#15 |
![]() Drives: 2016 2SS, Summit White, A8, NPP Join Date: Apr 2013
+1 on this, mine just started the other day. I haven't been in for the flush yet.
#16 |
![]() Drives: 2016 Camaro LT2 v6 A8 Join Date: Nov 2016
help
+1. i have my local dealership ready to have a GM engineer come to Wilmington, NC to ride with me. If GM would just read this real world data it would save them the trip. GM, step up, read from the customers who spend their hard earned $$$$ with you. Fix it now.
#17 |
+1
Mine doesn't have the shudder (yet), but I'd love to know what gives before it does... |
#18 |
#TeamBeckyD
Drives: 2017 HBM 2SS Convertible A8 Join Date: Aug 2008
"This"
**FIFTY HBM 2SS VERT** |
#19 |
![]() Drives: 2017 Fifty 2SS w NPP Join Date: Dec 2011
Well it looks like after 9 months and about 4000 miles mine is acting up again.
So it looks like another trip to the dealer soon. The did a triple flush, filter change and reprogrammed the computer last time. I really hate having to go through this again.....
#20 |
Snackbar Tuning
Drives: 2023 SGM ZL1 Join Date: Oct 2016
+1 I had this show up at 2000 miles on my 2017 SS Fifty. Triple flush and TCM reprogram/reset and the car has been shudder free for 6000 miles.
#21 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Camaro 50th anniversary edition Join Date: May 2017
+1 we have the same problems over here in the EU but it takes ages until our dealer get information from GM. Please Al enlighten us.
Soleil
_____________________________________________ A car is fast enough, if you fear to unlock it in the morning." (Walter Roehrl) |
#22 |
GM just needs to allow the TCM to be tuned properly and the issue will go away. This is of course before the issues start popping up. All the slipping programmed into these transmissions is eating up clutch packs and causing the converter shudder. Replacing the failed parts without proper tuning is just going to lead to the same issue again. Unless GM redesigns the parts to be able to withstand all the slipping. They really teabagged this transmission.
#23 | |
#24 |
links
Wanted to make it easy for GM to read some real world threads about our A8 issues. There are plenty more on here......
http://www.camaro6.com/forums/showthread.php?t=470624 http://www.camaro6.com/forums/showthread.php?t=510599 http://www.camaro6.com/forums/showthread.php?t=506642 http://www.camaro6.com/forums/showthread.php?t=503577 |
#25 |
![]() Drives: 1979 Corvette Join Date: Mar 2017
Thank you everyone who is chiming in on this!
I just wanted to add two notes that hopefully will get to Al, as KingLT1 noted, some forum members have had a lot of luck tuning their TCM to make the TC lock up 100% at cruising. In addition, a forum member from Chicago said that his dealership was informed that GM is supposedly releasing a revised speed sensor and wiring harness that fixes the issue of the hard/improper shifts which are apparently maybe caused by the speed sensor sending improper data and the A8 not knowing the correct input speed for shifting. I personally experience this on a daily basis, and have had multiple instances where the A8 either shifts at the wrong speed, shifts abruptly, or fails to shift up under hard acceleration. I think a proper tune and/or new speed sensors are both relatively simple fixes to roll out to anyone who is experiencing any of these symptoms, and should certainly be cheaper than GM having to pay lots of $$ for very expensive transmission flushes over and over again or replacing the transmission and/or TC entirely. I am personally seriously considering trading in/selling my 17 1SS JUST because of the A8 and getting a 2019 just to get into an A10, and would likely lose a lot of money in the process. Please let us know if GM will do something to address these issues/implement these fixes. |
#26 |
When this will be sent to Al? Hopefully not in 8 weeks
Soleil
#27 |
![]() Drives: 2017 2SS A8 Black Join Date: Mar 2017
+1...mine goes to the shop next tuesday for very pronounced low RPM shudder in V4 and V8 mode.....started at about 8k miles....almost 10k miles now.
Man is born free, and everywhere he is in chains
#28 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
It will need to be selected to be in the poll and then get the most votes in the poll. I suspect question #2 is 1-2 weeks out from when Al and team actually receive it.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
