#15 | |
Big Samoan ina little car
Drives: 2016 camaro Join Date: May 2014
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt "Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant |
#16 | |
![]() Drives: 2016 2SS A8 Join Date: Feb 2016
Are you referring to version 3.7?
16 Summit White 2SS-MRC-NPP-A8 :: PrayPorted IM - LT5 TB - Mishimoto Catch Can - RotorFab - E85 - TSP 2" LongTubes - Speed Engineering X/Mid Pipe
DIY Hpt Tune - DR - 1.75-60' - 7.47@95 - 11.56@120 with +2676DA |
#17 |
yes 3.7...I just had Hp tuners support update my account so I can download it. The caveat is it's not backwards compatible, so( Correct me if I am wrong.)you will want to flash your stock tune, reread the ECM with 3.7, save the new stock file, then modify and flash from there?
#18 |
Drives: 2016 Camaro SS Join Date: Oct 2016
You can use the old stock file with 3.6 if you need to flash back to stock. The backwards incompatibility is a bit of an annoyance. I wish they would update 3.6 to handle 3.7 opening and flashing.
Keep solid backups! |
#19 |
Have a question. I was under the impression that it took 4 credits to access both the ECM and TCM with HP tuners? When I licensed mine it only required 2 credits and it will let me flash both the ECM and TCM.
#20 |
16s use the E92/T87 controllers. For 17+ they moved to E92A/T87A which bring the additional steps and cost. It makes for a costly venture if you want/need to touch the TCM.
Tim |
#21 |
Just want to update that this has worked for me. I have not logged a ton of miles, but so far no issues.
#22 |
Bodysnatcher
Drives: 2017 Black RS Join Date: Oct 2016
I have the 2.0 T and it is doing it (Shuddering) when transmission fluid temperature reaches 147 Deg, So I am wondering, I know I have to bring the car to the dealership, but from what I am gathering, the three flushes wont work?, and is replacing the TC gonna work?
#23 | |
#24 | |
![]() Drives: Camaro 2SS Join Date: May 2016
#25 |
No if anything it will pro long the life of the transmission. Slipping causes heat which eats up clutches.
#26 |
#27 |
No because the shudder does not occur on shifts. It usually happens when cruising around 1500 RPM and or in/out of AFM.
#28 |
![]() Drives: 2017 50th Camaro SS Join Date: Jul 2016
OK, I just had my TCM unlocked and we will be doing some other mods. Should I tell my tuner to ZERO out all slip in 7th and 8th gear? Anything else I should tell him regarding the shudder problem and tuning solutions?
50th Anniversary Edition |Borla Atak and 60606 mid pipes| Kooks 1 7/8" | ProCharger Stage II |305/45/17 DRs | Circle D 3500 stall | LT4 fueling | Custom made Lowside Aux Pump | Alky Control Meth | DSX E85
