syn, it says Dexos1 right on the bottle.
dpevans is offline   Reply With Quote
Old 11-06-2017, 06:56 PM   #21
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Ok, so I am good or better than good with Mobil One Fully Synthetic 5W-30 weight oil?
Yes. As long as an oil has the little green "Dexos1" logo on it, that means GM has approved it for use in your car.
Old 11-06-2017, 06:58 PM   #22
Mr. Wyndham
Green label = Dexos1, primarily for gasline engines.
Blue label = Dexos2, primarily for diesel engines.
However, in your manuals, you'll find a recommendation to run Dexos2-spec oils of 5W-40 weight for use while racing to withstand the higher temperatures of track-duty.
Old 11-06-2017, 07:47 PM   #23
ride98red
ride98red's Avatar
Right, OP wasn't referring to track use. He mentioned his first "free oil change" which implies daily use, in which case dexos 1 oil is the recommended oil.
Old 11-06-2017, 07:52 PM   #24
Mr. Wyndham
True. Someone else mentioned Dexos2...just wanted to clarify what role that stuff plays in "Camaroland".
Old 11-06-2017, 08:35 PM   #25
greaser2
greaser2's Avatar
Drives: 2017 A10 ZL1 KG
There was is no data that says Mobil 1 is better or worse then a semi synthetic.
greaser2 is offline   Reply With Quote
Old 11-06-2017, 08:53 PM   #26
enzia35
Track and diesels.
'16 Camaro 1SS
'18 Miata GT
Old 11-06-2017, 10:23 PM   #27
g-boac
Drives: 2018 ZL1 Coupe M6
Say what??? It's on the front of the bottle, lower right corner (the 5-gallon jug). When I purchased mine (I use Mobil 1 full syn as well) I verified the dexos specification. You're good.
haha, you mean 5-quart jug, correct?
also, I've only found the 5-quart jug at Wal-Mart; everywhere else the jug is 4-quarts. Notably, the 5-quart jug sells for the same price at Wal-Mart as the 4-quart jug does at O'Riley.
g-boac is offline   Reply With Quote
Old 11-06-2017, 10:43 PM   #28
enzia35
Who sells a 4-qt jug???
'16 Camaro 1SS
'18 Miata GT
