Old 02-02-2018, 11:59 AM   #15
DiGiam
DiGiam's Avatar
Drives: 2016 NFG SS A8
My KOOKs 2' headers leak at the ball flange as well. the ticking is annoying
2016 NFG 1SS A8. Pray ported intake manifold, Rotofab dry cai, kooks 2" catted longtubes, E85,
DiGiam is offline   Reply With Quote
Old 02-02-2018, 12:11 PM   #16
Nightfall SS
Nightfall SS's Avatar
Drives: 2016 Camaro 1SS
My kooks always sound like there is a leak with the enhanced ticking noise but with flashlights and inspection mirrors I never see evidence of soot caking or anything so I presume its just the nature of the beast to hear these noises now. I never had codes though once I tuned for it.
1. Phastek detachable front license plate bracket 2. Blacked out Bowties 3. Blacked out sidemarkers/third brakelight 4. Rotofab dry/no soundtube CAI 5. VMAX ported throttlebody 6. Kooks 1 7/8 Longtubes with Hi-Flow Cats 7. EFI Tuning Flex Fuel kit and tune 8. HP Tuners NGAUGE 9. Zeitronix ZT-2 Wideband(reads on NGAUGE) 10. Ported MSD intake manifold 11. CORSA XTREME axle back w/ dual quad black tips
12. Racestar Darkstars 17X9.5 with Mickey Thompson ET Street SS 305-45 17 Radials 13. Kicker 3-way door speakers. DYNOCOM mobile dyno trailer: 471hp/490TQ@97degrees ambient/ethanol percentage=80%
Nightfall SS is offline   Reply With Quote
Old 02-02-2018, 12:18 PM   #17
1LE Red Dragon
Train Driver
Drives: 2018 Summit White ZL1 1LE
The sound you are talking about, I was used to. This sound that developed is a old truck sounding leak, that you can only hear mostly on the highway cruising. You give it a little gas and you hear the leak. When you go WOT or about 60% throttle (i would estimate), the exhaust gets loud enoujgh where you cant hear it. This sound is a putt putting noise. We could not feel it the first time I took it in on the lift. But we did see the black soot mark. The 2nd and 3rd time taking it in, you could feel the leak, its very small and you dont hear it under the car much at idle. But when the exhaust pressure is loud, and with the AFM valves shut the higher backpressure causes it to leak worse. My mechanic and my thoughts on it.
I am trying to get to Kooks R&D center for them to evaluate. They are only 30 minutes from me.
2018 Camaro ZL1LE
/ / Katech TB // RotoFab Dry // Borla 60606 // ATI Super Damper / /
1LE Red Dragon is offline   Reply With Quote
Old 02-02-2018, 12:47 PM   #18
marknagy13
Markoon13
marknagy13's Avatar
Drives: Camaro 2SS
I have the same problem. This stuff seemed to fix it pretty well and it's easy to install.
http://amzn.to/2GHPFmQ
marknagy13 is offline   Reply With Quote
Old 02-02-2018, 03:09 PM   #19
1LE Red Dragon
Train Driver
I will give that a shot. From Kooks R&D guy, he says they have made a pipe that will go from the outlet of the connector pipes (catted or off-road for stock exhaust) to the stock rear muffler. This pipe is smoother than the stock pipe and eliminates the crush section too. It is the primary stages of production. And he says it will make for a much more reliable connection, but at a cost.
2018 Camaro ZL1LE
Old 11-17-2022, 03:08 PM   #20
Spaceme1117
Spaceme1117's Avatar
Drives: 2017 Camaro SS, 2011 Corvette GS
I don't mean to resurrect a 4-year old thread but if the OP is still active here, I would love to hear if he was able to solve the leak?
I just got a bunch of O2 codes pop up on me on my 2017 SS. I have the Kooks headers with the catted connection pipes to the stock exhaust and everything had been running perfect since the install in the early spring. (Also had the car tuned at the same time)
Only thing I can think changed was that we went from 70+F temps to barely 32F temps in about a day and maybe this is causing a connection (or connections to leak).
I should be able to get under the car in a few days once the temps warm up.
It is definitely not the problem of the harness on the passenger side touching the header; I made sure to move that out of the way and heat insulate it at the time of the header install.
Spaceme1117 is offline   Reply With Quote
Old 01-01-2023, 02:24 PM   #21
Camarojt
Camarojt's Avatar
Drives: 2011camaro SS
I have a Question for those that did the Kooks headers with off-road connection pipes to factory NPP exhaust. I cut my factory exhaust pipes where Kooks said, however the off-road pipes won’t fit inside the factory exhaust pipe unless the end of the factory exhaust pipe is flared some. A muffler shop can do this very quickly. My question is, for those of you that decided to take your car to a muffler shop for this reason, did you leave your exhaust attached in the rear and the hangers, and just let it rest on the tunnel brace and drive it that way slowly to the muffler shop? Or did you remove the exhaust, and truck it separately while you drive your car to them?
Camarojt is offline   Reply With Quote
Old 01-05-2023, 08:49 PM   #22
Sephx1
Sephx1's Avatar
Drives: 18 ZLE, 18 SS1LE, 16 SS, 23 ZL1
Wouldn’t a V-band setup take care of the leaking issues? I’m considering this so I can easily take out the cats on my ZL1 and swap them for off road pipes when I track it.
Sephx1 is offline   Reply With Quote
Old 08-10-2024, 04:23 PM   #23
Joelskidelahoya
Drives: 01 Z28 05 GTO 06 GTO 09 CTSV 21 1LE
I was gonna get a set of kooks? Would it just be easier to have a muffler shop make a connection pipe n weld it as opposed to spending 800 bucks on something that might work
Joelskidelahoya is offline   Reply With Quote
Old 08-10-2024, 07:31 PM   #24
GreyGhost702
Drives: 2019 Camaro 1SS1LE
This post is like the ultimate Walking Dead lol. Just won't stay dead!
When ordering exhaust parts, make sure you're using the parts for the application they specify. If Kooks says their headers are meant for their mid-pipes, use their mid-pipes or you'll need an exhaust shop to make a connection for you. If you buy their mid-pipe, then you should be fine on your own. You can always talk to Kooks on the phone to verify part combinations and what your intentions are.
I have a set of knock-off's and just had a local shop weld up some V-band connections and make it work with the factory mid-pipes. Eventually will be going back under there for a custom H pipe. Will have them V-Band at the collectors and at the axlebacks, so the system can be removed more easily.
2019 1SS1LE M6 Shadow Gray Metallic
ProCharger D1X Race Kit - 4.25" Pulley || GPI Pistons/Rods - ACL Bearings - ARP Hardware || LME Timing Chain Guide || Katech C5R Timing Chain || Katech OE Spec Billet Oil Pump || OE Ported Heads || CHE Trunnion Upgrade || BTR 220 Cam - BTR .660" Dual Springs - GM Racing "Caddy" Lifters - BTR 3/8" Pushrods (7.825") || ATI Balancer || LT4 Injectors || LT4 HPFP || JMS BAP || DSX Flex Fuel || LT2 Intake Manifold || LTH (Catless) || Stainless Works Redline Series NPP || 91 + 8oz Boostane
7/26/2024 Tuning in progress
GreyGhost702 is offline   Reply With Quote
Old 08-11-2024, 12:25 PM   #25
MyNameIs
Drives: Camaro SS
If leaking at the collector then sounds like a header defect. Call Kooks.
MyNameIs is offline   Reply With Quote
