Old 10-10-2017, 12:57 PM   #15
oneredry
HYPER SS
oneredry's Avatar
Drives: 2016 Supercharged 2SS
we had to use a 4ft pry bar. putting the car in reverse and e brake still managed to turn the tires. the tq on that bold is redonkulous.
Ordered: 1/15/2016
2000 status 02/01/16
3000 status 02/29/16
3400 status 03/07/16 TPW of 03/14/16
4200 status 03/17/16 in transit!
Delivered 03/23/16
2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points.
| AWE touring - resinated catback with link pipes.
oneredry is offline   Reply With Quote
Old 10-10-2017, 06:57 PM   #16
bpang1234
You can only YOLO once.
bpang1234's Avatar
Drives: '16 2SS & '15 Subaru Forester
OK so straight up, how hard is the install?
2016 Camaro 2ss
-Summit White / Ceramic White
-8A, NPP, MRC, Ceramic White package plus knee pads, black bowties.
-1st Car to have the "full" SEMA High Performance Graphics kit from 6LEDesigns.
-1st Car to have the 6LEDesigns Blade Spoiler.
-Borla S-Type w/ custom H-Pipe
-Procharger P-1X Stage 2
bpang1234 is offline   Reply With Quote
Old 10-10-2017, 07:01 PM   #17
MR 45TH
MR 45TH's Avatar
Drives: 2018 ZL1
It’s not that hard at all! As far as the crank bolt, 30 seconds with a propane torch and it will come right out. Easy day
2018 ZL1…Many mods to come
MR 45TH is offline   Reply With Quote
Old 10-11-2017, 08:00 AM   #18
oneredry
HYPER SS
oneredry's Avatar
yeah, the install was not bad. just took my time with it, but the bolt part was probably the hardest. we used a heat gut to loosen up the Loctite. came right out, but the force to put it back on (per GM's requirements) was lets just say... interesting.. took me 4 days (or two weekends worth) doing it. only help I had was putting the bolt and holding the flywheel with that pry bar.
Ordered: 1/15/2016
Delivered 03/23/16
Old 10-11-2017, 08:05 AM   #19
Dysan911
Dysan911's Avatar
Drives: 2017 50th Anniversary 2SS
Same here. Taking it out was easy but tightening it down I thought I'd never hear the torque wrench click and I was pulling with everything I had. If I had it to do over again I would make sure I could find a length of pipe to slip over the end of the torque wrench for better leverage. I was renting one from local parts store and thought my jack handle would slip over the end of it but nope that didn't work.
Dysan911 is offline   Reply With Quote
