Old 12-18-2017, 08:49 AM   #15
Biscuit.fr
Drives: Red hot ZL1 A10 2017
Originally Posted by Stephen12ZL1 View Post
amazon had them...not a terrible price when I purchased...ACDelco 13598787 GM Original Equipment Tire Pressure Monitoring System (TPMS) Sensor Kit with Sensor and Stem. 24.31 each
Are they the ref for gen6 TPMS for sure?
Tx
(Got the std Zl1 and not the 1LE)
Biscuit.fr is offline   Reply With Quote
Old 12-19-2017, 08:50 PM   #16
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
Tx
yes...the ZL1 sensors and ZL1 1LE are the same. Fifth gen sesnors will not work. The ones I listed work and this is confirmed. You do need the reset tool just like the 5th gen. The orange electronics unit works fine.
Old 12-20-2017, 01:32 AM   #17
FringBirdAloha
Drives: Pre-production ZL1 M6
Originally Posted by seanblurr View Post
Buy the $40 dollar orange tool from Amazon. Sorry, I don't have a link. Super simple once you have the tool, though.
OP did that.
FringBirdAloha is offline   Reply With Quote
Old 12-20-2017, 10:29 AM   #18
Macaro
Macaro's Avatar
Drives: 2018 Camaro ZL1 1LE
I'm glad this thread has been re-opened. I'm the OP and I have a story to share...
When my older wheels/tires with the older TMPS sensors in them didn't work, I didn't think it was a big deal. Shortly after I created the post I had three track days all pretty close to one another. The third day was up at Palmer which is about 2 hours from my home. I drove out, spent the night at a hotel and the next morning went on-track. It was raining lightly during the first session so speed were kept down. By the second session it was getting nice out and we started to turn up the wick a bit. About mid-way through the session, my car just felt all kinds of wrong. Without TPMS working I had no idea that I had a flat tire. Luckily, I came around the last corner before the straight and at the last minute I decided to pull off and take a look. Thank goodness I did because by the time I got to the end of the pit wall I was nearly riding on the rim.
I've since purchased new TPMS sensors because I was lucky this time and I felt the issue but had the sensors been working, I would have KNOWN there was a problem well before I could feel it.
Macaro is offline   Reply With Quote
Old 04-19-2018, 11:29 AM   #19
JANNETTYRACING
JANNETTYRACING's Avatar
Any solution I tried to reset mine using the tool NO GO.
Ted.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 04-19-2018, 07:11 PM   #20
Stephen12ZL1
Drives: '21 ZLE A10
Ted.
please explain, Ted?
Old 04-20-2018, 07:33 AM   #21
JANNETTYRACING
Evidently the Orange GM TPS reset tool does not work on 17 and 18 cars.
Old 04-20-2018, 07:53 AM   #22
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
It works on mine. This sounds silly, but how are you using it? When I first got it I didn’t know, and I thought it was broken.
seanblurr is offline   Reply With Quote
Old 04-20-2018, 08:11 AM   #23
JANNETTYRACING
We have 2 of them neither would work on a 17 and 18 car in the same day with 2 techs that are very familiar with there use.
This thread seems to be the same problem that is why I chimed in.
Ted.
Old 04-20-2018, 02:53 PM   #24
waterman
waterman's Avatar
Drives: Grandad's C2 L89
following, subscribed.
2018 ZL1 1LE sw/PDR
Old 04-20-2018, 05:08 PM   #25
gotroost
gotroost's Avatar
Drives: 2021 Crush ZL1 1LE
I had a 2010 2SS and it didn't need a tool at all. Just dropped the pressure to put it in learn mode. Must have "improved" things with the 5th Gen refresh and later models. For track tires, I just left the TPMS out but that probably wasn't very smart.
2021 Crush ZL1 1LE
gotroost is offline   Reply With Quote
Old 04-20-2018, 08:22 PM   #26
Stephen12ZL1
Drives: '21 ZLE A10
sorry, this is incorrect. Mine works fine for the '17 & '18 ZL1. I swap back and forth between stock wheels and road course wheels constantly.
Old 04-20-2018, 11:53 PM   #27
JamesNoBrakes
JamesNoBrakes's Avatar
Drives: 2SS 1LE
I put my summer tires on a few weekends ago and from that I figured out that the orange TPMS reset tool I have is directional. I have to aim the antenna at the TPMS sensor through the tire sidewall. When I do that, it works great. When I just point it in random directions or hold it close to the tire, it doesn't work. Somehow I made the damn thing work when I put the winter tires/wheels on, but after several tries I finally got it to work and I didn't know what the magic trick was. Now I know. Aim the antenna at the sensor.
2018 2SS 1LE
2023 Colorado ZR2
2022 Stinger GT-line AWD
JamesNoBrakes is offline   Reply With Quote
Old 04-21-2018, 10:01 AM   #28
TLSTWIN
Romans10:9-13
TLSTWIN's Avatar
Drives: /\yes, this is me/\
The instructions on mine actually tells me I have to hold it against the tire wall at the sensor location.
TLSTWIN is offline   Reply With Quote
